Kohler engine surging - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 10 Old 04-04-2012, 05:54 PM Thread Starter
I took out dad's Gravely from winter storage, sharpened the blade and started cutting grass. It was running smooth, then about 5 minutes in, the rpm started surging. It idles just fine. It surges anywhere above idle. If I hold the throttle on the carb, the engine smooths out and just hums. I am assuming this is a problem with the governor, but have no idea where to start. I can't find a thread on this, so I must not be selecting the correct search parameters.
It is a Gravely 5260 according to the hood, I could not find any other plates on it. The engine is a Kohler
Model K181S
Spec 30675D
Ser # 8250569
Thanks in advance for the help.
'86? Ranch King 18/46
'04 Ariens 15/40
'?? Roper 18/50
Gravley walk behind
Trac Vac for the Roper
Misc Trailers set up to pull as Triples
zufrieden is offline
post #2 of 10 Old 04-04-2012, 07:33 PM
Re: Kohler engine surging
Model K181S
Spec 30675D
Ser # 8250569
Before you condem the governor, clean the carb in place and check all the carb settings. And engine that is too lean or too rich will "hunt", especially too lean.
Sheldon
ATLANTICCENTRAL is offline
post #3 of 10 Old 04-04-2012, 07:57 PM
Gravelyyard.com
arcam8123's Avatar
Like Sheldon said, most surging is a carb issue. If you close the choke some, does it have an effect on the surging?
Ron C
www.gravelyyard.com
www.gravelytractorclub.org
My Equipment: You're kidding, right? Not enough bandwidth on the planet.
arcam8123 is offline
post #4 of 10 Old 04-04-2012, 08:54 PM
Grand Sierra's Avatar
Hunting or surging can be fuel or air. Yours is probably fuel related, I fixed my generator that ran better on half joke carb bowl had junk and water in it. I just cleaned bowl didn't take it apart ran Seafoam in it for an hour. It still hunted after bowl cleaning let it sit a few weeks and its running great now, I was surprised it cleaned everything out.
Grand Sierra is offline
post #5 of 10 Old 04-04-2012, 10:50 PM
Richard-tx's Avatar
Images: 7
I suspect water contamination. Check the fuel. If it is yellow, then it likely has water in it. The problem with water is that even though the engine may run fine, there can be a layer of water lying in the bowl just below the main jet of the carb corroding it.
Some carbs have a bowl drain. THe Kohler K series do not as a rule.
The fix for water contamination is to drian the tank, blow it out dry, flush the lines, replace the fuel filter or clean sediment bowl, and then clean out the bowl of the carb. If the water has reached the main jet, then a full carb cleaning may be necessary.
Code:
                              Current Inventory
                              8183T (Onan B48)
Richard-tx is offline
post #6 of 10 Old 04-05-2012, 04:44 PM Thread Starter
Thanks Guys, I will try these things tonight and let you know.
'04 Ariens 15/40
'?? Roper 18/50
Gravley walk behind
post #7 of 10 Old 04-06-2012, 09:53 AM
CTPhil's Avatar
With gas being how it is, I've started the habit of treating every small engine that's not running right with an additive like seafoam before getting out any wrenches. It worked wonders on my 5460.
Gravelys: 1951 L, 1952 L, 1954 L, 1956 LI, 1961 LI-SR, 1962 L, 1962 LI, 1963 LI, 1965 L8, 1965 LS, C 10, 524, 5460, 8102.
I can quit any time I want. I just don't want to right now.
The rest: 1969 WH Raider 12, 1983 WH A-111, 1985 WH 314A, AC 917H, 1978 Ford 2600, 1978 Ford 4100, 1975 Ford 3550 Industrial, 1959 Farmall 560, 1949 Case VAC, 1951 Case VAC Eagle Hitch, Troy Bilt Horse, Troy Bilt Pony. Mowers, rakes, balers, and far too much other old junk to list....
CTPhil is offline
post #8 of 10 Old 04-06-2012, 10:35 AM
Richard-tx's Avatar
Images: 7
As far as I am concerned Seafoam is a ripoff. Read the MSDS for the reason why. In any case, I don't use it. If you want to, then by all means do so. Why should I care one way or the other? It is your engine, not mine.
Lighter Fluid is another example. I see that stuff usually selling for $9 or more for 12 ounces online. Lighter fluid is 100% VM&P Naptha. I buy VM&P naptha for about $15 a gallon from the paint store. The rest is packaging, advertising, and profit.
Charcoal lighter is yet another example. It is nothing more than Mineral Spirits.
http://msds.walmartstores.com/cache/27928_1.pdf
I love MSDS data. It really brings out the truth in specialty products.
Code:
                              Current Inventory
                              8183T (Onan B48)
post #9 of 10 Old 04-07-2012, 01:03 PM
It worked great on my weed wacker that bogged out at full throttle, ran it threw the tank and it reved like crazy. So far I have had good luck with it next my Honda powered 2 stage Dewalt gas compressor is running a little off. I'll see if I can go 3 for 3. I do like to take carb off and clean out everything but if I'm not in a rush for something I'll drop bowl and add it in fuel tank so far it has worked for me.
post #10 of 10 Old 04-07-2012, 02:06 PM Thread Starter
I changed the fuel, took the bowl off and took all the water and rust particles out of it. Cleaned things up with some carb cleaner. She started up and still surged a little. I made a small adjustment to the high speed mix and she is running great. Thanks for all the help guys.
'04 Ariens 15/40
'?? Roper 18/50
Gravley walk behind
