432 Commercial - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 23 Old 03-12-2012, 06:28 PM Thread Starter
432 Commercial
Hello all, I have a few Gravely related questions. I have an early 432 commercial. It has the rear mounted attachment lift. I found the schematic here :
http://www.oldgravelys.net/pdf/Rear_...t_IPL_1071.pdf..
I have the hitch and almost everything to make it complete, however I am missing part #'s 14721P1 which is the clevis rod, 14719, which is the clevis. Anybody out there able to help me locate these parts?
Also looking for the attachment to hook up the rotary plow and the roto tiller to the front of this machine as well. I just picked up L today with the brush mower, the rotary plow and the rototiller and would like to mount them to the front of my 432 if possible.
Billmac001 is offline
post #2 of 23 Old 03-12-2012, 10:06 PM
canadian.gravelynut's Avatar
Re: 432 Commercial
The parts that you are looking for do show up on E-bay that might be the place to look or at the Mow-in
It is Gravely season
John
canadian.gravelynut is offline
post #3 of 23 Old 03-12-2012, 11:55 PM Thread Starter
Re: 432 Commercial
Thanks for the reply
post #4 of 23 Old 03-13-2012, 12:29 AM
FLOYD'S's Avatar
Re: 432 Commercial
i can have those for you soon. i am parting a 432 this week.
FLOYD'S is offline
post #5 of 23 Old 03-13-2012, 12:38 AM Thread Starter
Re: 432 Commercial
That would be great!!
post #6 of 23 Old 03-13-2012, 09:25 AM
deerecharles's Avatar
Re: 432 Commercial
Does it have an electric lift?
deerecharles is offline
post #7 of 23 Old 03-13-2012, 09:29 AM
FLOYD'S's Avatar
Re: 432 Commercial
no, it is manual lift.
FLOYD'S is offline
post #8 of 23 Old 03-13-2012, 05:07 PM Thread Starter
Re: 432 Commercial
No on the electric lift but that would be nice.
post #9 of 23 Old 04-07-2012, 04:22 PM Thread Starter
Re: 432 Commercial
I have another question about this tractor. When I got it the PO advised me that it would work in low range and reverse but not in high range or when the mower was engaged it would slow down. I pulled the engine off today and this is what I found. I believe this is the rear ring gear? any ideas what would cause this wear?
ID:	207050   Click image for larger version
ID:	207051   Click image for larger version
post #10 of 23 Old 04-07-2012, 04:42 PM
Gravelyyard.com
arcam8123's Avatar
Re: 432 Commercial
Very worn bushings in the planetary gears. Here's what I found in my Pro Master 50 that did the same thing except it would not work in low range.
The bushing is .036 clearance. It should not be more than .002 if my memory serves me.
ID:	207053   Click image for larger version
ID:	207054   Click image for larger version
ID:	207055   Click image for larger version
Ron C
www.gravelyyard.com
www.gravelytractorclub.org
My Equipment: You're kidding, right? Not enough bandwidth on the planet.
arcam8123 is offline
post #11 of 23 Old 04-07-2012, 07:32 PM Thread Starter
Re: 432 Commercial
Well that would explain things, Are there bushing kits available to rebuild the planetary or do I need to send the planetary to Richards?
post #12 of 23 Old 04-07-2012, 08:40 PM
Gravelyyard.com
arcam8123's Avatar
Re: 432 Commercial
You can buy bushings for replacement, but you need to measuse the pins and bolts to make sure they are still round and not oval. Those bolts are left hand thread by the way.
Ron C
www.gravelyyard.com
post #13 of 23 Old 04-07-2012, 11:58 PM
Gravelyyard.com
arcam8123's Avatar
Re: 432 Commercial
Here's some pictures of a worn bolt and bushing next to a NOS bolt and bushing. You can see the difference. What you can't see is that the bolt is .010 out of round.
ID:	207173   Click image for larger version
ID:	207174   Click image for larger version
Ron C
www.gravelyyard.com
post #14 of 23 Old 04-08-2012, 12:26 AM Thread Starter
Re: 432 Commercial
Thanks for the replies Ron....
post #15 of 23 Old 04-08-2012, 12:52 AM
Richard-tx's Avatar
Images: 7
Re: 432 Commercial
If it were mine I would replace the orbit gears as well as the ring gear. I would also examine the sun gear (engine gear) for wear. There is also the pilot bushing to examine as well.
Code:
                              Current Inventory
                              8183T (Onan B48)
Richard-tx is offline
