Points or Eletronic Ignition - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 28 Old 01-22-2012, 03:10 PM Thread Starter
smoothracing's Avatar
I was just wondring how many have converted there points ignition over to eletronic,and indexing the spark plugs.I been thinking of converting my Onan over.Kirk Engines,Inc sells the point savers and coils.Might just be a cheap way to get a little more ponys out of the Onan.
smoothracing is offline
post #2 of 28 Old 01-22-2012, 08:15 PM
Richard-tx's Avatar
Images: 7
Re: Points or Eletronic Ignition
I wouldn't touch the Onan points and condenser system for all the tea in China. It is so reliable and so trouble free that nothing would be gained by putting a electronic ignition on an Onan CCKA or B series engine. I think I changed the points and condenser on my 818T when I got it over 15 years ago. I have not touched it since.
The only failure I ever had on my CCKA engines was the 6 volt coil. The epoxy that was used to encapsulate the coil is now starting to break down due to age. As a result the spark will arc from a crack in the case to ground.
If you have the old style coil and want to upgrade something, get a new style Onan coil. I think they have a higher output voltage than the old one. Don't forget to take the voltage dropping resistor out of circuit. The new coil is a 12 volt coil. I think I paid about $60 for a new Onan coil.
Code:
                              Current Inventory
                              8183T (Onan B48)
Richard-tx is offline
post #3 of 28 Old 01-22-2012, 09:16 PM Thread Starter
They also make them for Kohlers too,was just pondering the idea,we put transisterized ignition on my neighbors 5600 (8hp kohler) and it made a world of difference on it.
post #4 of 28 Old 01-22-2012, 10:43 PM
Senior MTF Poster
"we put transisterized ignition on my neighbors 5600 (8hp kohler) and it made a world of difference on it."
?? My experience has been that there is no improvement in performance and engines equipped with points and cond. in good shape start easier, fewer rpm required to fire.
Walt Conner
Walt 2002 is offline
post #5 of 28 Old 01-22-2012, 10:59 PM
CADplans's Avatar
Anybody got part #'s/link for the Kohler conversion??
I would love to look at it!!
CADplans is offline
post #6 of 28 Old 01-22-2012, 11:12 PM
Richard-tx's Avatar
Images: 7
I agree with Walt. A properly functioning points and condenser will make no difference when converted to electronic. If the wiring is bad, the condenser old or the points corroded then an improvement will be experienced when converted to electronic.
Now if a different coil was used, then the coil change will likely show an improvement over the stock coil but the electronics had nothing to do with the improvement.
How the path to ground on the primary side of the coil is switched on and off makes no difference in spark quality. It is the coil itself that makes the difference.
Here is some food for thought. Inside the electronic ignition are usually some electrolytic capacitors. That is exactly what a condenser is. So what happens when the capacitors fail? Convert back for $30 or replace a $100 (future price) ignition module?
Code:
                              Current Inventory
                              8183T (Onan B48)
post #7 of 28 Old 01-22-2012, 11:28 PM
Richard-tx's Avatar
Images: 7
I did a Google search for "Kirk Engine" and found it.
Code:
                              Current Inventory
                              8183T (Onan B48)
post #8 of 28 Old 01-23-2012, 06:10 AM
Gravely Model L Guy
Gravely Model L Guy's Avatar
I converted my K301 that is on my Commercial 12 from Electronic to points ignition and I think it runs better on points
1951 Gravely Model L.
1964 L-8-currently under restoration.
1953 Model L with ring gear Ford type starter
1957 lI pull start
1957 li elec start
1961 L
1963 L-I
1970 Commercial 12
1963 L-I super convertible.
1987 Ford LGT14D
1960 bunton mower
1926 Ford Model T Tudoor sedan.
1985 Troy-Built Horse
1979 Troy-Built Horse
1950's Airens Trans a Matic
1972 MG MGB roadster
1997 ford f-450 5 spd 7.3 turbo
check out my youtube channel: http://www.youtube.com/user/64gravely?feature=mhee
Gravely Model L Guy is offline
post #9 of 28 Old 01-23-2012, 07:37 AM
Banned!
I also converted my K301 to points. Like Richard said, who wants to buy a $100 dollar coil?
gravely-power is offline
post #10 of 28 Old 01-23-2012, 08:24 AM
Just Have a Little Faith!
If you check on Brian Miller's site, he states that the stock Kohler coil puts out more than enough voltage to burn properly.
The stock Kohler points aren't going to float at max. recommended RPM, so the only other problem that points and condenser might cause would be if the owner had a problem with setting the timing. If proper technique is used in setting it, or better yet, a timing light, then stick with points.
The answer I have gotten is that indexing the plugs gives only a slight increase in HP, which would only interest a racer. I believe you might find more improvement with trying different brands of plugs.
LilysDad is offline
post #11 of 28 Old 01-23-2012, 08:25 AM
Senior MTF Poster
My eldest brother converted his Kohler K341 from points to electronic and then changed it back to points shortly afterwards.
Walt Conner
post #12 of 28 Old 01-23-2012, 11:42 AM
Richard-tx's Avatar
Images: 7
Ignition systems are somewhat of a mystery to some people. Once certain principles are understood, then one can more closely evaluate the claims made by manufacturers.
I remember all the gizmos and gadgets that were advertised in the JC Whitney catalog. If all the claims were true for fuel regulators, spark plugs, water injectors, coils, CDI, fuel line magnets, etc. then it would be easy to get 150 miles to the gallon from a 454 engine and get a 150% increase in horsepower too.
Code:
                              Current Inventory
                              8183T (Onan B48)
post #13 of 28 Old 01-23-2012, 11:47 AM
Gravely bug bit.
I'd be happy to get 30 MPG from the 8.1L.
The place where electronic ignition would help is down here. Points fail here due to moisture.
Current L/C count = 38.
Fla Don is offline
post #14 of 28 Old 01-23-2012, 12:28 PM
CADplans's Avatar
From my work on very low current flow contactors', the Kirk ignition would perform poorly in the Florida humidity.
Since the points are still used, the points appear to operate at very low current when converted to the electronic system.
At very low current the points will oxidize and fail to conduct current.
We prototyped 2 methods to resolve this problem on ship mounted (high humidity) contactors.
1) the contacts were gold plated.
2) the contacts were redesigned to "rub" at contact to break the oxide.
Method #2 was going to be real expensive to tool so we went with method #1.
Anybody know where I can get some gold plated Kohler point sets!!!???
CADplans is offline
post #15 of 28 Old 01-23-2012, 01:20 PM
Old Iron Connoisseur
Jimmy in NC's Avatar
I'll sell you some points for $250! Then you would swear they were gold plated!
Guaranteed not to rust, bust, or gather dust until they get out of the shipping package!
WANTED:
Time to finish all my tractor projects!
My name is Jimmy and I have G.A.S.
Click for an explanation if you need it....
Gravely 816s, 8182-T (Going back to 8183-T soon!), 526, Lots of "L"
Round Fender John Deere 110
Jimmy in NC is offline
