undercoating a mower deck? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 40 Old 08-21-2011, 08:18 PM Thread Starter
I have read several ads for mower decks for sale indicating they have been undercoated? Anybody do this? What are your thoughts?
Sheldon
ATLANTICCENTRAL is offline
post #2 of 40 Old 08-21-2011, 08:27 PM
Richard-tx's Avatar
Images: 7
Re: undercoating a mower deck?
I use epoxy paint or equivalent. If dried concrete can't stick to it, that is good enough for me.
Code:
                              Current Inventory
                              8183T (Onan B48)
Richard-tx is offline
post #3 of 40 Old 08-21-2011, 08:38 PM Thread Starter
So far I have just cleaned mine real good every fall when I take it off. It's still red underneath? No rust to speak of. The deck has reached the point were it looks really dull and dirty in spots and has a few small surface rust spots (very small), so I was thinking of some paint work when it comes off this fall.
Epoxy paint, that makes good sense to me.
Sheldon
post #4 of 40 Old 08-21-2011, 10:24 PM
eveled's Avatar
Images: 8
I think the decks rot out when they are allowed to sit outside and the moisture builds up underneath. Decks that are used alot seem to last the longest. When I work on a deck, I usually clean it up as best as I can then use apliance epoxy spray cans. The decks that I have in storage I keep up off the ground and spray with wd40.
Here's to our veterans past present and future
Machine of The Month link
eveled is offline
post #5 of 40 Old 08-21-2011, 10:31 PM
Old as Sin
silver hair deere's Avatar
I use the rubberized car undercoating on my 89 sears (mine since 91) still looks like new . wish I'd held up that good !!
Silver Hair Deere
2014Craftsman YTS 4500
1989 Sears lawn tractor (5 bolt)
1996 MTD 696 needs front fixed
1998 Murry needs engine 12.5 B*S
1989 GMC 1500
1998 FORD RANGER
When one breaks down , i just drive or
mow with another
A PROUD MEMBER FOR 10 YEARS !!!!
silver hair deere is offline
post #6 of 40 Old 08-21-2011, 11:38 PM Thread Starter
My tractor, and its accessories, have never spent the night out doors. My garage is not heated (at least not unless I am working out there in cold weather), but it is insulated and dry. And my deck is in good condition, just ready for some cosmetics.
I used spay can appliance epoxy on my recent wheel and wheel weight repaint - I'm very happy with it so far.
Sheldon
post #7 of 40 Old 08-22-2011, 02:18 AM
Richard-tx's Avatar
Images: 7
WD40 makes for a miserable rust preventative. Almost anything else is better. LPS3 is pretty good.
Code:
                              Current Inventory
                              8183T (Onan B48)
post #8 of 40 Old 08-22-2011, 10:52 AM
eveled's Avatar
Images: 8
Sheldon
I would need a warehouse to keep every thing indoors. I was just saying that the decks I've seen that had real rot issues spent a long time outdoors and most where on tractors that had sunk into the ground. On a working tractor I don't think it is an issue. So the answer to you orgingal question is that I don't think undercoating your deck is worth while. I'm also aware of wd40s limitations, but I get an endless supply of it for free, so I make the best use I can of it. The other problem with undercoating the spindles is that you may hold in heat and lead to premature bearing failure. Ed
eveled is offline
post #9 of 40 Old 08-22-2011, 10:57 AM
Back in VA!
crisco's Avatar
yes plus if you leave the grass buildup under there too long, it will rust underneath those blobs that grow over time. also i would assume the more wet grass you cut, the more you have to keep an eye on things under the deck.
-1972 816 Rider w/50" deck and M20 Kohler
-1990? Promaster 20 H with 60" deck M20 Kohler
-6x4 diesel gator with leaky tires
-1978 troy-bilt Horse tiller/V-furrow plow 7HP Kohler
-2007 Kubota BX2230s w/60" deck and FEL,
42" woods bush hog, 60" DR Power Gravel Grader
crisco is offline
post #10 of 40 Old 08-22-2011, 11:06 AM
eveled's Avatar
Images: 8
That is probably true, I do blast mine with the leaf blower on top and underneath to remove clippings and dust before I bring it into the barn. They used to make an adapter for your garden hose to attach to your deck but it seems like the worse thing you could do to it before putting it away, Ed
eveled is offline
post #11 of 40 Old 08-22-2011, 11:55 AM
qlty's Avatar
If you have been cutting wet grass spraying with a garden hose has to be better than not doing it,other wise blowing it with compressed air is my choice and sealing exposed metal with any paint has to be better than none JMO
qlty is offline
post #12 of 40 Old 08-22-2011, 12:44 PM
Desk by Day/Shop by Night
esnb74's Avatar
Images: 8
To me the key is pulling the deck off several times per year and cleaned out underneath. As long as you don't leave grass packed under there that retains moisture - rust shouldn't be an issue.
JD 318 H3
JD 140 H3
JD 110 RF
CC 124
CC 1250
Farmall H
Ford Mustang (64.5)
Attachments: 2 Brinly plows, Brinly cultivator, 4' Brinly Disc, IH 295 1 row planter, JB Sr, Johnson Loader, JD front 540 PTO, 2 JD 46" Snowblowers, Front blade, Swisher Box Blade, JD 80 Cart.
Past Equipment: JD 316, JD 318, JD 757 Ztrak, IHC 1100A Pickup, CC 3235
Future Wish List: JD X748/X595, CC 782D/982D, MF 12/14/16, Farmall Super C, Farmall AI, Farmall Cub, Case 224/222/446/448
esnb74 is offline
post #13 of 40 Old 08-22-2011, 02:03 PM
Gravely Enthusiast
vr4Legacy's Avatar
A lot of the newer push mowers I looked at had that. A simple hose female hose fitting on top of the deck, you were supposed to hook the hose up and run the mower for a minute or two to clean it. Not sure it is intended for each mowing. I think it's a good concept, just not sure how well the execution would be.
-Jason
1976 Cub Cadet 1200
1973 Gravely CI Walk-behind
vr4Legacy is offline
post #14 of 40 Old 08-22-2011, 03:38 PM
10K and Climbin!
WNYTractorTinkerer's Avatar
Images: 14
Arrow Re: undercoating a mower deck?
The grass under there does a lot more than retain moisture.. It begins a chemical process that produces Nitrogen and other 'deck-unfriendly' chemicals which eat things up faster as well or more than just the moisture. Lots of good ideas shared here for your consideration.. The best thing is mowing when the lawn is dryest as it won't promote the decay or mulching process as much and deck clean-outs when you do help a ton.. I rebuilt a few decks lately and applied rust converter to them in my attempts to retain what metal the decks have left.. Jury's still out on that method though.. Time will tell.. (*I might try the appliance paint if I ever get a newer deck!) Good luck and hope you find something that works!
Can You see the Real me?
WNYTractorTinkerer is offline
post #15 of 40 Old 08-25-2011, 03:52 AM
Mickeymotormount's Avatar
Images: 12
I've used pourable 2 part roof sealer. Turns to rubber when cured. I did my Ford LGT deck about 10 years ago and it's still holding up well. Grass doesn't stick to it very well, and even when it does, the amount is so small that it's not worth scraping off and possibly ruining the rubber coating.
John
Ford and Gravely Nut
Mickeymotormount is offline
