Gravely 16G Professional PTO clutch is stuck - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 28 Old 06-14-2010, 07:41 PM Thread Starter
Help Gravely 16G Professional PTO clutch is stuck
I first have to say , I am by no means any kind of expert when in comes to in depth repair of anything . I can do moderate repairs of machinery but anything involved I feel it is better in the hands of a professional .
Well I hate to be so new and ask for help right out of the gate but I have a 1987 Gravely 16 G professional , Koehler twin 16 horse. I bought it only a couple years old and this mower ran great for the last how many years.
The only issue I have had with it was an issue with the pto not disengaging at times , this was only on and off over the past year.
A month ago I ran the mower ( 2 acres of mowing) and it ran well. Again PTO did not disengage when I was done mowing , thinking that was not uncommon for this mower , I just parked it and that was it.
A week later I tried to turn the mower over and it would not turn over . It was only turning over v-e-r-y slowly.
I took it into a repair shop and they immediately told me it was a big job to fix . They explained to me that my PTO clutch is stuck in and that running it the way I did , and not disengageing the clutch can cause the transmission to almost weld itself to being permanently engaged . To fix it would be too much for them at this time of year. I asked them roughly what would it cost and they said it is 8.5 hours of labor and 400+ in parts, or more or less 1000 to fix, minimum!
Is their any easier of a fix for a stuck PTO clutch?
If not ...
2.How difficult is this job? I have an auto mechanic who is good and was telling me that he slowed down a little over the next day or so and he was willing to work on it .
Is their any step by step manuals or data available to access for me to review that I can give to my mechanic before any disassembly? I heard that taking them apart can be really tricky and disasterous for the inexperienced Gravely repairman.
I am wondering . Is this worth fixing this mower at that cost?
Your thoughts and advice would be greatly appreciated.
Dave
Dvycrocket09 is offline
post #2 of 28 Old 06-14-2010, 09:43 PM
Gravelyyard.com
arcam8123's Avatar
Re: Gravely 16G Professional PTO clutch is stuck
The first things you need to do is make sure it is adjusted properly and the oil level is correct. You can get a manual for it at www.oldgravelys.net
arcam8123 is online now
post #3 of 28 Old 06-14-2010, 10:08 PM
PA RedRider's Avatar
I have a G which exhibits similar symptoms...ie., PTO continues to spin for a few seconds after the PTO lever is positioned to OFF. It will eventually disengage. Have to assume the lever is out of adjustment. After reading your story, think I need to stop putting it off.
Thanks.
Looking for a home for:
- Fan belt for a 6.6/7.6
Looking for:
- Side shields for a rotary cultivator
- QH 40" Commercial deck
- QH Dozer Blade
- Nice original wooden cart
- Direct Mount setup
PA RedRider is online now
post #4 of 28 Old 06-15-2010, 04:08 AM
Mickeymotormount's Avatar
Images: 12
I would definitely adjust the clutch as per the instructions supplied by arcam. If the pto still won't disengage, you may have to get into the transmission to repair it. I would have to say that since this has been a gradual process of the pto not disengaging at times, and finally ending up with it not disengaging at all, that the adjustment should do the trick. Hopefully, the clutch is not worn out as that requires engine removal and trans disassembly to remove/ repair/ replace the pto shaft. Here are some pics of the clutch and transmission. It's not too bad to work on. Just methodical care and follow the instructions found here:
http://www.oldgravelys.net/pdf/Pro_G_Serv_Man.pdf
John
Ford and Gravely Nut
Mickeymotormount is offline
post #5 of 28 Old 06-15-2010, 08:02 AM
Gravely bug bit.
Just be forewarned that even if it has a blue spring on the PTO shaft, you do not want it coming loose. Current red spring ups the rate from medium pressure to heavy pressure. A loose spring can be dangerous.
Current L/C count = 38.
Fla Don is offline
post #6 of 28 Old 06-15-2010, 09:09 AM
yamato72's Avatar
Images: 10
When you replace the PTO clutch, can you buy the whole assembly ready-to-go, or does every repair involve messing with that spring?
I know I will have to replace mine eventually and I have read through the replacement instructions, I don't mind cracking the tranny case but my preference would be to not have to disassemble the PTO itself.
yamato72 is offline
post #7 of 28 Old 06-15-2010, 10:01 AM Thread Starter
I am not sure as to the extent of the issue but I really appreciate the replies and tips.
This mower has been great to own and all I did was oil changes and basic maintenance. I can't believe I have ran it this many years without an issue.
This couldn't happen last fall could it. The problem is, my grass is growing like crazy with all this rain and my neighbor, who is happily lending me his, is probably wondering when I will ever get my mower back.
So I am in the market for a good running PTO 5 -6 ft mounted finish mower till I can the rider back in business.
Anyone in the Erie Pa area that has one they would like to sell drop me a line. I would prefer a 6' rear discharge finish mower.
post #8 of 28 Old 06-15-2010, 01:45 PM
If you disconnect the mower drive, you shouild be able to get the engine running and warmed up. Then you may be able to reconnect the mower drive and restart the engine to try some unsticking remedies. If adjusting or overfilling with oil doesn't un stick it, go to the yahoo gravelyclub and look up message #101290. Harry Ashton made a tool that he used to disengage his stuck pto clutch. He uploaded put pictures of it in the photos section. The pto clutch is somewhat accessible when the engine is removed. Before you remove the engine to use the tool though, you should also search the archives there for other posts regarding stuck pto clutches and consider trying some of the remedies (basically some method of applying a sudden torque to the pto shaft). When I finish mowing and disengage the pto, if it doesn't disengage right away, usually just revving the engine quickly is enough to break it free.
It helps to understand how the clutch works to understand why/how it is stuck engaged and why/how it may be unstuck. The large spring mentioned earlier and shown in the picture puts pressure on two clutch cups to engage when the pto control is "IN". When the pto control is moved "OUT", the large spring is compressed so as not to exert pressure on the clutch cups. That's why proper pto control lever adjustment and ample lubrication are so improtant in freeing a stuck pto clutch.
Good Luck
George
george_lehr is offline
post #9 of 28 Old 06-15-2010, 01:50 PM
yamato72's Avatar
Images: 10
I was sure that I had a stuck clutch last year and it turned out that I had adjusted the lever wrong. Make sure you follow the adjustment instructions to the letter before you split the tranny.
yamato72 is offline
post #10 of 28 Old 06-15-2010, 02:49 PM
Images: 12
Don has a good point. Don't even think about trying to work on the pto unless you have the proper pullers. I found this setup in the Gravely 8000 series service manual on page 29 of the book(page 32 as counted by the computer).
http://www.oldgravelys.net/pdf/8000_...v_Man_0385.pdf
Once I saw that and knew I had the pullers, it was easy. But caution must still be exercised as there is alot of potential energy built up in the spring.
Instead of long bolts, I used high strength all thread and just went through the bearing puller and balancer puller and double nutted everything with double washers. The socket went over the shaft on the small gear end of the pto shaft to give the puller something to push against. Went smooth as silk but it was still done with care. Below is a pic of what I used. Believe me, if you have the knowhow to pull the pto shaft out of the trans, it's not beyond your ability to work on the pto shaft itself. Remember, the right tools make the job--- and make it done safely.
John
post #11 of 28 Old 06-15-2010, 03:28 PM Thread Starter
You guys are awesome.
I can't thank you enough for helping a new guy out.
I take it the 16G is worth fixing. One guy told me I may want to start looking for a new mower.
post #12 of 28 Old 06-15-2010, 03:51 PM
Gravely bug bit.
We have a Smilie for that person.
Fla Don is offline
post #13 of 28 Old 06-15-2010, 04:15 PM
yamato72's Avatar
Images: 10
I just re-read the PTO service instructions and yes, as long as you are careful and methodical, it appears to be a straightforward procedure. How do you know what to order ahead of time? Just the clutch cones? Obviously you should inspect everything for wear once the shaft is out.
And yes, Mr. Crockett, by all means hang on to that machine!
yamato72 is offline
post #14 of 28 Old 06-15-2010, 04:40 PM
Images: 12
Originally Posted by Fla Don View Post
When you put the gear back on the crankshaft, make sure the key and keyways are on the top. As you have the red spring, if you need to do a PTO clutch job, you should only need the cone and cups.
The above quote refers to a post about a 12 G transmission repair showing the red spring on the pto. According to Don, the cone and cups need to be replaced. I would have thought that the cone only needed replacing as long as the cups were good.I think most of the G series came with the red spring.(Don please correct me if I am wrong).
I believe the expense in replacing parts lies in the cost of the cone that has the lining material on it along with the bearing/gear.
John
post #15 of 28 Old 06-15-2010, 04:52 PM
Images: 12
I would say definitely worth fixing. Don't rule out the clutch adjustment as that would be the first and easiest thing to check out.
John
