Trailering tractors and loose ratchet straps ? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 37 Old 05-17-2017, 02:58 AM Thread Starter
4x4Dad's Avatar
I recently trailered my 16G four wheel tractor to cut a friend's yard . When I arrived at my destination ( both ways ) the straps had worked their way loose . I had one strap connected to the hitch and the other through the front axle hole for the PTO shaft . The only difference I can see is , the 2 machines I'm used to hauling have suspensions . A SXS and a motorcycle . The tractor doesn't have a suspension . How do you guys keep them from coming loose when hauling ? Oh , this is an enclosed cargo trailer . So I can't block it against a headboard like I can on a utility trailer .
4x4Dad is online now
post #2 of 37 Old 05-17-2017, 03:55 AM
15,000+ Posts & Climbing
Re: Trailering tractors and loose ratchet straps ?
I use 5/16" or 3/8" chains and binders.
GTs are heavier than motorcycles and do have suspension systems. The tires are air filled at low relative pressures and you want to pull the chains tight enough to make them squat a bit, just like pulling the bike's suspension down with the straps. Because the connecting points are much lower on the tractor than the bike, it takes considerably more pull on the chains to make the tires squat than it does on straps to collapse the suspension on a bike.
What size straps are you using?
TUDOR is offline
post #3 of 37 Old 05-17-2017, 07:02 AM
Richard-tx's Avatar
Images: 7
When hauling tractors I find that after about 2-3 miles the straps almost always have come loose. Retighten and then it is good until unloading.
Code:
                              Current Inventory
                              8183T (Onan B48)
Richard-tx is offline
post #4 of 37 Old 05-17-2017, 07:08 AM
Inveterate Putterer
Mikey4's Avatar
I tow a utility trailer so I can put the front tires into the head rail. Sometimes I actually do that, other times, not.
I use ratchet straps from the front that get anchored to the trailer behind the rear of the tractor, and from the rear of the tractor and anchored ahead of the front. The strains play against each other but still can loosen. Because of that I stop within 10 miles of wherever I start and check the straps for tightness. That allows things to sort of settle in. When I do that the straps are always tight when I get where I'm going.
Challenge Met
Gravely 16G (1994)
Gravely 16G (1991)
Gravely 16G (1986) (For Sale)
Gravely 816S (1976)
Gravely 812 (1975)(mine since 1982)
Mikey4 is offline
post #5 of 37 Old 05-17-2017, 07:39 AM
10,000 +posts!
glenn27's Avatar
Guys-that sounds 'right' about re-checking your bindings...
When I was working F/T and had a CDL, for many years--I moved heavy equipment off/on for the company I retired from. If I remember--with DOT rules--you stop after ten miles(safetly) and re-check the bindings..then every hundred miles there after. Also--after each stop--when you are away from the vehicle. I've had 'stuff' loosen up before--usually rubber-tired equipment that wants to walk over or 'squirm' as we used to say.
To the O/P--much harder to anchor something in an enclosed trailer also. You want to have your straps or chains pulling out and down at about 45 degrees.
Back wards and frontwards--so they are actually pulling against each other. When using any kind of strap-protect it with a cloth of something to keep from rubbing on sharp objects/edges.
Good luck to you on your moves.
glenn
Jimmy Buffett
glenn27 is online now
post #6 of 37 Old 05-17-2017, 08:30 AM
PA RedRider's Avatar
Best practice is to load by backing onto the trailer. This keeps the majority of the weight, ie the transaxle, forward of the trailer axle to prevent fishtailing. I then chock the rear wheels, make sure it is in gear and set the brake. Then secure the transaxle with two sets of rachet straps going in opposite directions to the D rings in the corners. Secure the front of the machine via one rachet strap around the front axle. Retighten after a few miles.
Thanks.
Looking for a home for:
- Fan belt for a 6.6/7.6
Looking for:
- Side shields for a rotary cultivator
- QH 40" Commercial deck
- QH Dozer Blade
- Nice original wooden cart
- Direct Mount setup
PA RedRider is online now
post #7 of 37 Old 05-17-2017, 08:42 AM
Gravely bug bit.
This is the reason why when our trailer was enclosed I had more D rings installed. There are now 8 of them. Front axle gets tied to second set of rings while rear axle gets tied to front set of rings. That is with a tractor loaded front end first. Always cross the straps if possible for best securement.
Current L/C count = 38.
Fla Don is offline
post #8 of 37 Old 05-17-2017, 10:08 AM Thread Starter
4x4Dad's Avatar
Thanks guys ! I believe the part I missed was the stop and retighten . I have the hollow stud with I-bolt running through the floor of the trailer in 4 locations . Although I did notice the tractor kinda moved itself to better line up with the anchor points of the straps . Must of walked when hitting bumps in the road ? I'll have to install the D-Rings and reinforce them under the trailer deck for a better hold for the tractor application . My straps are the 10,000 lbs. variety . That's why I couldn't understand how they worked loose . Ok , better anchors , more pressure and recheck after 10 miles . Got it ! Thanks !
post #9 of 37 Old 05-17-2017, 10:54 AM
I like the idea of getting some wheel straps for the rear wheels, borrowing from some of the hauling accessories available for cars, ATVs and motorcycles. With two sets of D rings in the deck, you could really anchor the rear end.
Thanks.
Looking for:
- QH Dozer Blade
post #10 of 37 Old 05-17-2017, 02:47 PM
I've never had one come loose...I use four straps, pulling four opposite directions. I like straps over chain, the straps can be stretched tight like a rubber band...
Maybe the straps don't have enough tension to start?
Sent from my SAMSUNG-SM-G900A using Tapatalk
steved is offline
post #11 of 37 Old 05-17-2017, 02:53 PM
2 - wheelers have actually given me more trouble in transport than 4-wheelers.
Thanks.
Looking for:
- QH Dozer Blade
post #12 of 37 Old 05-17-2017, 03:36 PM
Did you never notice that rubber bands stretch until they break?
Chains will also stretch until they break, but it takes a lot more effort than for the equivalent size of strap. Look at the length of the strap ratchet tightener compared to the length of handle on a chain binder and tell me which is going to apply more tension for a given amount of effort.
I use straps for lumber that I don't want damaged from the tension. Chains are for machinery that I don't want to move during transit.
TUDOR is offline
post #13 of 37 Old 05-17-2017, 03:47 PM
Deere 332's Avatar
When I haul my tractors to shows I use ratchet straps on my 165 and 212 but I use a combination on ratchet straps and chains on the 332. And all chains on the Farmall.
Current Collection
1987 John Deere 165 Hydro with snow plow, 38" mowing deck and AG tires Restored
1991 John Deere 332 Redland hill 3pt hitch, Carlisle Tru Power AG tires, and V61s, 30 Hydraulic Tiller, Restored
1975 John Deere 212 Electric Lift, Sleeve Hitch, 33 Tiller, Restored
1987 John Deere 160 38" Mowing Deck aka "The Bush Hog"
1988 John Deere 318 aka "Old Smokey"
1957 Farmall 130 Fast Hitch 2 Bottom Plow, 1 Gang Disc, 2 Gang Disc, Sprayer,
Deere 332 is online now
post #14 of 37 Old 05-17-2017, 03:54 PM
TWG1572's Avatar
I also use the "straps pulling against each other" concept pretty successfully, even on rubber tired equipment. It seems like you remove the play from the system that you would have otherwise. I'm also a fan of the drive a few miles and retighten concept. 9 times out of 10, everything is still tight and away I go. But you do catch that 1 time before damage occurs.
TWG1572 is online now
post #15 of 37 Old 05-17-2017, 05:40 PM
I've had more issues with chains popping loose over my few years of trailering stuff than I ever had straps come loose or break. Chains have a purpose, but they are inferior to a strap in most instances.
I'll stick with my straps thank you...haven't had a tractor come loose yet, nor anything I've hauled.
steved is offline
