Rotary plow on a 8199 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 13 Old 04-19-2017, 02:03 PM Thread Starter
WCF
WCF's Avatar
Hello Im trying to get a rotary plow hooked up to the front of my 8199. the problem is with the push bar to lift and lower the unit. Is the lift bar any different than the one I use with my snow cannon? It appears to be too long
Name:	8900F03A-D97B-48FE-9E7F-44068F01F954 - Copy.JPG
ID:	1951849   Click image for larger version
ID:	1951857   Click image for larger version
ID:	1951865   Click image for larger version
WCF is offline
post #2 of 13 Old 04-19-2017, 09:11 PM
Gravely Noob
Re: Rotary plow on a 8199
From what I've read, the 4 inch long sleeve on the rear male end of the push rod needs to be removed, so the female front half will slide on the male half farther. I see the sleeve installed in your first picture.
-Steve
1987 Gravely 8123-G
SteveInPA is offline
post #3 of 13 Old 04-19-2017, 09:15 PM
Gravelyyard.com
arcam8123's Avatar
Yes, the bar you need is shorter.
Ron C
www.gravelyyard.com
www.gravelytractorclub.org
My Equipment: You're kidding, right? Not enough bandwidth on the planet.
arcam8123 is offline
post #4 of 13 Old 04-19-2017, 09:56 PM Thread Starter
WCF
WCF's Avatar
[QUOTE=SteveInPA;10653585]From what I've read, the 4 inch long sleeve on the rear male end of the push rod needs to be removed, so the female front half will slide on the male half farther. I see the sleeve installed in your first picture.[/
Steve, the sleeve on the rear end is welded on. I will take a measurement tomorrow to see if a sleeveless bar will fit. Thanks for the input.
WCF is offline
post #5 of 13 Old 04-19-2017, 09:59 PM Thread Starter
WCF
WCF's Avatar
Attachment 1952881
What should the OAL be? I can't quite see in the picture. I got about 42.5 on mine with the sleeve on it
WCF is offline
post #6 of 13 Old 04-19-2017, 10:00 PM Thread Starter
WCF
WCF's Avatar
Or is it a different front or rear bar I need?
WCF is offline
post #7 of 13 Old 04-19-2017, 11:03 PM
Gravely Noob
[quote=WCF;10653809]
Interesting. In all the attachment manuals I've read, I did not see anything about that sleeve being welded, only pictures showing the sleeve and a washer as spacers for different attachments and tractor frame lengths.
-Steve
1987 Gravely 8123-G
post #8 of 13 Old 04-19-2017, 11:13 PM
Steveamy40342's Avatar
[quote=SteveInPA;10654129]
That pictured lift rod you have is for a snowblower. As you have noticed, it's too long for your needs with a rotary plow and front adapter kit. Let me know if you want the appropriate length rod......
Steve in Frankfort KY
Steveamy40342 is offline
post #9 of 13 Old 04-20-2017, 07:04 AM Thread Starter
WCF
WCF's Avatar
[quote=Steveamy40342;10654201]
PM sent. Thank you
WCF is offline
post #10 of 13 Old 04-20-2017, 01:40 PM
Gravelyyard.com
arcam8123's Avatar
The bar you need is approximately 21.5" from the end to the center line of the round peg. You will still need the 4" sleeve on the lift weldment because of the long frame you have.
Ron C
www.gravelyyard.com
post #11 of 13 Old 04-26-2017, 10:25 AM Thread Starter
WCF
WCF's Avatar
Still looking for the correct lift bar. If any one has one they would like to sell let me know.
Thank you
WCF is offline
post #12 of 13 Old 04-26-2017, 11:07 AM
turtle96's Avatar
Does the sleeve look to be factory welded? Maybe you can grind off the weld and have the sleeve loose as Steve suggested. Just a thought to solve the problem.
Mike
turtle96 is offline
post #13 of 13 Old 04-26-2017, 03:13 PM
Gravely Noob
Not sure if you have a sledge hammer, drill, welder and an angle grinder, but if you do, that push tube does not look too difficult to fabricate pretty quickly.
Use the one you have to measure the material diameter and wall thickness you need, then smash one end of the raw tube with the sledge, drill a hole, put a bolt in the hole and weld it fast, then cut tube to correct length and clean up the smashed end with the grinder.
-Steve
1987 Gravely 8123-G
