Case 480 skip loader for farming? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Construction Equipment A Forum for the Big Boys Toys of All Sizes (Excavators, TLB's, Dump-Trucks, Dozers, Backhoes, etc.)
post #1 of 3 Old 06-26-2009, 10:28 PM Thread Starter
For a guy with a cabin and a little property would a 4wd Case 480 with a 3pt and PTO operate implements like a tiller, brush hog, etc? Would this tractor have a low enough range to do slow moving projects like tilling etc or would it be to cumbersome? I am sure this tractor would have a better lifting capacity and workability than one of the 40-50hp compact tractors wouldn't it? I would appreciate some opinions.
sqdqo is offline
post #2 of 3 Old 06-27-2009, 10:51 PM
jazzyjeff's Avatar
Images: 19
Re: Case 480 skip loader for farming?
What 480 is it ie d, l, ck, that will make a big diffrence as in if it has a pto the tranny etc
Jeff
http://www.zaleskiequipment.com
Bobcat CT440 Cab, Ingersoll 4120
jazzyjeff is offline
post #3 of 3 Old 06-29-2009, 06:25 AM Thread Starter
E model, the unit I am looking at has a PTO, I just don't know its rpm rate. I know the 480 skip tractors are contractor units and the 3 pt system is design to not only lif but will pitch and angle as well. Also it looks like the 3 pt. system hangs fairly low, I don't know if this would creat a ground clearance issue. I would prefer a more robust machine with greater lift capacity than the compact tractors and I cannot afford one of the larger farming type.
sqdqo is offline
