MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information - View Single Post - Replace Thermostat?
Old 12-22-2012, 08:13 PM
Diesel Powered
MTF mile high club member
Diesel Powered's Avatar
Re: Replace Thermostat?
Good deal.
As for bleeding the air out, it'll probably cure itself shortly; the most I'd do is crack the injector lines one at a time. If the tone of the engine doesn't change when you crack one, you likely found the cylinder that needed bled; it should smooth back out when you snug it back down.
2011 JD X748
2004 JD 4410 TLB
Diesel Powered is online now
