L series jerky 3ph, there may be a fix - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 3 Old 08-10-2011, 06:33 PM Thread Starter
Machinery enthusiast
Volfandt's Avatar
The std L series tractors, L2800, L3400, L4400 and the newer L3300 & L3700 have been reported to have jerky 3ph operation. These tractors have position control on the 3ph but many have reported it as being very jerky when raising an implement in increments. Heres a couple examples:
http://www.youtube.com/user/unfinish.../1/jSTJrL6AwYg
http://www.youtube.com/watch?v=AS5VN8McI2Y
Kubota doesn't consider this to be unexceptable and recommends to throttle down and adjust the 3ph drop/raise rate to slow it down. This does smooth it out some but many folks don't like the drop in performance.
Kubota also recommends to step up to the Grand L series (premium tractors) to get the VERY smooth 3ph operation they provide. It should also be noted that the smaller premium B3000, B3030 & B2630 w/position control 3phs are also VERy smooth.
Over the yrs there have been a few posts by various L series owners on other forums that indicate that they either had their valve replaced w/the Grand L's valve or some other action was performed that smoothed their 3ph out but exact details of the "fix" were never really shared, until now.
This is still evolving but it seems that the 3ph valve found on all the std L series tractors w/position control "may" be able to be adjusted to the point where it's operation os VERY smooth, as evidenced by this video:
http://www.youtube.com/watch?v=HLbzc...ature=youtu.be
This owner is posting on another site but was able to question his dealer & mechanic and they are shareing the info w/him.
Unfortunately this is not any easy adjustment as the top of the HST must be removed to gain access to the valve. The valve then needs to be removed to be adjusted, (via shims or springs, not sure at this time) then placed back into the tractor then tested. The owner that posted the above vids and info indicated that his dealer told him they at 1st tried a new valve, which was worse, so they continued to work w/this original valve and that it took many times to get it as smooth in the video.
This is still evolving and I'll update as more info is shared/learned.
One thing, it does appear that this will not be a warranty type adjustment so if you decide to enlist your dealer to try it, make sure you cover costs upfront.
Dave
http://www.mytractorforum.com/showth...highlight=BX23,
1966 Wheel Horse 856, Gear.
1966 Wheel Horse 876, HST.
http://mytractorforum.com/showthread...hlight=856,876
Volfandt is offline
post #2 of 3 Old 08-14-2011, 03:33 PM Thread Starter
Volfandt's Avatar
Re: L series jerky 3ph, there may be a fix
Update. Seems there is atleast one std L series owner that claims a different fix than the above listed valve adjustment and/or replacement of the std valve to a Grand L3010 valve.
There is apparantly a hydraulic line relocation kit made available by Kubota that reportedly also smooths out the 3ph operation.
It is somewhat sketchy as to whether this is the cause to many who experience the jerky 3ph operation but according to one owner, the return line for the power steering is tied into the suction side of the pump which can cause cavitation under heavy usage which inturn causes the 3ph to be jerky. This "kit" reoutes the P/S line back to a new top on the 3ph which eliviates the cavitation on the 3ph & valve. This owner indicates the installation of this kit corrected his jerky 3ph operation and made it smooth.
So to summerize, there appears to be 3 "fixes" available to smooth out the jerky 3ph on some L series tractors:
1) replace the std valve w/the valve from an L3010 Grand L, part # 31351-39604
2) install a new P/S hydraulic line relocation kit.
3) adjust the std valve.
Will update as more info is learned.
Volfandt is offline
post #3 of 3 Old 11-18-2011, 10:30 PM Thread Starter
Volfandt's Avatar
update:
Jeff, (J252 on another forum) has shared his fix for his jerky 3PH operation.
(copied w/permission)
Quick summary:
L3400 with extremely jerky 3PH (violent) with old YR909-00100 PCV. We bought the tractor used this winter, and were quickly and thoroughly disgusted by this fundamental problem. I dismantled and studied the PCV system and made the mods early this spring. Have been using the tractor like this all summer and am very happy with the result.
1. Disassembled the PCV and chamfered the spool control edges by ~200 um. This increased PCV response and reduced the violent jumps from 1" down to less than 1/4".
2. Added an external pressure compensated flow control valve ($~90 + lines and fittings). This reduced the flow to the 3PH system and took the violence out of the 3PH motion. It also reduced the lift speed though this is now adjustable. It did not affect the 3PH lift capacity or the FEL in any way.
I will fill in the blanks, and explain much more thoroughly later as well as show photo's and a part list of the install.
( video)
http://www.youtube.com/watch?v=2LLU2Q0Pvtg
Cheers,
Jeff
-more-
Mini Rant
The closed loop 3PH position control system on this tractor is just plain and simply badly designed. Its not just badly executed, its also fundamentally flawed. The YR909-00100 position control valve is effectively offering only ON-OFF closed loop control in the up direction. The way the spool valve and unloader poppet are designed, it is not really capable of providing much (if any) proportional response - its output flow is really pretty much either on or off.
Now ON-OFF control would be a legitimate (albeit simple) method of closed loop control, provided the system is relatively slow changing (high capacitance). Your home thermostat does a pretty good job with on-off control of holding your room near the set point - it is a nice slow changing system. Our 3PH system are not slow moving; the cylinder is too small or the flow rate is too high (whichever way you want to look at it). ON-OFF is not going to work under those conditions. I have a bit more ranting to do that I'll save for a later post.
I wanted to see what it would take to make the existing system work. Since I couldn't increase the size of the cylinder, I tried a few different ways of reducing the flow into the cylinder thereby slowing its response. Inline restrictions (after the PCV but before the cylinder) did work but introduced some new problems. The pressure compensated flow control valve was the cleanest way to get the job done.
***I'll discuss the YR909-00100 PCV and the mods I made to it in a later post****
For now, what I will say is that for those with YR909-00100 PCV's like mine, I expect just reducing the flow to the 3PH by using the flow control valve will smooth out the motion, but will not get away from the fact that the handle has to be moved 1" before the 3PH hitch responds with its discrete 1" lift. (The reason it is 1" is a result of the PCV spool to housing dimensional relation (either by design or tolerance)). For many that is not a big deal, and can live with it if the hitch is no longer jerking.
Maybe some of later L-series owners can speak to this, but I have heard that those, though still jerky, are better resolution and have smaller (1/4") jumps. In that case, just adding the flow control would be all you'd want to do anyhow.
Installing the pressure compensated flow control valve
To reduce the flow to the three point hitch system, I used a pressure compensated flow controller. This valve works as an adjustable flow divider, which divides the flow between the controlled flow (CF) port (leading to the 3PH system) and the exhaust port (back to sump). The pressure compensating spool inside ensure that the flow rates through the controlled flow port doesnt vary due to load changes. The valve I bought was a 16 GPM unit from my local Princess Auto (Princess Auto Flow Control Valve) though Surplus Center has a nice 8GPM Prince unit that is better sized for the flow rate of the system (Surplus Center - SAE 8 HYD FLOW CONTROL VALVE RD108-8) and probably better quality.
Mounting
I mounted the valve on the underside of the loader control valve. It fits there like its meant to be.
I used two of the 4 existing mounting holes on the loader valve and made a bracket to mount. The location is nicely out of the way, doesnt interfere with anything, and is still accessible (bracket dimensions in mm).
Plumbing
1. I removed the hose from the BY port on loader valve and turned the fitting 90 degree to the outside.
2. With a new hose, the BY (power beyond) on loader valve was routed to Flow control valve inlet (IN).
3. The hose to 3PH (formerly connected to loader BY port) was connected to CF port on flow control valve.
4. EX port on flow control valve gets teed into EX line on loader valve via a new hose and a tee. This flow goes back to tank (sump).
-more-
The pressure compensated flow control valve strives to keep the flow constant out of the CF port regardless of changes in inlet flow. It does so by determining the absolute flow out the CF port using the deltaP across an internal orifice.
Practically I haven't noticed a difference in 3PH speed due to changing RPM. I may try to post a video testing this, though it will be 2 weeks before I'm near the tractor again.
****NOTE"*** Once Jeff add's more I'll post them.
Volfandt is offline
Closed Thread
