Hydro Trans for pulling? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
The Pulling Club Puller Builds and Discussions
post #1 of 28 Old 11-04-2011, 12:08 AM Thread Starter
DieselMower's Avatar
I found a JD 111 for $50 locally that has a lot of potential but has a hydrostatic trans. Has anyone used a hydro for pulling or would you be better off using a gearcase? Also can you upgrade a hydrostatic or mess with it any? Thanks
DieselMower is offline
post #2 of 28 Old 11-04-2011, 10:34 PM
ldunlap's Avatar
Re: Hydro Trans for pulling?
Nobody pulls with hydrostats in my area. I have seen on the internet where some guys in New York were pulling with cub hydros. They had said that you had to know how to work the hydro lever as you are going down the track. Good luck to you, pulling is a lot of fun.
ldunlap is offline
post #3 of 28 Old 11-06-2011, 08:36 PM
big jake's Avatar
I Pull a older Ford 145 hydro but the rear has a hi and low that works good.but it takes more motor to make them work. Jake
big jake is offline
post #4 of 28 Old 11-07-2011, 08:00 PM Thread Starter
Nice puller big jake! Do you have built pics? Did it come factory with shaft drive or belt?
post #5 of 28 Old 11-07-2011, 08:07 PM
larrybl's Avatar
Images: 32
Larrybl here, I can show the drive The LGT 145 has with pictures. It is a shaft drive to the Eaton Hydro Pump.
Name:	Deck Lift Ram.JPG
ID:	181950   Click image for larger version
ID:	181951   Click image for larger version
1990 18.5 Craftsman (RED)
1978 Roper 20T (Old Girl)
[/url]
larrybl is offline
post #6 of 28 Old 11-07-2011, 08:18 PM
big jake's Avatar
Thanks for the help Larry. I didnt take any build pic. Jake
big jake is offline
post #7 of 28 Old 11-07-2011, 09:13 PM
larrybl's Avatar
Images: 32
I like the rims on Poppa Smurf.
http://www.mytractorforum.com/showthread.php?t=699657
[/url]
larrybl is offline
post #8 of 28 Old 11-13-2011, 08:21 PM
junkman1946's Avatar
Rule of thumb for Cub Cadets: It takes 25% of the engines power just to turn the hydro. therefore you put yourself way down on power. I have seen limited success with C.C.s with bigger motors with hydros, but you have to be real good with the control handle.
junkman1946 is offline
post #9 of 28 Old 12-15-2011, 09:40 AM
A quick question I am thinking of getting in the smaller side of pullin my family farm had a smoker series puller untill it got to expensive. anyhow I have an ingersoll 3018 with the onan engine and hydraulic drive I know it is strong enough but what about the hydro is there rules for that type of tranny and can you modify the pumps to be more efficient for the application.
wseternmd is offline
post #10 of 28 Old 01-18-2012, 12:51 AM
still lookin for any comments on my ingersoll idea, if any one care to chime in
post #11 of 28 Old 01-18-2012, 02:55 AM
15,000+ Posts & Climbing
Hydraulic drives are even less efficient at transmitting power than hydrostatic drives. A good hydro is about 80% efficient, but a hydraulic drive with a gear pump and motor has to be in top shape to make 65% efficiency.
You can only increase the relief setting or turn the pump faster to get more power out. You have to have even more power from the engine to do that, though.
TUDOR is offline
post #12 of 28 Old 01-18-2012, 07:18 AM
redmule's Avatar
Lets see if I am understaning this. We have two tractors one is a JD 425 and the other is a case 4020. Because the JD has a hydrostatic drive it can pull or push more than a case with hydraulic drive if both tractors are the same in every other way.
redmule is offline
post #13 of 28 Old 01-18-2012, 08:38 AM
Weaverama's Avatar
Bob stated that a good hydrostatic pump is 80% efficient and a hydraulic drive with a gear pump is 65% efficient. If both tractors are the same in every other way as you stated (tire diameter, gearing, horsepower, rpms etc), one could expect to have more available power to the drive wheels with the hydrostatic driven tractor, hence, it will do more work.
You did mean "the same in every other way" didn't you?
______________________
1966 - 856 Wheel Horse
1976 - 1000 IH Cub Cadet (Sold)
1984 - 682 CCC Red Cub Cadet
1988 - 2072 Super Garden Tractor
1997 - 345 John Deere
1972 - 108 Cub Cadet (Sold)
1978 - 1650 Cub Cadet (Sold)
Weaverama is offline
post #14 of 28 Old 01-18-2012, 09:04 AM
redmule's Avatar
Yes Thank you
redmule is offline
post #15 of 28 Old 01-18-2012, 08:21 PM
Tractor hoarder/collector
searstractorfan's Avatar
Images: 5
Find a gear drive cub...u can buy the hydro tractors to rob parts from...Hydros might work good once or twice...but EVENTUALLY they burn up or wear out....If ur gonna spend the money..might as well build something to somewhat last..
1967 Sears Suburban 10, 1967 Custom 7, 1969 8Xl, (3) 1973 ST/16, (2)1973 SS/16, 1973 ST/10, 1974 SS/16, 1974 ST/16, 1976 ST12, 1977 SS/18, 1977 10/6, 1977 12/6, 1977 14/6, 1978 GT19.9. 1973-75(unknown year) Roper RT16T, 1978 or 79 Roper 18T. Craftsman Mowers: 196? Craftsman 6hp mower, 2 196? craftsman mowers. Various 82 series pullers 1973 IH Cub Low Boy, Cub Cadet 782, IH Cub Cadet 582 Special, IH Cub Cadet 582. 1972 Economy Jim Dandy, 1972 Economy. And an unknown Panzer, theirs more im sure.
searstractorfan is offline
