Troy-Bilt tiller tine assembly removal - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 5 Old 03-19-2011, 11:58 PM Thread Starter
Does anyone out there know of a trick to remove the tine assembly so seals can be replaced, I sure would like to know it. I have been unable to get the tine unit off a Pony, used heat and built a 4 bolt hole plate to use with a steering wheel type puller. The plate was also long enough I could strike it with a hammer to try to twist it loose from the shaft. No luck!! Any Ideas or should I just cry a little and beat my head against the wall and then LOL. Thanks for any help or just moral support.
old1mech is offline
post #2 of 5 Old 03-20-2011, 11:46 AM
I Love All Color Tractors
DJ in WV's Avatar
Images: 6
Re: Troy-Bilt tiller tine assembly removal
There have been a number of threads here about removing tines. The one thing that they all have in common is persistence.
This one might be of some value to you:
Tine Hub Removal
Challenge Met
Looking for a Technical Exchange Article? Here's an Index!
My YouTube Page
My Equipment:
1970 Gravely C10A
1971 Gravely 430
1972 Gravely 816
1973 Gravely Model C8
Eight other Gravely C's, L's, and LI's
1978 Massey Ferguson 1655
1982 Gravely 8123
1983 Troy Bilt Junior
DJ in WV is offline
post #3 of 5 Old 03-20-2011, 02:16 PM Thread Starter
Thanks for the response, I might as well try the 2x4 too. I think this will come up again for me so I am considering building a bottle jack type press with changeable base plates to remove different things,tines,wheels, or whatever comes up. If I build it and it works will post pics. It will take a little time to gather materials and build so it will not happen overnight. Will let everyone know if it does.
old1mech is offline
post #4 of 5 Old 03-20-2011, 02:19 PM
DJ in WV's Avatar
Images: 6
That sounds like it would be a very interesting tool/build. I look forward to seeing what you come with.
Good luck with your tines. Let us know how you make out.
Challenge Met
My YouTube Page
My Equipment:
1970 Gravely C10A
1971 Gravely 430
1972 Gravely 816
1982 Gravely 8123
DJ in WV is offline
post #5 of 5 Old 03-21-2011, 05:12 PM
The 2x4 trick worked for me. A couple good whacks and they were off. I'd advise a good healthy dose of anti seize when you go back together with them. If you happen to have the wheels off I'd put anti-seize on wheel shaft as well.
ehenry is offline
