3pt finnish mower HRM48H and 4118D - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 12 Old 07-17-2009, 07:28 AM Thread Starter
I am new to this form but have been a Case /Ingersoll finatic for many years. I am hoping that someone wil know the answer to this. I have a 4118D tractor and i recently came across a mint 3pt mower deck for it a HRM48H. I have the parts catalog for this deck and it shows the compatability as a 4118D tractor needs a AHRM4H deck. Looking through the catalog the only thing that stands out as a difference between the two decks is that the ARHM4H has a drain back line and the HRM48H does not. Do any of you guys know if this deck will work with a 4118D and why would a drain back line be needed? The HRM48H dech looks like it has a plugged port where the drain back line could be added just dont want to mess uo the Hyd motor on this deck. Thanks for any insight
cobra2266 is offline
post #2 of 12 Old 07-17-2009, 07:39 AM
Banned!
Re: 3pt finnish mower HRM48H and 4118D
The only tractors that used the hydraulically driven decks were the "All Hydraulic" models produced in 1992 and 1993. Therefore, this deck is compatable with your tractor PROVIDING you add a "case drain line" to your tractor's hydraulic system.
The motor on that deck must have the third line connected or you will blow the front seal. Adding a case drain isn't all that difficult. You need a quick coupler female to match up to the male on the deck plus some fittings and a hose. The case drain taps into the return circuit heading to the oil cooler. If you study the drawings in the parts books for the AH tractors, you should be able to figure out where Ingersoll hooked the case drain to. If I recall correctly, the travel/lift valve had an extra port cast into it for this purpose.
Whether your tractor has this port or not is something for you to check out. Other models using the case drain tapped into the downflow side of the oil filter. In other words, the oil leaving the case drain line did NOT pass through the oil filter.
Caseguytoo is offline
post #3 of 12 Old 07-17-2009, 10:54 AM Thread Starter
My tractor has the drain back line but the issue it that the deck that I have the HRM48H does not have the drain line on the hydraulic motor. Do you think the drian should or could be added to this deck. The other deck in the parts manual is a AHRM4H and it has the drain line installed????
post #4 of 12 Old 07-17-2009, 11:05 AM
If the deck motor doesn't require a case drain then you don't need to use one even if your tractor has one.
Bart is offline
post #5 of 12 Old 07-17-2009, 11:16 AM
Banned!
My apologies for not reading your initial post more carefully.
I now realize that you are talking about the rear finishing mower and not the belly mower.
If the drive motor is tapped for the case drain line, then I'd be inclined to install one if all it takes is unscrewing a plug. The parts book shows one motor with that boss but it is not drilled and tapped. The other motor is drilled and tapped and that one has the third line. If the plug does not unscrew, then leave it alone and just go with the two lines.
But here's the other issue.
The motors used for the AH decks are slightly larger internally because of the larger hydraulic pumps used on the AH tractors. This is mostly to do with blade tip speed but it also might have to do with the max rpm that motor was designed to spin at. In other words, if this was my rig, I'd install the case drain line if the motor will take one and make sure that I kept the engine speed to no more than 3/4 throttle. As long as the deck cut grass the way I wanted it to at 3/4 throttle, then that's all that would matter.
post #6 of 12 Old 07-17-2009, 11:17 AM
Banned!
I agree but the issue here is whether the original two line motor failed and someone put a three-line motor on it but chose to plug the third port.
post #7 of 12 Old 07-17-2009, 03:04 PM Thread Starter
The deck that I got is in mint condition, the paint is still there on the bottom of the deck. It could not have been used more than a couple of times. So I do not think that the motor has been replaced.
post #8 of 12 Old 07-17-2009, 03:11 PM Thread Starter
Here is the parts manual for both versions of the decks. I have the HRM48H deck. http://www.rottmansales.com/ingersoll/8-3091.pdf
post #9 of 12 Old 07-17-2009, 05:02 PM
Banned!
If you believe that this mower is pristine, then just go with the two line set up. But keep your engine speed lower as stated earlier.
post #10 of 12 Old 07-17-2009, 05:29 PM
Ingersoll Dealer
bhildret's Avatar
I agree with CG2's assessment on the motor speed. 4118D's are "all hydraulic" and were designed for that line up of implements.
I can't suggest what would or could happen if you run the HRM48H deck at full engine speed ... but I KNOW it will be running over the design rated speed of the mower deck. User beware.
If the motor is already tapped for the drain hose, I recommend using it even if the hose was not previously installed. Will cost you about $25 to add some robustness to that setup.
The documents I have show that later model HRM decks also got the drain hose ... and it is for the simple reason of making the motor more robust against leakage.
Brian
bhildret is offline
post #11 of 12 Old 07-17-2009, 11:54 PM Thread Starter
Thanks for all the feedback I got on this issue!!
post #12 of 12 Old 07-18-2009, 07:32 AM
capehoorn's Avatar
If you have the model number of the drive motor, you could call the manufacturer (of the motor, not Ingersoll) and they will tell you if it requires the case drain line. If it does, then using it like it is without it, you run the risk of blowing a seal. They can also tell you the gpm flow rating on the motor to see if it will handle the output capacity of your tractors pump.
capehoorn is offline
