Pto/clutch Adjustment - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 22 Old 01-25-2009, 06:24 PM Thread Starter
new case dued's Avatar
Is There An Adjustment To The Pto/clutch On The Front Of The 14hp Kolher On My 1984 444. We Recently Got A Bunch Of Snow - I Was Excited To Get Out There And Clear The Neiborhood It Did A Good Job Except The Fact The Snow Caster Would Bog Down And Stop. I Know This Can't Be Normal, My Dad Had A 222 With Snowcaster And It Tossed The Snow Way Better Than Mine In Spite Of Two Less Hp.
Any Suggestions. (another Big Storm On The Way) Will Be Time To Play Soon.
Thanks,
Patrick
new case dued is offline
post #2 of 22 Old 01-25-2009, 06:37 PM
Banned!
Re: Pto/clutch Adjustment
If your Snocaster is bogging down and stopping the engine, then it isn't the fault of the clutch.
If you told me that your engine was running at full throttle but the Snocaster was stopping on you when you waded into the snow, then that would be different. Your clutch would be slipping and in need of an adjustment or new disc.
Keeping every area of your Snocaster painted is important. Rusty augers, rusty housings, rust chutes all slow down the discharge of snow and take hp away from the engine. In wet, heavy snow this problem really shows up.
Augers that have been moved forward to take up stretch and wear in the drive chain also underperform. Put a new chain on and move the auger back to the OEM position.
If your clutch is somewhat hard to push forward and then snaps in as it reaches the end of the lever travel, then it's adjusted just fine.
Caseguytoo is offline
post #3 of 22 Old 01-25-2009, 06:49 PM
Magnum RT's Avatar
Images: 10
Thanks,
Patrick
If the engine is holding speed, but the snow caster auger is stoppong, Then you do have a clutch or belt problem. You will then have to determine which of the two it is. For the clutch, go to the link below:
http://groups.yahoo.com/group/casegardentractors/
go to "Files" and scroll down to:"FAQ's "
Then scroll down to:
"How do I adjust PTO clutch?"
I suggest you study this area, book mark it and maybe join the group.
Rol
Extreme S.W. Michigan
Ingersoll Fan
Green Bay Packers Fan
A lazy mind finds easier solutions!
Magnum RT is offline
post #4 of 22 Old 01-25-2009, 07:23 PM
As Rol said, you have to determine whether the belt is slipping or the clutch. The belt should not slip unless the snowcaster jams with a large stick or the like. Make sure that the belt tension spring is keeping the belt tight--it should take a pretty firm push on the idler lever to release the belt tension.
Bart is offline
post #5 of 22 Old 01-25-2009, 08:39 PM
If your clutch is mechanical as oppossed to solenoid operated, than it needs to be adjusted. Adjustment is made by tightening the lock nut on the end of the engine crankshaft and leaving a a gap of.002"-007" . The tractor manual I have says to measure by using two feeler gauges 180 degrees apart.
Steve
pack rat is offline
post #6 of 22 Old 01-26-2009, 06:59 PM Thread Starter
the engine doen't labor at all but the snow caster will come to a halt if i go any faster than a crawl. belt isn't slipping. so i guess its the clutch that is slipping as i first mentioned. i have seen mentioned here on the forum, of easy adjust clutches? is that what would be on a 1984 ingy 444???
thanks for the replies
patrick
post #7 of 22 Old 01-26-2009, 07:59 PM
Go to the following link and there is a manual describing how to adjust your clutch.
http://f1.grp.yahoofs.com/v1/gE5-Sb5...0manual%20.pdf
Bart is offline
post #8 of 22 Old 01-26-2009, 08:50 PM
Banned!
I wish that both you and Rol would tell people that they have to JOIN the CCI group in order to view any files there.
Not a big deal to do, but informing them of that fact tends to make things simpler and less frustrating.
post #9 of 22 Old 01-26-2009, 11:39 PM
I'm not positive but I don't think you have to join to view the messages and files. Nevertheless they should join for all the fun they would otherwise miss.
Bart is offline
post #10 of 22 Old 01-27-2009, 05:21 AM
eschoendorff's Avatar
"Document Not Found."
The Case Yahoo group isn't hard to join... but you have to wait for approval before you can view files... bummer. Should only take a day or two.
eschoendorff is offline
post #11 of 22 Old 01-27-2009, 06:55 AM
Banned!
Bart,
Non-members can lurk and read the board but that's the extent of it. Photos, Files, Links etc are off-limits. That's the way it is with every Yahoo Group and on some, even the board can't be read.
post #12 of 22 Old 01-27-2009, 07:01 AM
Retired MTF Admin
Ken N Tx's Avatar
Images: 60
Its the same here at MTF...
Due to the spammers out there, New Members have to be validated by an Administrator in order to participate!!
As of 08-12-2006, MTF went to validating and have over 5,000 spammers on record!!
Sorry, now back to the topic...
R.I.P Durwood
Ken N Tx is offline
post #13 of 22 Old 01-27-2009, 09:31 AM
Magnum RT's Avatar
Images: 10
Thank you, Sir! I was not aware of that! I'll try to do better from now on!
Rol
Ingersoll Fan
post #14 of 22 Old 01-27-2009, 04:44 PM
tmd
I have the Service Manual for that Tractor and Clutch. (You did say the EZ Clutch Correct). If you send me your email, I'll send you the section. I have had to mess with mine a few times mostly due to the using the snow caster. I know Rol will get on me about this because he has been trying to help me correct the problem on mine. I have not had a problem with it this year however so I may have FINALLY gotten it correct. You need to follow the instructions to the letter expecially if you have tried to take it apart with out the manual. The spring order (wavy washers) and the clutch gap are critical.
tmd is offline
post #15 of 22 Old 01-27-2009, 06:05 PM Thread Starter
HEY TMD,
THANKS FOR THE RESPONSE. MY EMAIL IS JJOH400801@AOL.COM I WILL TAKE YOUR ADVISE AND FOLLOW INSTRUCTIONS TO THE T. I DID GO IN TO SOME OF THE YAHOO GROUPS BUT COULN'T FIND THE MANUALS THERE.
THANK YOU,
PATRICK
