Case snowcaster/snowblower - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 15 Old 03-14-2010, 08:07 AM Thread Starter
coobie's Avatar
Question Case snowcaster/snowblower
Will a case 48 inch snowcaster/snowblower off a case 226 fit a 1996 ingersoll 4020?
coobie is offline
post #2 of 15 Old 03-14-2010, 08:35 AM
Ingersoll Dealer
bhildret's Avatar
Re: Case snowcaster/snowblower
Yes, and no.
The correct model for a 'RH' tractor (3000 / 4000 series) is the SB38, SB42, or SB48 (width being the only meaningful difference)
Now, that said, there is a conversion kit available for the older model snowblowers. It is admittedly expensive and ends up being a bit of time involved as well.
A good, diligent search for a SB48 is generally the preferred route. Of course, a brand new SB48 could be on your door step in short order ...
Brian
Brian Hildreth
President - Salem Power Equipment, LLC
www.SalemPwr.com
SalemPwr@aol.com
bhildret is offline
post #3 of 15 Old 03-14-2010, 08:39 AM
bgmac's Avatar
I have a used SB48 for sale. PM me for more details
bgmac is offline
post #4 of 15 Old 03-14-2010, 08:42 AM Thread Starter
coobie's Avatar
Thanks for the offer but I am looking at a used one here locally.coobie
coobie is offline
post #5 of 15 Old 03-14-2010, 08:46 AM Thread Starter
coobie's Avatar
Originally Posted by bhildret View Post
Yes, and no.
Brian
Brian,Pm me a price on a new(48 inch) one.I could come and pic it up.It would give me a good excuse to take a day off from work.
coobie is offline
post #6 of 15 Old 03-14-2010, 08:52 AM
bgmac's Avatar
Sure...I also have a brand new P84 "Hi-Cast" (white) that I am selling as well. Both will be listed on Ebay by Thursday.
bgmac is offline
post #7 of 15 Old 03-14-2010, 09:33 AM
Banned!
Coobie,
Before you get rushed to the hospital upon hearing the price for a new blower, I want to make sure that you fully understand the following.
All Case and Ingersoll branded tractors that have 3 digit model numbers (224, 226, 444, 446 etc) use snowcasters that begin with a letter such as H, J, K, L etc, followed by either the number 80 or 84.
Ingersoll branded tractors with 4 digit model numbers such as your 4020 must use snowcasters that begin with the letters SB followed by two numbers that indicate the true cutting width.
So, to answer your original question as to whether a snowcaster off a 226 will fit a 4020, the reply is "Yes it will FIT but it won't work properly."
In order to make the earlier snowcasters work correctly on a 4 digit tractor, you must do one of two options. Either buy the outrageously over-priced conversion kit from Ingersoll ( $650.00, if IIRC) and install it or modify the mule drive on the snowcaster yourself. This is all about getting the early snowcaster to spin in the correct direction since the engine in your 4020 faces the opposite way to the engines in the 3 digit models.
So... if you buy the blower from the 226, you better have the tools and skills to cut off brackets and weld them in a different position. If not, then buy a SB-48.
Caseguytoo is offline
post #8 of 15 Old 03-14-2010, 01:01 PM Thread Starter
coobie's Avatar
Originally Posted by Caseguytoo View Post
Coobie,
Yes I found out how much the new ones are,a little to salty for me thanks,coobie
coobie is offline
post #9 of 15 Old 03-14-2010, 06:45 PM
Level 2's Avatar
If he hooks it up and pours cold water down the chute, will it blow snow out of the front?
Coobie,
Ingersoll 448 Serial 14062821
Ingersoll 4016 Serial 14190385
Ingersoll 4020PS Serial 14184194
I spent my childhood keeping Pop's Case Tractor running, 35 years later I now own 3... GO FIGURE
Level 2 is offline
post #10 of 15 Old 03-15-2010, 08:06 AM
USMC
slkpk's Avatar
Images: 21
My SB42 works great and I have no complaints with it. slkpk
1964 JD RF110 Restored
2007 JD 2305
slkpk is offline
post #11 of 15 Old 02-17-2017, 12:25 PM
will 446 work on 226
evalance is offline
post #12 of 15 Old 02-17-2017, 12:28 PM
So someone is selling a k80-k84 snow thrower he had on his 446, This should work on a 1986 case 226?
evalance is offline
post #13 of 15 Old 02-17-2017, 03:27 PM
Ingersoll Dealer
bhildret's Avatar
Yep ... that will work fine.
Brian
Brian Hildreth
www.SalemPwr.com
SalemPwr@aol.com
bhildret is offline
post #14 of 15 Old 02-17-2017, 06:24 PM
Brian
Thanks i believe he's asking 385 good price? 2 hour drive tho
evalance is offline
post #15 of 15 Old 02-18-2017, 07:33 AM
Ingersoll Dealer
bhildret's Avatar
Yes, $385 is a reasonable price for a good working machine, that is complete with lift bar, chute crank, good bearings, etc.
That's a lot of snowblower for $385 and they might be a bit hard to come by in your area. You've had a lot of snow lately ... that puts the price up.
I'd be more than happy to have private trades settle on a complete snowcaster at $300 most days.
You'll love it once you have it and fixed up a bit.
Brian
Brian Hildreth
www.SalemPwr.com
SalemPwr@aol.com
bhildret is offline
