Vapor Lock Issue - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Power King & Economy Tractors Power King, Power Queen, Jim Dandy Tractor Brands
post #1 of 17 Old 05-12-2012, 07:03 PM Thread Starter
Electrician
ariensman2's Avatar
Vapor Lock Issue
We talked about this in the past but never came to a solution at that time. I have the kohler 14hp in my machine and it appears to run out of gas and stall after about 20 minutes of hard use mowing. It will start right back up if I let it rest for a while and go for another 20 minutes or so depending on the outside temperature. This never happens in the winter plowing snow but that is a much easier task for the tractor. In earlier posts we talked about relocating the exhaust to point away from the machine thinking the heat may be causing a vapor lock. I have done that but it didn't help. It doesn't appear to be overheating and runs very well when cooled down. Does anyone have any ideas how to prevent possible vapor lock or any other ideas what it could be? It has always done this all along even the previous owner told me it did that.
DAVE
06 Massey Ferguson GC2300, FEL, MMM
FHM rear pto wood chipper
FHM rear pto backhoe
Woodland Pwr. Prod. Cyclone Rake Bagger
89 Ariens HT16 Hydro
81 Ariens YT1138 w/Snow Blower
86 Ariens YT1032
79 Ariens YT1132(parts machine)
58 Super SS (Supportive Sweetie)
ECHO Power Tools
ariensman2 is offline
post #2 of 17 Old 05-12-2012, 08:34 PM
Mike 604's Avatar
Re: Vapor Lock Issue
Ck the gas tank cap for proper venting. If that's ok then I would consider an electric fuel pump. I got the idea from Brian Miller's pulling site. I have a similar issue with my Wheel Horse.
http://gardentractorpullingtips.com/carbfuel.htm
1964 Wheel Horse 704 32"RM-324 deck 42" Dozer Blade 40" mid/back grader blade. 8" Garden plow Brinly cultivator
1976 Wheel Horse C-160 Auto Big-Block Kohler! 42 RD deck 42" Dozer Blade 42 "LTD-244 Dump cart
1977 Power King 2414 w/homemade FEL
I love the sound of a Power King idling in the morning
Board certified Tecky Destroyer!
Mike 604 is offline
post #3 of 17 Old 05-13-2012, 04:08 PM Thread Starter
Electrician
ariensman2's Avatar
I think you might be right about the fuel pump. My vent in the cap looks ok and I have an inline fuel filter that I can visually see and its full of gas so fuel supply to the pump is fine. When I disconnect the outlet of the fuel pump it pumps big time but it possibly could be intermittant. I was wondering if I could just gravity feed the carb. I'm not sure why these engines have fuel pumps as the Briggs I have in other tractors are all gravity feed.
DAVE
86 Ariens YT1032
ECHO Power Tools
post #4 of 17 Old 05-13-2012, 04:44 PM
Banned!
Next time it happens check for spark while it's still hot,
could be a bad coil.
Vapor lock can happen,but a lot of stars need to line up for it to happen, and if yours is doing it that often it would be a little out of the norm.
John@Reliable is offline
post #5 of 17 Old 05-13-2012, 04:48 PM
Banned!
Try putting a thicker gasket/spacer between the carb and cylinder. That will insulate the carb.
gravely-power is offline
post #6 of 17 Old 05-13-2012, 08:00 PM Thread Starter
Electrician
ariensman2's Avatar
Yeah it does it every time the engine is using the governor and working as hard as it possibly can and that is only when mowing. It does also sound like it could be spark too because it gives no warning, it just starts to sputter a little and the RPM goes down and down and then it just stops.
DAVE
86 Ariens YT1032
ECHO Power Tools
post #7 of 17 Old 05-15-2012, 11:21 AM
BUDSVTX's Avatar
I agree with John on this one, go after the coil. I have run my 1980 2414 without the fuel pump with out any issues. The tank is a bit higher than the carb, so you can never empty the tank. The 1965 2412 with the L shaped tank was higher than the carb and it didn't have a pump, never had any issues. Learned this the HARD way. Always put a filter between the tank and the pump and another filter between the pump and the carb. On an old pump, it flakes small bits of rubber and not let the float seat and causes flooding.
Coil getting hot will open or it will sputter and loose spark, sounds like it ran out of gas, then open. Let it cool and it starts right up, runs fine. Next time it happens and you are running battery/coil ignition, feel the coil and see how hot it is.
BUD
BUDSVTX is offline
post #8 of 17 Old 05-15-2012, 08:46 PM Thread Starter
Electrician
ariensman2's Avatar
BUD
I will check my coil for heat next time. Still wondering why it only happens when mowing and the governor is always kicked in. The governor never activates when just plowing snow. Would just the air temperature cool it enough. It seems like the temperature around a warmed up engine would always be the same any time of year. I really think the 60" mower is just too much for a 14 hp single cylinder motor. It works it so hard that sometimes I think its going to blow but then it stops and I have to let it rest. Other people have these with no problems. I also just rebuilt all the spindles and greased them up and everything spins freely.
DAVE
86 Ariens YT1032
ECHO Power Tools
post #9 of 17 Old 05-15-2012, 11:07 PM
sep
1971 PowerKing 1614
sep's Avatar
Dave,
I'm wondering if it could be the plug?? I recall reading on one of the sites that there is a standard plug and "heat"plug. If the plug gets too hot, you lose some spark and shuts the engine right down. Once it cools, it is ready to roll again. I had a plug in mine that showed spark but wasn't enough to keep it running. Just a thought and may be a cheap fix.
Steve
"You can't make this ****** up!!"
sep is offline
post #10 of 17 Old 05-16-2012, 03:47 PM Thread Starter
Electrician
ariensman2's Avatar
Originally Posted by sep View Post
Dave,
You've got me thinking now. I used the plug recommended by kohler original equipment so maybe I should just get a new one and see what that does. Is this "heat" plug a cooler range plug for hot running engines or a hotter range plug for cold blooded engines?
DAVE
86 Ariens YT1032
ECHO Power Tools
post #11 of 17 Old 05-16-2012, 10:05 PM
sep
1971 PowerKing 1614
sep's Avatar
not really sure, Dave. check out this thread to see if it helps. I think I have the H10 in mine.
H10 Champion plugs
Steve
sep is offline
post #12 of 17 Old 05-19-2012, 06:51 PM Thread Starter
Electrician
ariensman2's Avatar
H10 Champion plugs
Thanks Steve, I'll read it.
DAVE
86 Ariens YT1032
ECHO Power Tools
post #13 of 17 Old 05-19-2012, 10:08 PM
I agree with the other posts that are pointing to the coil as the culprit. I know you looked at the fuel filter and all looks ok. I just wanted to point out, fwiw, that if a paper filter ever gets water in it, it will never pass fuel well again, if at all. This is just a tidbit of info I have picked up during my 40 years of small engine experience.
There's only two things that excite a man, expensive toys and real expensive toys. -- Red Green
tjhummer is offline
post #14 of 17 Old 05-20-2012, 09:04 AM
cajun66's Avatar
I just fought the same problem in my 2412. Turned out to be the coil.
Matt
197? IH Cub
???? Iseki TU1700
cajun66 is offline
post #15 of 17 Old 05-20-2012, 10:11 AM
Coil on mine too.Started off shuting engine down (what) let sit for a while fire up no proplem till next time it happend.After about the 3rd time installed used coil off a spare engine. Has not missed a lick since.
clintonpower is offline
