Ford TW35 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 9 Old 09-25-2009, 07:37 AM Thread Starter
Ford TW35
I heard you could change a tw 35 pto from a 1000 to 540 or vice versa is there any truth to it? how do you do it? Anything else i need to know if i was buyin a tw35?
farmerboy806 is offline
post #2 of 9 Old 09-29-2009, 11:04 PM
dbear's Avatar
Re: Ford TW35
If the TW pto setup was like our 9600, I think the output shaft comes right out after removing a snap ring. I can remember breaking our pto shaft, although I don't recall just how, and I'm pretty sure my dad swapped out the 540 with a 1000 shaft until the new 540 came in. There might be some other mods needed, but I don't know. Been too long...
dbear is offline
post #3 of 9 Old 10-01-2009, 02:56 AM
BLUEPAINT's Avatar
Re: Ford TW35
Yes shafts are held in place by a snap ring ..easy change...The TW's are fantastic tractors i've had 10's-15's-20's and 25's some of them up in the 10'000hr mark which were very reliable and good performers...Only problems i've ever had are leaky PTO seals , A few powersteering pumps and some issues with blowing o-rings in the valve chest...The engines are beauties and the tranny if an aquired art to shift are as good as any mechanically .
Which cab are you looking at the superQ with the flat roof or the old bubble top..The later super Q's were a little more prone to rusting under the windsheild and in the doors around the window seals and around mirror mounts so look out for fresh paint.
One annoying thing is the huge diameter engine oil filter that costs $30 genuine and is not a common filter for aftermarket to stock..
Generally TW's are ..
BLUEPAINT is offline
post #4 of 9 Old 10-04-2009, 01:22 AM Thread Starter
Re: Ford TW35
thanks for all the info it was really helpful ill pass it on to the people that were wantin to know
post #5 of 9 Old 10-04-2009, 05:39 AM
County Man's Avatar
Re: Ford TW35
I want to do the same on my County. Will I have to drop the oil out? I have heard that you can park some tractors on a steep hill to change the shaft?
County Man
County Man is offline
post #6 of 9 Old 10-04-2009, 12:25 PM
dbear's Avatar
Re: Ford TW35
I'm pretty sure we did NOT drain the oil, and that there was little, if any, loss.
dbear is offline
post #7 of 9 Old 10-05-2009, 11:16 PM
BLUEPAINT's Avatar
Re: Ford TW35
Unless the front is up in the air oil loss is no more than a trickle..!We change them a couple of times a day when busy and usually takes seconds although you get the odd time you have to do some turning to find the right spline..!
post #8 of 9 Old 11-23-2009, 05:51 AM
County Man's Avatar
Re: Ford TW35
Hi. Me again. I can't get the shaft to come out. It moves about 1/8th of an inch with the snap ring in or out.Should I put some pressure on it with a puller? I suspect it may be rusted in the bearing. Any Ideas?
County Man
post #9 of 9 Old 12-05-2009, 05:00 AM
County Man's Avatar
Re: Ford TW35
I finally managed to get it out. I put an adapter on the end of the shaft and made a puller that fitted behind it. Then I used my Port-a power to pull it out. It was tight in the splines so now I can get the 540 shaft.
County Man
