Hello,
I just picked up a Ford 445A and the 3 point hitch isn't operating. The tractor has an aux. valve installed and when you pull the lever on it, you can hear the bypass working. With this in mind, I have hydraulic pressure, but the 3 point hitch does nothing. I am a newbee with this type of setup. So, is this normal? Do I need to remove the valve and reinstall the original plate that the tractor came with from the factory in order to get the 3 point hitch to raise??
Any help would be appreciated!
