Brake Shoe Replacement on 800 Series Ford Tractor
I put together these PDF files on how to do brake and seal replacement on a hundred series tractor after I received some questions from different forum members. I needed to repair a seal leaking on my 850 and decided to document the process, hope it helps.
While this does apply specifically to the hundred series Fords the basics can also be used to repair the late model 8N's with seals in the axle housing and Naa's. The spring connections will differ slightly but the basic process is the same.
