Brake Shoe Replacement on 800 Series Ford Tractor
15K views 5 replies 4 participants last post by  JohnW
#1 · (Edited by Moderator)
I put together these PDF files on how to do brake and seal replacement on a hundred series tractor after I received some questions from different forum members. I needed to repair a seal leaking on my 850 and decided to document the process, hope it helps.
While this does apply specifically to the hundred series Fords the basics can also be used to repair the late model 8N's with seals in the axle housing and Naa's. The spring connections will differ slightly but the basic process is the same.
  • Like
Reactions: SMarlin
#4 ·
Moderator DJ said he would add it to add it to the stickies a few weeks ago. I also sent him a parts manual pdf for the 850 to be added to the manuals section.
#6 ·
:thThumbsU Gotta give you part of the credit, that is what prompted me to put this together. That plus the leaking seal got me off my rump and do my brakes that were in need and it was just in time to prevent damaging the drums.
