1968 4500 tractor/backhoe engine problem - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 14 Old 10-25-2012, 12:00 AM Thread Starter
I've had this old hoe now for about 10 years, served me well, never any trouble.the other day noticed some steam while idling,sure enough there was oil leaking at the front of the head ,shut it off checked oil, pan full with coolant and oil.Having to many projects on the go and not being familiar with diesel's I hired a tractor mechanic,he pulled it apart, the head had to be machined 60 thou,put it back together, fired it up and there is still water getting into the oil.It's not leaking at the head gasket now so the issues in the block,i guess the next thing is to pull the pan and pressure test it and see where it's leaking.
Talking to people I've been getting different stories,the mechanic that did the work so far says my engine would have to come out and be decked also' i never saw what the deck looking like, also he's been told these 201 cid 3 cyl blocks are notorious for bad castings and they have a hard time getting them to seal and on and on . he says he can get me a running one for $1800,seams a lot .Myself I would rather spend the money and have my engine rebuilt. Looking for some advice from someone that is familiar with these engines. Thanks Joe
copojo is offline
post #2 of 14 Old 10-25-2012, 01:39 AM
Not a restorer
Ecnerwal's Avatar
Images: 8
Re: 1968 4500 tractor/backhoe engine problem
Nice looking 4500 - certainly nicer than either of mine.
The trouble with hiring help is you're never quite sure what you're hiring until it's too late...
I don't know anything about this from direct experience, but I think it is not uncommon to need to sleeve the cylinders due to perforation - hopefully someone with more experience will chime in. If that's the case, decking the top surface of the engine won't do a bit of good, as far as I understand it.
Ford 4500 diesel TLB (740/753)
Ford 4500 gas 740 Loader/3-point (no pto)
Ecnerwal is offline
post #3 of 14 Old 10-25-2012, 03:01 PM
Joe, The 201 is a good engine and it is not likely that the deck needs to be resurfaced as that is fairly uncommon problem.
1-Was the head checked for cracks when it was surfaced?
2-Were the freeze plugs checked on top of the head for any problems?
3-Did the mechanic see where the water was coming from?
4-Does the water drain into the pan when the engine is off? (Check by filling cooling system with water and drain all oil. Watch for water coming out of oil drain. May have to pressurize the cooling system and/or turn the engine over by hand to move pistons)
Before getting too worried, those questions need to be answered. There could be a pin-hole in the cylinder wall and that can be answered by #4 above. This is common to ALL diesels, but at various degrees. (other diesels have corrosion in liners and liner seals). Ford blocks do have a problem, but more so with later blocks as they took some of the metal out of the blocks. A rebuild by boring the cylinders and installing sleeves will fix the problem.
At any case, when the current problem is solved, you should add New Holland FW15 coolant conditioner, $7.00/bottle to prevent cylinder cavitation in the future.
Ask the mechanic if he knows how old the engine/tractor is and ask him if you got your money's worth!
Tractortech is offline
post #4 of 14 Old 10-25-2012, 11:21 PM Thread Starter
Thanks for the replies,to answer the questions
1- I was told the head was magged for cracks and tested OK.
2- can,t say the freeze plugs were checked,I would assume they would be.
3- No I don't believe he did,I think he saw where the head-gasket was leaking oil and the oil pan being full to the brim with coolant and oil and assumed that the problem was the head-gasket.
4- Yes ,that was easy,I drained the soup out of the pan , poured some water into th rad and sure enough ,out the pan drain she comes.
I got to say in hindsight I should of come here first and asked a few questions before just going out and hiring a mechanic.winters coming and I've got work to get done . any more advice would certainly be appreciated. Joe
copojo is offline
post #5 of 14 Old 10-26-2012, 08:25 PM
I would also assume that the freeze plugs were checked, but....
You should remove the rocker cover and see if the plugs on top of the head aren't the culprit.
Doesn't explain the oil and steam, but it sounds like your head was warped. If so, then it must have overheated at some point which will stress old freeze plugs.
post #6 of 14 Old 06-17-2013, 01:23 AM Thread Starter
Hi to everyone out there,I finally got back on the tractor project, pulled the pan,saw where it appeared to be leaking,broke her apart and pulled the motor. It's on the engine stand now,pulled the head,rolled it over and I got some pictures of the problem area. There is a small hole ,perfectly round about the size of a 3/32 bit. I'll try to describe exactly where the pinhole is.looking down from the deck into the water jacket and putting a light underneath the engine at the hole I can see the hole is just to the side of the cast cylinder. I stuck a pick in the hole and there is a small void behind the hole but doesn't seem to be to big , I'm thinking maybe I could drill and tap it for say a small 1/8 plug? It's hard to get at but doable,I would have to get a bit and weld about a five inch extension on it and the same with the tap.
I'm a electrician and I have a welding ticket,I'm not a diesel mechanic but I've welded lots of cast ,i don't want to make this into a big project. I would like to fix the hole without welding ,ring and bearing it ,maybe the front and back seals and put it back together. I'm sure there are some guys out there that have seen this before, looking forward to your valued opinions on the best way to fix this without tearing the motor down.Also I will post pics and maybe down the road this thread will help someone else. Jo
ID:	339570   Click image for larger version
ID:	339578   Click image for larger version
ID:	339586   Click image for larger version
copojo is offline
post #7 of 14 Old 06-17-2013, 04:39 PM
that looks to be in a place that you can just drill tap an put a screw with lock tight in
lay the head gasket on to see if you can do it
john
no2498 is offline
post #8 of 14 Old 06-17-2013, 09:27 PM Thread Starter
Just to be clear the pictures shown of the pinhole in the block [casting flaw] are taken from the bottom side of the block looking up towards the bottom of the cylinders. jo
copojo is offline
post #9 of 14 Old 06-17-2013, 09:42 PM
Yeah looks like you can drill and tap and locktite a setscrew into it. Don't go real big.
davo727 is offline
post #10 of 14 Old 01-01-2014, 03:01 AM Thread Starter
Thought I would update this thread. I seem to have fixed the problem with my block leaking internally. I took a self tapping screw ,I'd say Number six,screwed it in with some locktight on it and topped it off with some JB weld just for a little extra insurance . seems to have worked. Since the motor was out and on the engine stand thought we may as well ring and bearing it, crank was in nice shape,cylinders didn't have much of a ridge.Motor had never been apart,obviously the oil had been changed regularly,the hour meter reads forty one hundred hours. Picked up new pistons with the rings installed ,bearings and a complete gasket set from Ag Kits for under five hundred dollars delivered.was just going to get the rings but with pistons was only about one hundred and fifty dollars more. I'm attaching a few pics. jo
ID:	620226   Click image for larger version
ID:	620234   Click image for larger version
ID:	620242   Click image for larger version
copojo is offline
post #11 of 14 Old 01-01-2014, 11:58 AM
Nouveau Redneck's Avatar
So it's all back together and running now? That's great news. Were the engine and the inside of the front bolster always blue?
Nouveau Redneck
Sean in PA
2008 John Deere X500
2015 John Deere X530
Nouveau Redneck is offline
post #12 of 14 Old 01-01-2014, 02:15 PM Thread Starter
Yes, seemed like a huge job at the start,but I had bought all the manuals ,five in total ten years ago from the ford dealer for a very good price,i suppose the just wanted to get rid of them. Well it showed in there how to break it apart and I just did it one step at time,actually they are quite easy break apart, like anything once you have done it ,it seems easy.I couldn't afford to hire someone to do the whole job,once I had the motor out i took it to a fellow who works on heavy equipment in the field,after a little discussion we decided on how to fix the leak,I looked after that and he suggested we through some rings and bearings in it while we had it opened up. instead of wasting time cleaning the pistons up we bought new pistons with the rings installed,he slapped it back together,I put it in,he came over and helped me fire it up. I learnt a lot on this project and it was very satisfying to see it run better than ever.the only thing I forgot was to put a block heater in it.I'm sixty years old and still learning, to answer you question the engine,trans and diff were blue along with the bolster . When I bought it I had my buddy sandblast it and paint it with what we had and that was Cat Yellow,originally it was painted that pale yellow the ford used with the blue chassis like the ag tractors.
ID:	620490   Click image for larger version
ID:	620498   Click image for larger version
ID:	620506   Click image for larger version
copojo is offline
post #13 of 14 Old 01-01-2014, 04:57 PM
Very nice! Thanks for the update and pics. Happy for you. I have a 68 4500
davo727 is offline
post #14 of 14 Old 01-05-2014, 11:54 AM
All through the 1970's and early 80's Ford were the market leader in farm tractors here in the UK, but they had this 'porous block' problem with their casting process which they never really solved until the 40 series in early 90's, people got fed up and changed to JD, and JD are still no1 in sales here ahead of CNH and MF. Some blocks lasted many years and some only a short time, 4-cylinders seemed to be worse than 3's or 6's, the usual cure is just a new block although they can be bored/sleeved.
Glad you've got your engine fixed, if it does develop another leak (sorry to sound pessimistic!) at least you'll now know what to do...
blackbob is offline
