Ford 5610 Injector Pump Leaking - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 4 Old 03-30-2012, 02:17 AM Thread Starter
I have a 5610 Ford and the injector pump is leaking fuel when the tractor is just sitting. The fuel is seeping up out of the shut off lever shaft and drips off the pump housing. My questions are as follows:
Is it possible to remove the control cover off the top of the injector pump without removing the injector pump from the tractor?
Can the seals on the shut off & throttle lever shafts be replaced without having to make adjustments internally to the injector pump?
Has anyone here attempted a repair like this before? If so I would appreciate any tips one might have.
Thanks!
ajwgator is offline
post #2 of 4 Old 03-30-2012, 08:38 AM
Re: Ford 5610 Injector Pump Leaking
If your 5610 has a CAV inj pump this will help. As you raise cover there is a spring that must be unhooked. When reattaching spring be sure to attach it in "exactly the same hole".
Tx Jim is offline
post #3 of 4 Old 03-30-2012, 11:41 PM Thread Starter
Thanks Tx Jim for the reply and the attached image. Yes the pump is a CAV and I assume the spring you are refering to is the governor spring that attaches to the throttle shaft (77). Looking closely at the image it looks as though the cover is only held down with two nuts about in the middle of it. I attempt this repair this weekend and keep a close watch on where the spring is attached before disconnecting it. Thanks again!
ajwgator is offline
post #4 of 4 Old 04-18-2012, 12:02 PM Thread Starter
Tx Jim or anyone, do you know where one can obtain the o-rings and top gasket for the CAV pumps without having to purchase a complete rebuild kit for the them? I've not been able to locate any parts here in town. Thanks.
ajwgator is offline
