Alternator isues TN55 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 22 Old 01-04-2012, 06:38 PM Thread Starter
Greetings all, I have a 2000 TN55 New Holland that I have just changed out the alternator and regulator, I know new oines can be bad too but maybe I have overlooked something? I will try and keep this as short as I can. Like I said new alt all is hooked up right, but I have no volts, (FYI) the charging light don't work and the starter relay don't either ( I bypassed the starter relay) ??? could the starter relay ,the lack of dash power to guages,and warning lights have any thing to do with it ? The alt. didn't work when I bought it. Thanks, David
AERDAVID is offline
post #2 of 22 Old 01-04-2012, 07:37 PM
Re: Alternator isues TN55
I am not familiar with a TN55 But the charge light is a key circuit in turning on the regulator. And if the starter sol is inop there may be several dead wires, safety switches, relays and or fuses involved.
Get a wiring diagram and a multi meter.
DS
Down South is offline
post #3 of 22 Old 01-05-2012, 06:08 AM
1981 Ford 1100 4WD
donimbimbo's Avatar
The replacements came from New Holland? Or did you get them somewhere else and had to do some wiring to make them fit?
Alternators require an "exciter" voltage before they will generate. If it's an external regulator, then the exciter voltage comes from the regulator.
Sure sounds like something is hooked up wrong.
Ford Mustang 1990
Ford 1100 Tractor 4WD 1981
Ford LGT14H Tractor 1988
Subaru Forester 2014 (Wife's car)
Honda 1100 Shadow Sabre 2000 (being restored)
donimbimbo is offline
post #4 of 22 Old 01-05-2012, 09:38 AM
David:
Sounds like you do NOT have any power to your ignition key switch. Before you go any further, you need to get power to that. That switch provides power to your alternator to "turn it on" and also to operate you starter solenoid.
I have had problems in the past with bad ground connections from battery to frame as well as bad connections at positive from battery to starter. I'd check those two items, first.
you may email me at: cyrus47@hotmail.com
if this is not enough information. I don't have any tractors that new to reference, but New Holland does have good references on line. Besides, most alternators are fairly simple, once you figure out what is going on. Took me years to give up on generators. Now, I wouldn't have anything else but an alternator.
Cyrus
cyrus is offline
post #5 of 22 Old 01-05-2012, 09:40 PM Thread Starter
The new alt. and regulator came from Messicks and I am sure of the install. I don't have any fire at the warning light which means I dont have any "exciting" going on I just don't know why. I had checked the ground but didnt check the + at the starter,I will but it starts fine. Is there a obvious ground for the instrument panel? The ignition sw is hooked up correctly. I traced the red light wire from the inst. panel the the alt. I guess the power I am missing comes from the panel somehow when the swich is turned?. Thanks guys keep em comming please. David
AERDAVID is offline
post #6 of 22 Old 01-06-2012, 10:29 AM
David:
That tends to indicate the positive side is fine. You mentioned the ignition switch is hooked up correctly. I am going to assume that you checked that. I have had cases where the connections on the back came off. Earlier though, you mentioned having to jump the starter because the switch didn't work it. Now you say the starter works fine. Which is it? Right now, it sounds as though the power is not getting from the starter solenoid connection(where the power comes directly from the battery)to the ignition switch. Check the small wire attached to that connection. It feeds power to the ignition switch. If you have no power from that point to the ignition switch that could be your whole problem. C
cyrus is offline
post #7 of 22 Old 01-06-2012, 12:13 PM Thread Starter
I don't think I said I had to jump the starter, I did have to jump the (starter relay) located in side the dash next to the flasher. I connected the two soleniod wires together sending 12v to the starter when the key is switched to the full start position. it had power from the switch but wouldn't come through the relay from the key switch to the starter solenoid. The ign switch has all wires (colors) to the correct tabs and the switch operates fine (its pretty new too). Thanks
AERDAVID is offline
post #8 of 22 Old 01-07-2012, 03:19 AM
H-D
Aged parent's TC 29 had problems with the neutral safety switch which caused the same symptom. The 3 speed range selector has 2 neutral positions & we just went to using the alternative one, waiting for total failure before fighting with all the busyness associated with the switch. Best I recall, the neutral switch provides a ground to the low-amp side of the starter relay (not solenoid) which is located under the plastic clam shell covers below the steering column. You might try working the range selector back & forth through all positions while holding the ign. switch in 'start' to check for bent/badly adjusted linkage. HTH!
H-D is offline
post #9 of 22 Old 01-07-2012, 09:16 AM
The solenoid on most newer tractors is on the starter. I also question your replacing the voltage regulator, as it should probably be inside the alternator instead of a separate item.
The neutral safety switch would not keep the alternator from charging once the tractor is started.
I did have a '95 or so NH 3010 with alternator charging problems. I suspected overheated wires and wired around the problem area on that one.
Do you have an owner's manual? If so, does it mention any fuses that might be in the charging circuit? Massey Ferguson used to put fuses in their system, unlike most other brands.
Let's confirm some other voltage points:
take your voltage test light and check for 12 volts at the big wire at the alternator. It should be hot at all times.
cyrus is offline
post #10 of 22 Old 01-07-2012, 09:32 AM
Here's a source for a repair manual from NH, but it is $60 to download. I'm still checking for free info.....
0 items Login / Sign up
Shop all Departments Documents / eBooks
Start Affiliates Support
Dealernation Documents / eBooks Shop
Home Catalog ManualsVehicles (other)TractorNew HollandPage 4File Information
New Holland TN55 TN65 TN70 TN75 Tractor Workshop Service Repair Manual
Price: 59.95 USD
DOWNLOAD
NOW
Add to cart
Instant Download from dealernation, digital version
Size: 17.1052 MB Platform: Win
File Data:
Contact Seller: dealernation, USA, Member since 11/01/2007
URL: Tweet this
Embed: Widgets for your homepage
Description:
(ID 9201092)
This is the New Holland TN55 TN65 TN70 TN75 Tractor Workshop Service Repair Manual for New Holland Agricultural Farm tractors. This is just like the original factory paper manual made for these New Holland farm tractors; the only difference is its not paper, and doesnt need to be shipped!
Like the paper manual, it has many sections that are neatly organized in Adobe Acrobat, very clean, sharp images that are scalable to several times normal size. There are tons of diagrams, schematics, illustrations, specifications, pictures, step-by-step instructions, special tool info etc.
Service Repair Work Shop Manual 870-Pages, 14-Sections
This service manual covers model TN55 TN65 TN70 TN75 New Holland AG & farm tractors built from 9/1999 through 12/2003. Including diesel 3 cylinder engines. Attachments such as loaders and backhoes are beyond the scope of this repair service shop manual. Coverage of individual model names listed below.
TN55
TN65
TN70
TN75
Zoom it, print it, save it, close it. Print a few pages at a time, as you need; no need to lug that bulky binder around anymore! No need to worry about stained, torn or missing pages. Each section is indexed for fast & easy referencing. Each section covers a different area of the machine:
Section Index:
GENERAL INFORMATION
ENGINE
CLUTCH
TRANSMISSIONS
DRIVE LINES
FRONT AXLE
MECHANICAL TRANSMISSION
REAR MECHANICAL TRANSMISSION
MECHANICAL POWER TAKE OFF PTO
BRAKING SYSTEM
HYDRAULIC SYSTEM
STEERING
AXLES AND WHEELS
ELECTRICAL SYSTEM
PLATFORM, CAB, BODYWORK
Once you buy the manual, you will get a link in your email, then just go view it, print it, and save it for use later on. This has every page that is in the paper service manual. Viewed in popular Adobe PDF format, which most computers have already. To download the latest free viewer, go to www.adobe.com/reader
About Ford New Holland
New Holland started with one corn mill in the state of Pennsylvania, first built in 1895. The company then expanded into farm implements and later found success with automatic hay balers. New Holland was acquired by Ford Tractor Operations in 1985, and the Ford New Holland name began to appear on tractors. In 1990 Ford sold a majority interest in its farm machinery operations to a foreign company called FIAT, with the agreement that the Ford name be dropped in ten years.
Tractors began to be released under two names: New Holland in traditional Ford tractor markets, and FIAT in their traditional markets. In 1999, Case IH and FIAT New Holland merged to form CNH Global (Case New Holland) which continutes to built tractors under the New Holland brand.
New Holland produces both Agricultural farm equipment, and Heavy construction equipment like backhoe, skid steer loader, excavator, mini excavator, and wheel loader. The tractor models included in this service workshop repair manual are TN55 TN65 TN70 TN75.
Searches:
"TN70" & "Manual" & "Clutch"
tn 55 ford
online new holland tn65 repair manual
User tags: new holland manual, tn65, tn75, service manual
Votes:
(based on 1 reviews)
Reviews:
Perfect
Now I can fix my Tractor. Perfect!!
cyrus is offline
post #11 of 22 Old 01-07-2012, 10:16 AM
Knowing what alternator and regulator would make it easier for us to guess.
Did you have your old stuff checked to see if it was Bad?
DS
post #12 of 22 Old 01-07-2012, 11:05 AM Thread Starter
H-D, I will check that. Cyrus the voltage regulator is in the alt. but thee is a smaller relay size 2 pin (tab type) bolted on the alternator bracket that NH calls a voltage regulator, (fisst I have seen) anyway I replaced it first because one of the tabs was rusted off and inside the connector. No owners manual and I do have 12v at the alt heavy cable at all times, the v is only comming from the battery. I did download and pay for the repair manual it is not really user friendly as far as real trouible shooting, it's more for the trained NH shop guy. It shows values and such and has been some help with volt and olhm testing only, the schem sections should have stayed in a book, (imho)(hard to see) Down South the alternator is a RTT119AC Magneti type (very typical with an internal voltage regulator and an external voltage regulator circut. It is the type that the rotor needs energized from the warning light circut inorder to start charging. Outside it looks like any Delco remy on a chevy ect, by the way its a 45 amp. No auto parts store would do a bench test for me claiming they didn't have the output specs for that alternator (bs) I figured it to be bad from past experience tests (everything else was "ok". belt tight wires, batt, ground, ect. If this helps the only thing on the dash that works is the pto indicator light (which is allways on) and the signal light indicators. Thanks, David
AERDAVID is offline
post #13 of 22 Old 01-07-2012, 11:16 AM Thread Starter
By the way I really do thank you all the extra efford you are giving and hope I can return the favor some day (but hope you don't need it), David
AERDAVID is offline
post #14 of 22 Old 01-07-2012, 11:34 AM
Its odious you have some wiring, switch,fuse relay issues But.
With your numbers this is all i have found.
http://cn.oemol.com/oem/en_oem_detai...Regulator.html
The regulator, one or both of the plug in need 12v. guessing
The voltage stabilizer ?
http://anklauto.en.alibaba.com/produ...tabilizer.html
References to 633-200 and 633-210 as the alternator. Then nipondenso 101210-016 and Opel 130 amp
http://www.rmlunits.com/Vauxhall_Ope...nator/100-466/
But all that means is some of the same parts inside
One solution is to convert to a delco 10si but you need to deal with the wiring as well.
Got any small alternator generator shops in the area?
DS
post #15 of 22 Old 01-07-2012, 03:12 PM Thread Starter
Ok, from what youall have said and what I have found I think it may be gearbox,pto switch somewhere since I can jump the starter relay and get Ign but no alternator to kick in I have disconnected the range gear and transmission safety switches each and don't get olhms in or out of gear ! How do they work? Can they both be bad? does anyone know for the circut to work should they be closed? I think I'm getting closter.
AERDAVID is offline
