Ford 600 Tractor - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 10 Old 04-30-2011, 04:35 PM Thread Starter
Help Ford 600 Tractor
We have a 600 Ford tractor and my husband would like to know if anyone can tell him how you check to see if your hydraulic oil is correct and how much hydraulic oil it takes.
We know there are three reservoirs and they go from one to the other. Also if you are sitting on the seat on the left hand side is what appears to be a dipstick, is this where you check and if so where should it be?
My name is Lynne and I am in Ontario, Canada.
cjfinn is offline
post #2 of 10 Old 04-30-2011, 05:05 PM
Imagine it. Build it.
tiretrx's Avatar
Images: 8
Re: Ford 600 Tractor
Hi Lynne, welcome to MTF. Plenty of knowledgeable Ford folks here. I'm sure help will be on the way before too long Good luck with your 600.
.....just call me Ellis
I was abandoned as an infant and raised by a family of opposums........does that explain things?
tiretrx is online now
post #3 of 10 Old 04-30-2011, 06:10 PM
souNdguy's Avatar
the sumps are seperate and in fact DO NOT go from one to the other.
trans, fill by shifter, drain underneath.. level check is a PLUG on the right side just above the running board, near your right foot.. but on trans.. not on center setion. don't remove any bolts fromthe side of the trans.. just that plug.
hyds, fill under left front of seat under left thigh.. drain underneath.. hyd dipstick on left side by pto shifter.
diffy fill behid seat, right side aft of your right but cheek kinda..
drain underneath diffy.. is a plug.. other two are large bungs.
level check is a plug on the back of the left axle trumpet mid way up.. near the flange where the trumpet bolts to the center housing.
gear oil in the trans and diffy, utf in the hyds.. or utf in all 3. utf meeting m2c134d ford spec reccomended. trans type will change the amount of oil.. but if going utf in all.. get a 5g pail.. otherwise, a 2g pail of utf, and 4g of gear oil.
soundguy
souNdguy is offline
post #4 of 10 Old 04-30-2011, 07:51 PM Thread Starter
Thanks Soundguy. Have printed out for my husband to check out tomorrow.
Lynne
cjfinn is offline
post #5 of 10 Old 04-30-2011, 11:04 PM
Mike X485's Avatar
Images: 8
Lynne, Welcome to the forum.
JOHN DEERE X748
Mike X485 is online now
post #6 of 10 Old 05-01-2011, 03:46 PM
kdmoser's Avatar
Hi Lynne, Welcome aboard. Always great to have another 600 series owner posting.
BTW, UTF is Universal Transmission Fluid. Available at Tractor Supply, Walmart and many auto stores.
Kurt-NEPA
kdmoser is offline
post #7 of 10 Old 05-01-2011, 03:59 PM Thread Starter
Just a short note to say thank you. Your advise helped greatly. He has it figured out now.
Again thanks.
Lynne
cjfinn is offline
post #8 of 10 Old 05-03-2011, 09:46 PM
souNdguy's Avatar
post back if you got any more questions.
I love the 00/01 series.. the 55-64 fords are my favorite
soundguy
souNdguy is offline
post #9 of 10 Old 05-04-2011, 08:40 AM
Paul J's Avatar
The Ford 600 tractors, along with some other models have a seal between the front, (transmission) and rear (hydraulic) sections of the housing. Unless the unit has been rebuilt within the past couple of years and that seal replaced, the chance of cross over contamination is possible. I'd drain all the oil out of both and refresh with hydraulic oil in both compartments. The worn seal will allow the trans oil to pass through and contaminate the hydraulic fluid. The proper hyd. fluid in both compartments will eliminate that situation and with the modern formulas, the transmission will be properly lubricated. Unless you replace that seal yourself, a lot of work, a shops fee will be very expensive due to work and time involved. JMHO. PJ
REMEMBER & NEVER FORGET
We all live in the land of the free
BECAUSE OF THE BRAVE!
Paul J is offline
post #10 of 10 Old 05-04-2011, 11:36 AM
souNdguy's Avatar
that seal is between the hyd section and the diffy.. not the trans and the hyd.
soundguy
souNdguy is offline
