Ford 4500 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 31 Old 09-13-2010, 06:31 PM Thread Starter
Ford 4500
Hi all... Sorry about two posts... but One was about a wain roy backhoe (sorry but i never heard of this) and this one is a bout a ford 4500.
I love FORDS I am a ford fan through and through tractors cars and trucks.
So here we go... I talked to a guy selling this one, ford 4500 industrial tractor with 4 spd forward and 4 speed reverse tranny, all working ok.
No leaks and he said everything is working good.
Questions for you guys:
1. If the brakes need to be replaced is that a simple drum brake job and can you get parts?
2. What should I be paying for this thing if it is in good shape - no leaks etc..
here is the listing
thanks, I am looking at it tomorrow night!
http://newjersey.craigslist.org/grd/1925517910.html
Kenny
Mercury is offline
post #2 of 31 Old 09-14-2010, 10:34 AM
Nouveau Redneck's Avatar
Re: Ford 4500
The brakes are wet brakes inside the axle housing. The rear differential and axle housing is also the hydraulic reservoir. You would need to drain all of the fluid and then pull the wheels off and then remove the outer housings (trumpets) for each side's axle from the center housing to get to the brakes. The brakes are actually a multi-pack disc assembly, similar to a motorcycle clutch.
Most parts are still available. Check out the New Holland On-Line parts catalog here. Type in 4500 as the model and click Search, and then click the plus sign next to the first selection "4500 3 cylinder Industrial Tractor" to expand the list, and then click on brakes, and then finally on "Brakes & Brake Controls".
Nouveau Redneck
Sean in PA
2008 John Deere X500
2015 John Deere X530
Nouveau Redneck is offline
post #3 of 31 Old 09-14-2010, 10:51 AM Thread Starter
Re: Ford 4500
Thanks bud!
I do not know how the brakes are on it now but its one thing i will check.
I look at the 4500 tonight and the wain roy in the AM... this reminds me i need to call somebody and ask about a ford 4000 AG tractor.
Whats better the industrial or AG? when it comes to digging?
The 4500 has a 3 cyl diesel with a strong engine, i think that will be great for what I have to do.
Thanks for any advice, I am very new. I was very close to buying a AG ford 4000 tractor with back hoe but the guy was supposed to fix a blown hose and he has had a month to do it, time for me to move on to the next one, the 4500 is local i cant wait to take a look... plus it is diesel and i love diesel.
kenny
Mercury is offline
post #4 of 31 Old 09-14-2010, 01:40 PM Thread Starter
Re: Ford 4500
Wanted to ask one more quick one, how much would be reasonable for a machine like this?
Starts and runs well and strong...
thanks in advance... I am new at all this and just looking for a solid backhoe to work in my yard
kenny
Mercury is offline
post #5 of 31 Old 09-14-2010, 02:41 PM
Re: Ford 4500
A 4500 would probably be better for digging than a 4000 AG with a backhoe added on, especially if it's the older 4 cylinder 4000, which were smaller, lighter and less hp. The 3 cylinder 4000 AG tractor was comparable to the 4500, but the backhoe addition was still an add-on rather than being designed into it from the ground up like the 4500 Industrial was.
I've been seeing that same one on the Philadelphia craigslist for the last several weeks, and I think that if it's running as good as he claims and there are no leaks anywhere, then $4500.00 is a good deal.
Nouveau Redneck
Sean in PA
post #6 of 31 Old 09-14-2010, 02:50 PM Thread Starter
Re: Ford 4500
Thanks redneck.... I looked at the ford 4000 AG tractor... and it was the 4 cyl gas, engine fired right up and felt strong but then it blew a hose on the stabs, I have been waiting a month for him to fix it but no such luck. he wanted 4400 for the ford 4000.
Now this one the ford 4500 has not been listed all that long (a few weeks at most) and the guy is local which is good (less towing costs).
I go to look at it tonight and if I like it I think ill just buy it. Parts can still be had for the 4500's at reasonable prices.
My other back hoe I was supposed to look at tomorrow is a wain roy 4 cyl diesel backhoe. But there is nowhere I can find parts for that thing, sure it is listed for 3K but what if I blow something, im just totally stuck - I think I am pushing for the ford 4500.
Thanks for the info, this is all very exciting.
Does the 4500 industrial have a 3 point hitch if the backhoe is removed? Just wondering, I may want to use it at some point later in life.
kenny
Mercury is offline
post #7 of 31 Old 09-14-2010, 04:08 PM Thread Starter
Re: Ford 4500
By the way I just tried that parts place you told me about and it needs me to log in there... Are you a dealer or something?
Kenny
Mercury is offline
post #8 of 31 Old 09-14-2010, 06:08 PM
Not a restorer
Ecnerwal's Avatar
Images: 8
Re: Ford 4500
4500 may or may not have 3-point hardware - if it was a hoe rig from the factory, it probably won't. You could change the rear end to get one, but that's a job and a half. A second tractor might well be easier.
4500 .vs. 4000AG - no contest, the 4500 is the better digger. 3 cyl .vs 4 cyl - 3 cyl better, IMHO. Certainly newer.
4500 has a 27GPM nose-mount pump, and a 20 gallon reservoir (5 in the nose with the filter, 15 or so in the loader frame). The loader (740) is an industrial loader that will break out 6000 lbs and lift 3000 to full height, with a front axle that will support that. An ag front axle is weak by comparison, and ag loaders are wimpy and slow by comparison. No ag add-on pump is comparable to the 4500 hydraulic package pump, as far as I recall. I'm assuming it's got a loader, they nearly all do since the loader frame is on there from the factory.
As for price, condition is everything at this age. Anywhere from $1500 to $6000, "depending". Hoses are easy, seals are moderate, scored cylinders and rams are expensive, as hydraulic repairs go. Back tires are very expensive. If somebody loved it enough to use all 20+ grease fittings on a regular basis, it's worth a lot more than if they used 3-4 of the easy-to-get to ones once in a great while and left the other 16 or so un-touched. If you can't pump grease in them all, they are not happy and have not been used - the the one in the bottom of the main hoe pivot pin (fun to get to, or even find depending on impacted dirt) or the two at the center pivot of the front axle for "not likely to have got used much if not caring for it." Look for slop (forward/back mostly - open it up and put the bucket edge in the ground, then pull/push and see what moves) at the main pivot of the hoe. Look for the power steering working only in one direction (end of the ram may be snapped off, so it only works when pushing.) Look for missing bushings on the king-pins of the front wheels.
I've done a lot of work with mine, and parts can be found, but as with any old equipment, getting it apart to get new parts on can easily be 90% of the battle when things are rusted tight and 40 years old, not to mention heavy enough to kill you (in many cases) and awkward to handle once you do get them loose.
Ecnerwal is offline
post #9 of 31 Old 09-14-2010, 08:11 PM Thread Starter
Re: Ford 4500
Hi there...
Well I did not get to do "everything" you said.... but the machine did fire up after the pre heaters were ran twice she smoked a little when getting fired up but ran nicely when she was up and running. She sounds VERY strong.
Everything was greased well and maintained nicely. No slop in any pins, on loader or backhoe.
Transmission worked nice it was a 4 speed forward and reverse with the quick throw lever (i do not know the name of this tranny)
The hour meter showed 2500 or so and i believe it.
The two rear tires have some patches / plugs in them and I will search for those tires for cheap (look for a deal) are they split rim, how do you mount them?
The two front tires were shot and a tube is popping out on one of them.
There are no leaks on the machine except for one seep on one hose connection for the stick on the backhoe.
I got some numbers here.... i will try to look them up too...
on tranny? 357e-4033a
on engine
C94n7006D
Any info would be great along with size of front tires i could not read the size... cause i need those bad - wonder if i can mount those myself with my harbor frieght machine
Thanks all Kenny
Mercury is offline
post #10 of 31 Old 09-14-2010, 08:48 PM
Not a restorer
Ecnerwal's Avatar
Images: 8
Re: Ford 4500
Transmisson is called "4 speed power reversing"
Numbers you posted are just casting numbers - look up "oaktree tractor page" and then on there look for "ford thousand series" to find the best page for where to look for numbers and what they mean. If the hood is original the numbers should be on an aluminum plate under there (over the battery), otherwise the flat spot behind/above the starter (hard to see with the loader frame on a 4500 - you may need a flashlight, a mirror and a wire brush) is where the primary numbers are.
Front tires were typically 7.50x16 - if you don't have a thing for bias ply, slap some 235x85 R16 truck radials on there (with tubes) and you are good for digging/loader duty, unless you have to have the "look" of tri-rib ag tires. Load range E radial tires are a good bit above the original "6-ply" bias rating....
As far as I recall the back tires are normal rim, and you will break the bead with something heavy and then use tire irons to change them - or you will wimp out and call a tractor tire service, especially if they are loaded with calcium chloride.
I take it you've got a diesel, since you mentioned a preheater. Unless you are DEAD CERTAIN the previous owner has done this VERY RECENTLY, pop on down to the New Holland dealer and get an oil filter, a transmission filter, a hydraulic package filter, an air filter and a fuel filter. Change them all, change the engine oil, and give serious consideration to changing the hydraulic fluid unless it looks pristine (but there is a _lot_ of it.) That way you know when they were changed, and you know you are starting out with them all clean, and can keep records from there.
Everything on the tractor but the engine uses Ford (pardon me, New Holland) 134D or a Universal Tractor Fluid that meets the 134D spec. Generic will be cheaper and works just as well as far as my opinion goes - other opinions may differ. The transmission and rear end are separate, and both use the stuff.
Depending on the year, your power steering may be separate or may be tied into the hydraulic package.
Don't miss greasing the spline drive to the hydraulic pump in the nose.
Ecnerwal is offline
post #11 of 31 Old 09-14-2010, 08:53 PM Thread Starter
Re: Ford 4500
Its funny I could not give away my stock 235/85 R16 tiers, now i can use um! oh well.... ill find some
Gotta trailer it home next, im looking that up now cause i bought it
kenny
Mercury is offline
post #12 of 31 Old 09-14-2010, 09:08 PM
Not a restorer
Ecnerwal's Avatar
Images: 8
Re: Ford 4500
You'll need a heck of a trailer.
Hiring an equipment mover may be the better/cheaper (in the long run) option. Depending exactly how it's equipped (size of hoe, are tires loaded or not), it's a 7-9000 lb beasty with a hoe on.
Ecnerwal is offline
post #13 of 31 Old 09-14-2010, 09:15 PM Thread Starter
Re: Ford 4500
Im looking at equipment movers now.... I can rent a 20 ft deck over for 100 bux but i do not think its wise to make this transport, even though it is only 5 - 10 miles
Mercury is offline
post #14 of 31 Old 09-14-2010, 09:19 PM
Not a restorer
Ecnerwal's Avatar
Images: 8
Re: Ford 4500
Experience and the right equipment are worth paying for - I don't know about your local market price, as they vary widely, but if you don't have to go too far away to find a mover (transit time to/from the job) you might actually come out paying less and having someone that's fully equipped for the job to do it. If equipment movers come up too expensive or far away, look around for a local contractor that hauls a backhoe around your town and give them a call.
Ecnerwal is offline
post #15 of 31 Old 09-14-2010, 09:21 PM Thread Starter
Re: Ford 4500
Oh I agree... theres a slight hill from there to here and I do not think it is wise for me to attempt on my own, the most I ever trailered was 3500 LBS, this is quite different I am sure.
Im still looking
im excited needless to say
kenny
Mercury is offline
