Snapper Comet mower differentials specify "Snapper 00 grease," what interchanges? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Don's Synthetic Lubes A Commitment to Excellence in Synthetic Lubrication AmsOil The First In Synthetics
post #1 of 9 Old 07-02-2009, 11:46 AM Thread Starter
Snapper Comet mowers were produced for many years and they are such durable machines that people keep them running by performing basic maintenance while new low-priced mowers typically become salvage-yard candidates within 10 years.
Naturally we expect most parts to be model-specific, but some items like fuel, oil, grease, tires, blades and engines, should interchange. I don't believe that Snapper is producing oils or greases. It does not surprise me that they market those products under their own brand name. I found it disconcerting to learn that grease specified by Snapper for use in their Comet model differentials is being marketed as "Snapper 00 Grease" without standard interchange standards committee compliance specification! Worse, they refuse to tell Snapper Comet customers what that stuff is. Instead, they insist on hiding that interchange information and demanding that Comet owners buy their rebadged product. I may have a 5-gallon bucket of some perfectly suitable replacement grease in my shop. Yet I can't be certain if what I already bought is a suitable substitute without that interchange information.
"Thank you for e-mailing Snapper. This grease is specially formulated for Snapper and we do not have a substitute. The Snapper part number for the four ounce tube is 7029443 and the part number for the 32 ounce bottle is 7061017. We have a Dealer that sells on line and you may be able to order this through them, their web site is www.alamia.com."
Talk about self-serving statements!
Buying grease in 4 ounce or even 32 ounce containers is priced higher per ounce than 5-gallon bucket prices through standard trade vendors. I also assure you that this cat and mouse game, intended to wring out a few extra nickels from captive customers, is highly offensive to me and to other Snapper product owners. It would also require one more trip to a dealer that might not be needed if they released the standard interchange specification information.
Does anyone know what the heck interchange specifications correctly describe this secret formula "Snapper 00 Grease" which has been marketed for at least 50 years already?
I KNOW from experience that swapping in the wrong grease into some limited-slip differentials quickly clauses them to chatter as they slip then bite during cornering. I want to run suitable grease in my Comet's differential. But I also hate being so obviously abused. I refuse to reward that kind behavior. Help - spill the beans.
John
LoveLearn is offline
post #2 of 9 Old 07-02-2009, 05:51 PM
Decesaed (R.I.P.)
tgore3's Avatar
Images: 5
Re: Snapper Comet mower differentials specify "Snapper 00 grease," what interchanges
This is what I get http://tewarehouse.com/7-06612;jsess...4Pa38Ta38Rb3r0
You don't have to buy Snapper brand 00 grease
Regular grease is too thick, gear oil is too thin and will leak. If the cases were sealed better, gear oil would work fine. Regular grease will just throw off the parts and not flow back to them. I guess the key words are "semi fluid".
tgore3 is offline
post #3 of 9 Old 07-02-2009, 08:34 PM
I searched "00 grease" and found several, looks like amsoil and rotary both offer a "00" grade of grease.
It looks to me like the "00" rating is like ratings on engine oil "SE" "SF" etc.
http://www.amsoil.com/storefront/gsf.aspx
http://www.mowtownusa.com/m5_view_it...5:item=770-123
http://www.mowmore.com/index.cfm?fus...oduct_id=30335
john c is offline
post #4 of 9 Old 07-02-2009, 08:48 PM
Decesaed (R.I.P.)
tgore3's Avatar
Images: 5
Yeah, the 00 is the grease type, semi fluid
tgore3 is offline
post #5 of 9 Old 07-03-2009, 12:09 PM
donsoil
John
Greetings John !
First off let's take a look at what grease is.
Grease is 70% to 80% base oil + 1% to 10% Additives + 8% to 12% thickeners.
Grease thickeners are:
1 soap based organic ( lithium complex, and aluminum complex )
2 non soap based organic ( Polyurea)
3 Inorganic ( Clays and Silicas)
The ammount of thickener added determines the thickness of the grease.
There are 9 NLGI (National Lubricating Grease Institute) Grades, they are:
NLGI # 000 very soft, semi fluid
NLGI # 00 very soft, semi fluid
NLGI # 0 very soft, will not flow
NLGI # 1 soft , couplings
NLGI # 2 The most commonly used grease for automotive type use, wheel bearings, universal joints.
NLGI # 3 Very stiff, high speed bearings
NLGI # 4 Extremely stiff
NLGI # 5 Nearly solid
NLGI # 6 Solid brick , used for lubricating drag line cables
Lithium based grease is the most common and widely used thickener.
Polyurea is frequently used in sealed for life bearings and electric motor bearings.
Clay and silica thickeners are used more for industrial and special applications such as nuclear power plants, and extreme temperature applications such as steel plants.
When changing greases compatibility must be taken into consideration, mixing greases that use different thickeners is asking for trouble.
Polyurea thickeners are only compatible with polyurea thickeners, do not mix polyurea with greases containing a different type thickeners, the reaction from incompatible grease thickeners produces fluid seperation, the item being lubricated is left with the leftovers of the reaction which will lead to component failure.
Sodium thickeners are only compatible with sodium thickeners.
Lithium thickeners are the most common thickeners most of us use on our auto, heavy equipment, lawn mower type applications. Lithium complex is compatible with other lithium type thickeners as well as most calcium type thickeners.
The snapper grease you refer to is a NLGI # 00 semi fluid grease, no one has made mention of the type of thickener used in the snapper grease. It may very well be a lithium type thickener, but without the manufacturer specifications I would be guessing.
There is a saying to remember when changing greases, when in doubt flush it out. If you would like to change to Amsoil 00 grease, or another brand, be sure to flush out the housing to remove old grease before adding the new.
Another thing to consider is what components are in the gearbox, if it contains no yellow brass or soft copper, you could use Amsoil SAE 190 GL-5 Severe gear synthetic lube, as it is the same viscosity as the NLGI #00 semi fluid grease. If the gearbox uses these soft metals the Sulfur based EP additives in the GL-5 gear oils will corrode yellow brass and soft copper.
Many companies play the scare the customer back to us lubricant "Game" with their customers, the more you know about lubrication, the less often you end up a victim of their "Game".
Hope this helps !
Have a great day !
Don
donsoil is offline
post #6 of 9 Old 01-24-2010, 06:04 PM
The grease game,
You are lucky that the snapper folks even sell a product, I have been looking into this same subject in the automotive trade, It just so happens that for the enclosed knuckle differential a similiar type of lube is used by the manufactures . It is a #0 sodium based lube, it is used in applications that are prone to leakage, (and in this case a slight amount of discharge is preferred.)
and where high service intervals can be obtained, it lasts indefinitely , in some articles its mentioned as Lubed for Life or Practically maintinace Free.
I do not know for sure that the snapper 00 grease is a sodium base but it sure sounds like it.
It used to be very common 40 years ago but now its seldom seen and rarely used, and I may add even more so mis- identifed those who encounter this form of grease in the 4x4 steering knuckle think that it is 80-90w oil contaminated with wheel bearing grease, due to a axle seal failure, except for a few old school mechanics who have actually seen this form of lube. Thanks Frank
backwoodsgoop is offline
post #7 of 9 Old 03-10-2010, 08:35 PM
Playin' In The Dirt Again
Hi Fellows.
I would like to piggy-back on this "00" grease discussion.
Today I was looking through the manual which came with my Land Pride tiller, reading about lubrication. It suggested that I use Shell Alvania EP 00 oil for the drive chain's enclosure. The manual also said that alternatively I could use SAE 90 oil. No further elaboration was provided. I have two questions:
1. Is "00" oil of another brand okay to use in the place of Shell Alvania EP 00 oil? In other words, is someone else's "00" oil equivalent and okay?
2. By SAE 90 oil, are they speaking of the smelly stuff like goes into the differential of my car and truck?
Hank
A little Green Deere, a little Red Dirt, and lots of Rocks ...
hankosaurus is offline
post #8 of 9 Old 03-10-2010, 08:52 PM
larrybl's Avatar
Images: 43
Several years ago I was taking my used oil in for recycle, the guy there asked if I wanted a 5 gal can of grease, cause it would take too long to pour out.
I scored a new 5 gal can of Chevron Dura Lith Grease EP (NLGI 00).
Been using it on all my transaxles including the current Snapper project.
Fill a funnel, and wait an hour to train into the transaxle,
Still have about 1/3 can left.
1990 18.5 Craftsman (RED)
1978 Roper 20T (Old Girl)
[/url]
larrybl is offline
post #9 of 9 Old 03-10-2010, 10:11 PM
89YT12's Avatar
Images: 9
im just using a generic "00" from the local tractor/auto parts house
Jason "J"
89YT12 is offline
