mobil 1 15w50 in hydro - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 6 Old 08-30-2009, 09:48 AM Thread Starter
smokey hollow
Good Morning fellow tractor nuts;
Changed transmission fluid this morning with cub filter and mobil 1 15w50.
Tractor runs quiet and strong. Wanted synthetic for winter use.
wesk is offline
post #2 of 6 Old 08-30-2009, 06:27 PM
JMoe's Avatar
Re: mobil 1 15w50 in hydro
Good deal wesk. I assume this is on your late model 2550 where Cub Cadet Drive System Fluid Plus is specd? I too bucked the system ~4yrs ago and swapped out to Shell Rotella-T 15w40 for the trans on my 2544. I dunno that I would have gone to a 50wt variant for winter use, but it should be fine for you.
Joel
Current rider: 2006 Craftsman LT2000, 18.5hp Briggs AVS, Peerless HT2000 hydro.
Mowers of the past:
2010 Cub Cadet Z-Force 44 fab.
2005 Cub Cadet 2544.
1979 Case 220.
2003 MTD Yardman 600 series transmatic
1992 John Deere GT262
1970 John Deere 110
JMoe is offline
post #3 of 6 Old 08-30-2009, 06:36 PM
gwdave1997's Avatar
I have to jump in here, I have been using Mobil 1 for several years in my motorcycles (Gold wings), and have not had any problems year round. Here in New England it gets kind of brisk during the winter, and when I was a working stiff I rode year round except when there was ice or snow on the road. I did have to question my sanity a couple of times while suiting up when the temp was hoovering around 18 deg. The 15-50 did not give a problem. I started using it in a 1200CC Kawasaki Voyager, and the first thing I noticed is that I could shift it without hearing the gears clash. I used to pull a camper with the wings, and never had a problem. I used the 15-50 in my old Rears, and Throwback (Sears) riding lawn mower, however I did not use that in the winter. I will be using it in my CC in another week or 2 as I almost have 50 hours on it........
GWDave1997
Cub Cadet LTX 1045, 46" plow/Dozer blade
Chains, Home made weight box, Agri-fab Aerator, Agri-fab 85lb spreader
Sears (Agri-Fab Vac N Go) - Professional lawn Vacuum/W extension hose
Happiness is a nice warm day, a
crooked road on a motorcycle.
gwdave1997 is offline
post #4 of 6 Old 08-30-2009, 08:34 PM Thread Starter
smokey hollow
Joel; I used it on my 07 gt2550. Mowed the yard this afternoon.Worked great.
Tractor has over 200hrs. already.Have never had a problem of any kind.
Wesk
wesk is offline
post #5 of 6 Old 08-30-2009, 08:53 PM
stint9's Avatar
TuffTorq hydros recently changed the recommended oil from 10W30 to synthetic 5W50
stint9 is offline
post #6 of 6 Old 08-30-2009, 09:37 PM
JMoe's Avatar
Right, but your average TuffTorq holds 2-4qts where the Hydrogear driven rears on our Cubs hold 6qts. I've never known overheating to be an issue with them, where (although a great trans) TuffTorqs will overheat given their small capacity. I'd go heavy and synthetic on a TT fo sho.
Joel
Mowers of the past:
1979 Case 220.
1970 John Deere 110
JMoe is offline
