Kohler K301A engine running hot - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 8 Old 08-08-2009, 06:06 PM Thread Starter
ptplumer's Avatar
My Kohler engine on my Cub Cadet 129 runs very hot. I rebuilt the engine two years ago and it has lots of power, but it runs very hot. I have the carb set where factory specs suggest, and it runs well, but carbons up and backfires when I shut it down. I have made some minor adjustments to the carb, but maybe I am just being too conservative. I am trying to find some good suggestions, anyone?
ptplumer is offline
post #2 of 8 Old 08-08-2009, 07:04 PM
Collector of many tractors
Kbeitz's Avatar
Re: Kohler K301A engine running hot
Running lean or a timming problem or no air flow...
Kbeitz is offline
post #3 of 8 Old 08-09-2009, 12:48 AM
certified tractor nut
amf1414's Avatar
have you pulled the shrouds to make sure that no furry little critters have made youe engine into a new critter condo
amf1414 is offline
post #4 of 8 Old 08-09-2009, 09:30 AM Thread Starter
ptplumer's Avatar
No furry creatures inhabiting the shrouds. I did the top end overhaul myself, all timing marks are aligned per procedure. I am going to play with mixture later today. Make it richer. Thanks.
ptplumer is offline
post #5 of 8 Old 08-09-2009, 09:41 AM
ex spelling bee champ
Ingersoll444's Avatar
Images: 14
What makes you think its overheating?
pretty much all the old K's backfire when shutting down. That big flywheel keeps the engine turning after shutdown, and pulls raw gas into and out of the engine into the hot muffler and POW!!! Before shutoff, let it idel down for a min or so, then shut off. that normaly helps.
Paul B
SUPER Of The Month 10/2011
Ingersoll444 is offline
post #6 of 8 Old 08-09-2009, 03:34 PM
I 444 is right. As long as the cooling fins have paint on them (except around the exhaust port) its temperature is probably OK.
rscurtis is offline
post #7 of 8 Old 08-09-2009, 09:46 PM Thread Starter
ptplumer's Avatar
I went through the tuneup process based on Kohler's specs as best I could wihtout a tach. Seems like ti may have helped. I'll have to mow with it this week and see how it does. I will try the cool down recommendation. Thanks a bunch!
ptplumer is offline
post #8 of 8 Old 08-09-2009, 09:47 PM Thread Starter
ptplumer's Avatar
One other thing, how do you tell the difference between the Walbro and Kohler carbs on these?
ptplumer is offline
