cub cadet fuel pump question - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 25 Old 04-09-2008, 01:03 PM Thread Starter
I have a 3205. It ran fine the other day while mowing a yard. Parked it. Went to start it today, and it acts like no fuel. Battery is fine, and cranks good.
I finally hit it with starting ether, and it started just briefly.
I filled it with gas, and the air cleaner is good.
Are there any problems with fuel pumps on these?
Don't know the engine that well. It could have a mechanical pump only oir an electrical.
rbig is offline
post #2 of 25 Old 04-09-2008, 01:56 PM
dyt4000's Avatar
Images: 12
Re: cub cadet fuel pump question
You could take the fuel line off the carb, stick it in a jar, spin the motor and see if there is any output...
1957 IH Cub Lo-Boy
1959 Ford 631 Workmaster
1967 Wheel Horse 857
2001 John Deere 425 3 point lift, rear PTO and Heavy Hitch with trash can option
dyt4000 is offline
post #3 of 25 Old 04-09-2008, 04:45 PM
Dave01's Avatar
I'd pull the spark plugs and re-connect the plug wires and verify you have a strong spark when cranking. Also see if there is any gas on the plugs or if they are dry.
Assuming plugs are dry and you have good spark, I think I've read here about fuel shutoff solenoid problems. I honestly don't know which models this applies to, so you ought to do a search here for fuel solenoids and see what you find, but I thought I'd mention it as a possibility.
Good luck!
CC 1864, CC 2084, CC 3204
Dave01 is offline
post #4 of 25 Old 04-09-2008, 04:51 PM
moe1942's Avatar
If it is vacumn operated replace it with a inexpensive 12V electric..That's what I do..cuts down on the cranking time too.
moe1942 is offline
post #5 of 25 Old 04-09-2008, 06:55 PM
neil_nassauequipment's Avatar
Some have a mechanical fuel pump built as part of the valve cover.
DO NOT install an electric fuel pump in one of these engines.
You either have one thats failed......ez to check or your fuel shutoff solenoid thats part of the carb is stuck and or malfunctioning.
If youre not handy with tools....take it to a kohler dealer.
neil_nassauequipment is offline
post #6 of 25 Old 04-09-2008, 07:27 PM Thread Starter
How do I check the fuel shutoff solenoid?
rbig is offline
post #7 of 25 Old 04-10-2008, 07:55 AM
moe1942's Avatar
Whats your reasoning. I just did it on my Bob Cat welder and it's works better than ever. There are electric fuel pumps available with press under three pounds..
moe1942 is offline
post #8 of 25 Old 04-10-2008, 11:22 AM
Gary in NJ's Avatar
Images: 10
I replaced the fuel pump on my 3206 last summer. 5 minute job. The pump is located on the valve cover.
Gary
Kioti CS2410 with FEL, BH, 60" MMM, Snow Blower, Carry All
Gary in NJ is offline
post #9 of 25 Old 04-10-2008, 03:04 PM Thread Starter
My engine is two cyl, liquid cooled.
my valve covers don't seem to have the pump arrangement.
My parts manual shows the fuel pump as being a separate electrical thing.
I can take the fuel line off the carb and see if the pump is delivering fuel. If it's not, where is it (front or under seat)?
rbig is offline
post #10 of 25 Old 04-10-2008, 05:03 PM
moe1942's Avatar
It's between the engine and the fuel tank. Just follow the fuel line to the tank.
moe1942 is offline
post #11 of 25 Old 04-10-2008, 05:06 PM
moe1942's Avatar
Another thing thrown into the mix is the solenoid operated shut off at the carb. Sometimes on the newer mowers it's best to check that first unless the problem is obvious. It's easily forgotten.
moe1942 is offline
post #12 of 25 Old 06-03-2008, 02:26 PM
neil, two questions please, (1) are the rocker arm cover type pumps servicable in any way except to replace the whole rocker cover?, (2) What is the reason an electric one can't be used?
Gramps is offline
post #13 of 25 Old 06-03-2008, 04:38 PM
xPosTech's Avatar
Re: cub cadet fuel pump question *Question*
Rbig it's now June. Are you going to post the solution to your Cub or is it still not running?
Ted
I wasn't born in Texas but I got
back here as soon as I could.
xPosTech is offline
post #14 of 25 Old 06-03-2008, 07:39 PM
Gary in NJ's Avatar
Images: 10
On my 3206 the original pump was no longer available, requiring the valve cover to replaced as part of a kit. On a newer 3100 this may not be the case. A quick call to Cub Cadet should resolve the issue.
In any event, it is an easy repair.
Gary
post #15 of 25 Old 06-03-2008, 08:16 PM
My bad rBig....
I've run into this before on 3205 and 3208. Some (actually most) have TWO fuel filters. Hitch is they're not on the parts list. One up by the engine (thats a kawasaki one,its on partslist) and one under the seat area in the fuel line.
Like mentioned above, follow the fuel lines. BTW If they're too old,replace the fuel line, they deterioate on the inside and may look fine on the outside. Little pieces of black stuff in the fuel filter is a clue.
It does already have an electric fuel pump.....remember the wiring diagram we sent you? You should hear it "turn on" when you first turn the key one to start it.
Apologies again for the oversight.
