Ross Steering rebuild video - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 5 Old 12-01-2012, 06:12 PM Thread Starter
FORD_LGT_165's Avatar
Just made this video today. Hope it helps out.
Cheers
http://youtu.be/qIxYUmPLRzM
FORD_LGT_165 is offline
post #2 of 5 Old 12-01-2012, 06:47 PM
JRC IOWA's Avatar
Images: 24
Re: Ross Steering rebuild video
Thanks for the video i have a extra ross that i would like to rebuild and this will help a lot
CC 3235
CC 1882
CC 1872
CC IH 123
JRC IOWA is offline
post #3 of 5 Old 12-01-2012, 11:21 PM
Tech Exchange Moderator
Sergeant's Avatar
Thanks I Copied & added this to the Cub Cadet FAQ
John Deere Models:X748,GX335,140H3,112,Sabre 1542,TX Gator
Ingersoll Model:3016PS
Simplicity Models:Wonder Boy
White Model: GT2055
Sergeant is offline
post #4 of 5 Old 12-01-2012, 11:24 PM
Merk's Avatar
Your video is a good start. There are a few more things I do.
1. The stud usually had some wear/flat spots on it. It needs be replaced or if you have access to a lathe it can be turned to remove the flat spots.
2. You need to check the package seal/retainer to make sure they are ok. I have had several seals that were torn or missing and the retainer in not very good shape. Grease and dirt can get between the lever and bolt assembly (Cub Cadet discription) and cause wear. Replace as needed.
3. Most times the retainer/ball assembly can be cleaned and reused.
4. I use a lite duty grease when I repack the steering assembly. The grease will fill in the areas when the steering gear and stud make contact. I use John Deere's corn header grease.
5. Most of International Harvester Cub Cadets have a plastic bushing at the top of the steering tube. I replace the bushing with the same bearing that I use in the front wheels of a IH Cub Cadet.
6. I use 2 washers, flat roller bearing and a lock nut to hold the lever and bolt assembly. It is cheaper and so far been trouble free for the last 8 years on 3 IH Cub Cadets (70-100-149).
Everyone that drives my Cubs thinks they have power steering.
Just trying to help
Merk is offline
post #5 of 5 Old 12-24-2012, 12:30 PM
DAC
DAC's Avatar
Is is really possible to remove all the play from the steering assembly? Never have owned a new tractor, thus it's been my belief that at least 1" of play was normal. I will pull in all six tractors and get busy if it can be done.
Current Machines:
Cub Cadet: 2082, 1862, 1541, 1440
John Deere: 100
Toro: 16-38 HXL
Alex in Cincinnati
DAC is offline
