Snow blade for a LT1050 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 10 Old 12-28-2010, 10:22 PM Thread Starter
We just set a record month for snow so I need to get some kind of blade/plow on my LT1050. Has anyone used this blade http://www.sears.com/shc/s/p_10153_1...4059-2#ppspecs
How does it fit on a Cub? I think this blade height and angle can be adjusted from the seat. I think changing the angle from the seat would be useful. I have to plow a crushed rock driveway about 150' x 2+ lanes plus a small circle drive. Drifting of a foot or two is common. I might also want to use the blade for minor spreading of gravel/top soil but mainly for plowing snow. Any suggestions?
Thanks,
Pete
EZ Rider is offline
post #2 of 10 Old 12-29-2010, 01:19 AM
Cubs Rule
NewCubGuy's Avatar
Images: 5
Re: Snow blade for a LT1050
Just curious, have you ruled out a Cub Cadet blade? I have no experience with the Sears blade but from an engineering outlook it doesn't have much in the way of sturdiness built into the way its made. I would ck out the Cub Cadet blade also.
2008 GT 2550
50in deck with PowerChute
Cub Cadet Dozer blade
Rear wheel weights
Chains
Sleeve Hitch
Cultivator
Home built Rear Tiller
Yard Cart
Rear dethatcher
NewCubGuy is offline
post #3 of 10 Old 12-29-2010, 01:22 AM
Cubs Rule
NewCubGuy's Avatar
Images: 5
Bercomac also makes good blades.
2008 GT 2550
Rear wheel weights
Chains
Sleeve Hitch
Cultivator
Yard Cart
Rear dethatcher
post #4 of 10 Old 12-29-2010, 08:01 AM Thread Starter
Hey thanks!
EZ Rider is offline
post #5 of 10 Old 12-29-2010, 10:31 AM
CCinCT's Avatar
Images: 13
You may have installation issues if you use the Craftsman blade. You'd be better off with the MTD blade, or a Bercomac that's specific to your tractor. The MTD and Craftsman blades are about the same in terms of quality, ruggedness, etc. I don't know anything about the Bercomac's, but most people here seem to be very happy with their products.
Don't forget you are also going to need to either get different rear tires, or put chains over your turf tires. You will also need additional weight, either by adding a weight bracket and suitcase weights, or by adding wheel weights, or by loading the tires, or any combination of those.
2013 X530 with:
  • 48" deck
  • 48" plow
  • 47" snow blower
  • Power sleeve hitch
  • Tractor shovel
  • Tractor lift
  • 18 steel cart
  • AC-G8010S-E generator
Previously:
2006 Cub Cadet 2544 - Loved it
CCinCT is offline
post #6 of 10 Old 12-29-2010, 10:57 AM Thread Starter
Thanks CC. I checked the Bercomac site on the advice of NewCubGuy and I can see why people are happy with their products like their electrically raised and lowered blade, but I'm sure those are more pricey than what I'm looking for. The installation issues with the Craftsman blade are part of what I was concerned about but looking at the owner's manual for the Craftsman, I liked that it had a full-length sub-frame that extended all the way back under the tractor as opposed to simply attaching to the front tractor frame like most I've seen. Maybe that's not a big deal. I know I'll need chains and possibly weights although weighing in at about 250 lbs myself, I'm not sure how much I'll gain (no more I hope!) with another 50lbs or so.
Thanks again,
Pete
EZ Rider is offline
post #7 of 10 Old 12-29-2010, 11:45 AM
ericdube's Avatar
I'd probably go with the Cub Cadet blade instead. It's the same price as the Sears plow (or even somewhat less in cost from what I just saw), and you wouldn't end up with any additional headaches when trying to mount it.
However, if you did want something more sturdy, then I'd look at either the Bercomac or Johnny plow (which are both well built and electrically operated making them much easier to use than the manual plows.)
ericdube is offline
post #8 of 10 Old 12-29-2010, 09:21 PM
Cubs Rule
NewCubGuy's Avatar
Images: 5
I wouldn't worry about the long frame mount. The first part to bend or break will be the metal closest to the blade just after where it turns. They take a lot of stress when pushing snow cause you hardly ever push an even amount of snow dead straight. Like when your pushing with the blade at an angle the frame up front will want to twist when your pushing uneven loads of snow. Look at the way the 2500 series blades are made. The front A-frame is boxed it for sturdiness so it can't twist.
2008 GT 2550
Rear wheel weights
Chains
Sleeve Hitch
Cultivator
Yard Cart
Rear dethatcher
post #9 of 10 Old 12-30-2010, 04:04 AM
USMC
slkpk's Avatar
Images: 21
You would be better off going with the Cub, Bercomac or JB setups IMO. slkpk
1964 JD RF110 Restored
2007 JD 2305
slkpk is offline
post #10 of 10 Old 12-30-2010, 09:52 AM
i had an lt 1050 i got a blade for it at tractor supply they also had them at home depot. it was $289 i think. worked ok but if you need to push more than 8-10 inches it will be tough. go with wheel weights a weight bracke and suit case weights will put to much strain on the trans thats what the cub dealer told me anyway. i had barlugs on mine and was fine.
jim982 is offline
