Project 2182 - Build Thread - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 21 Old 04-19-2017, 01:14 PM Thread Starter
KDB
New to the forum. Have been lurking around awhile and thought i would join to share a build with you guys. Not my first resto, or Cub, but it is my first Cub resto and any advice, opinions or thoughts are greatly appreciated.
I picked this 2182 up in February and it was a hot mess. Complete tractor, running engine and everything worked but needed attention. When i finally got around to messin with it, noticed that when engine warmed up it had a noticeable knock in the midrange rpm. Also was pouring oil from the front seal. I had planned to replace the seal and use it this season but during the process of replacing the seal, I noticed the crank had a good amount of play so i pulled the motor. And it was a good choice. Number 1 main was beat on pretty good and number 3 main had spun a bearing in its cap even tho the tractor had 25lbs of oil pressure warm. Anyway I had thought the crank was graveyard dead but I sent it off to Engine Power Source out of Rock Hill SC to see if it was salvageable and it turned out it was. So i ordered the corresponding bearings, new bearing carrier, rings and a full gasket kit etc.
In the meantime, I figured with the money i had just spent on engine parts, I wasnt about to put a brand new engine in a mediocre frame so I went ahead and started the whole build. Recently I have been cleaning parts, ordering parts and making a list of odds and ends stuff and this is where I am at with it. I will be posting the pics that i have taken up til now and will continue thru out the build. As mentioned earlier, any opinions, thoughts, or advice is highly welcome
Thanks
Here are some pics i took when i was buying it
ID:	1951793   Click image for larger version
ID:	1951801   Click image for larger version
ID:	1951809   Click image for larger version
KDB is offline
post #2 of 21 Old 04-19-2017, 02:40 PM
Re: Project 2182 - Build Thread
I'll be following along this build. Good luck.
NEOhio is offline
post #3 of 21 Old 04-19-2017, 02:49 PM Thread Starter
KDB
Getting it home and the tear down beginning...
ID:	1952017   Click image for larger version
KDB is offline
post #4 of 21 Old 04-19-2017, 02:52 PM Thread Starter
KDB
more pics
ID:	1952033   Click image for larger version
ID:	1952041   Click image for larger version
KDB is offline
post #5 of 21 Old 04-19-2017, 02:57 PM Thread Starter
KDB
main journal damage...
ID:	1952081   Click image for larger version
ID:	1952089   Click image for larger version
ID:	1952097   Click image for larger version
KDB is offline
post #6 of 21 Old 04-19-2017, 03:00 PM Thread Starter
KDB
more of teardown....
ID:	1952113   Click image for larger version
KDB is offline
post #7 of 21 Old 04-19-2017, 03:03 PM Thread Starter
KDB
more..
ID:	1952129   Click image for larger version
ID:	1952137   Click image for larger version
ID:	1952145   Click image for larger version
KDB is offline
post #8 of 21 Old 04-19-2017, 03:07 PM Thread Starter
KDB
more...
ID:	1952201   Click image for larger version
ID:	1952209   Click image for larger version
ID:	1952217   Click image for larger version
KDB is offline
post #9 of 21 Old 04-19-2017, 03:13 PM Thread Starter
KDB
cleaning and painting parts
ID:	1952233   Click image for larger version
ID:	1952241   Click image for larger version
ID:	1952249   Click image for larger version
KDB is offline
post #10 of 21 Old 04-19-2017, 03:20 PM Thread Starter
KDB
more cleaning and painting. i decided to go with a brighter blue for the engine and polish or clean all of the aluminum engine parts instead of painting the entire thing once it was all together. dang kubota even paints the rubber hoses
ID:	1952265   Click image for larger version
ID:	1952273   Click image for larger version
ID:	1952281   Click image for larger version
KDB is offline
post #11 of 21 Old 04-19-2017, 03:21 PM Thread Starter
KDB
powder coated parts
ID:	1952305   Click image for larger version
ID:	1952313   Click image for larger version
ID:	1952321   Click image for larger version
ID:	1952337   Click image for larger version
KDB is offline
post #12 of 21 Old 04-19-2017, 03:28 PM Thread Starter
KDB
now the fun part begins. sorry for all the pics... trying to get caught up
ID:	1952353   Click image for larger version
ID:	1952361   Click image for larger version
KDB is offline
post #13 of 21 Old 04-19-2017, 06:16 PM
? did you get a hold of the po and ask what kind of oil they used
john
no2498 is offline
post #14 of 21 Old 04-19-2017, 06:40 PM Thread Starter
KDB
Well the old man was kinda hard to understand and for what I gave for it I didn't ask too many questions. My guess is with that low of hours is it was ran low of oil. Givin the way that seal was leaking it could have happened really fast. In his defense tho, the low oil light bulb I found out later was also burnt out. Weird thing is I can't believe it didn't make any more noise than it did and it had really good oil pressure (mechanical gauge) almost 60 cold and 20-30 warmed up.
KDB is offline
post #15 of 21 Old 04-19-2017, 06:56 PM Thread Starter
KDB
Another reason I will be running mechanical gauges on this machine. I just don't trust those lights. I plan on getting this template lasered with thin aluminum or stainless
KDB is offline
