Hydrostatic Drive Fluid Question - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 6 Old 12-07-2009, 10:31 PM Thread Starter
snowbandit's Avatar
What type of fluid needs to go in the Hydro drive units on Cub Cadet? The owner's manual for my 3185 just says, "see your Cub Cadet dealer". Well I did that and the dealer told me not to buy it from him because it was too expensive and he doesn't keep it around anyway because you never have to change it unless it gets hot.
That story didn't make much sense so I just figured I would get some next time I was at Home Depot. After all HD carries CC so they should have the drive fluid, right? Wrong! They don't carry it either. So I have to ask, what do the experts here say?
snowbandit is offline
post #2 of 6 Old 12-07-2009, 10:47 PM
Mouse's Avatar
Re: Hydrostatic Drive Fluid Question
I only have a 125, I used Hytran, got it from a Case dealer. You better wait for a expert to answer. Good luck.
Mouse
1962 Cub Cadet Orginal
1963 Cub Cadet 100
1969 Cub Cadet 125
2009 Cub Cadet LTX1046VT
2011 Cub Cadet LTX 1040
1997 John Deere LX 178
Mouse is offline
post #3 of 6 Old 12-08-2009, 09:17 AM
Gary in NJ's Avatar
Images: 10
You can purchase two types of fluid from the Cub Cadet dealer, "Hydraulic Transmission Fluid" and "Drive System Fluid Plus, Synthetic Blend".
Does your model require synthetic fluid? I have a 2000 3206 and the fluid that was designed for it isn't even available anymore, "Cub Cadet Drive System Fluid".
I have been running Shell Rotella-T 15w40. No problems with running a bucket and blade with this fluid.
Gary
Kioti CS2410 with FEL, BH, 60" MMM, Snow Blower, Carry All
Gary in NJ is offline
post #4 of 6 Old 12-08-2009, 01:10 PM
magicalj's Avatar
I believe the proper fluid for it now is the "Drive System Fluid Plus" and it's about $13 a quart. Don't use "Hydraulic Transmission Fluid" in you tractor. It's not compatible with your transmission. I don't know what it would do to it, but I would suspect that it would eat the seals. With the DSFP they say you never have to change you fluid. I don't think I would go that far, but I would expect the life of it to be at least 300-500 hours.
AJ
1980 482
1981 582
1979 682
1980 782
1983 982
magicalj is offline
post #5 of 6 Old 12-08-2009, 05:09 PM Thread Starter
snowbandit's Avatar
I finally got a hold of my dealer, the one I trust that's about 60 miles away. He tells me the CC oil is a 20W50 synthetic. A good 10W40 would probably be okay in the Winter however.
Apparently there has been a problem in the past with these machines not stopping when you raise your foot off the petal because the oil was too thick. That's why CC developed the new "plus" oil which, he claims, solved that. Prices through him are $10.77 a quart and $39.51 a gallon.
post #6 of 6 Old 12-08-2009, 07:12 PM
patthesoundguy's Avatar
I'm using "universal tractor fluid" from wal mart in my 149, It says it's compatible with hydrostatic drives and said somthing about moisture resistance I think it was which is what I've read the hy-tran fluid is suposed to have and it's $7 a gallon canadian. so far so good.
patthesoundguy is offline
