TYM T-233 Tractor - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 8 Old 06-23-2012, 11:32 PM Thread Starter
SandDawg's Avatar
TYM T-233 Tractor
I bought a TYM T-233 tractor Thursday for use around my property. Bought a FEL and Boxblade in the package deal. Could of got a dual axle trailer and bush hog in another package but already have a trailer and can get a used finish mower cheaper on CL.
Used the tractor for about 8 hours today, so far I really like the T-233. I redressed the entrance drive with boxblade (did the main hole filling with a Large Ford tractor I borrowed from a friend), moved my heavy duty welding Jig table that is solid steel, moved implements into a new storage area and a few other things today.
Only problem I had with the tractor today was the hood latch wasn't adjusted correctly and the hood popped open when I hit a bump at high speed and flipped open in my face.... scared me cause I had just looked forward when it happened. Adjusted hood catch and all is well!
ID:	218772   Click image for larger version
Name:	TYM T-233 Moving Bogdisc.jpg
ID:	218773   Click image for larger version
Name:	TYM T-233.jpg
ID:	218774   Click image for larger version
Name:	TYM Lifting Welding Table.jpg
ID:	218776   Click image for larger version
ID:	218777   Click image for larger version
Name:	Drive Way Dressed with TYM Tractor.jpg
SandDawg is online now
post #2 of 8 Old 06-24-2012, 12:23 AM
RDR
RDR's Avatar
Re: TYM T-233 Tractor
You might want to keep the roll bar up and wear the seat belt if you were going fast enough to bounce the hood open.
Tractors have ag tires. Construction equipment have R-4 tires. If it has turf tires it is a lawnmower.
RDR is offline
post #3 of 8 Old 06-24-2012, 11:58 AM Thread Starter
SandDawg's Avatar
Thanks for the concern!
Wasn't really going that fast (low range / 4 wheel drive) and the ROPS was down so I could work underneath low hanging tree branches, plus my barn's roll up door just clears the ROPS bar in the down position. I keep all heavy loads close to ground during transport and watch the slope angles! The hood's latch was just barely catching, adjusted the latch bracket forward and no more problem.
Now seat belts are always a good idea, don't ask how I know this! To bad they are such a pain when moving stuff by yourself getting off an on tractor, hooking up chains constantly.
post #4 of 8 Old 07-01-2012, 03:52 PM Thread Starter
SandDawg's Avatar
Welded on a few upgrades to my FEL bucket and boxblade to make using them easier.
I welded 3 chain hooks onto my FEL bucket, this will help in moving heavy objects around the yard. I was having to wrap chain around a support bar behind the Bucket inorder to use the chain to lift with.
I also welded a hitch receiver onto rear of my boxblade so I can use receiver attachments and will make trailer movement alot easier! Drilled corners of boxblade to install chain hooks there. I can use them to hook a drag harrow or section of chainlink fence or anything I want to drag behind boxblade.
post #5 of 8 Old 07-02-2012, 08:28 PM
Joeyd's Avatar
Welcom to the TYM family, I think you will be happy with your tractor. Now all you need are some extra lights and you should be all set.
Joeyd is offline
post #6 of 8 Old 07-02-2012, 08:50 PM Thread Starter
SandDawg's Avatar
Thanks!
So far I'm happy with my purchase, only a couple of small problems to correct.
Thought about the lights but want a tool box mounted at the rear of the ROPS to hold tools and hitch attachments more!
post #7 of 8 Old 08-22-2014, 10:59 PM
bhayden's Avatar
So how about a long term follow up? I just happened to see in a Cabelas ad that they are now selling tractors. Did a little research and found out they were made for Cabelas by TYM. First I'd heard of the brand. Although even the 23HP would be serious overkill for my 1 acre do they look pretty nice. Competition to Kubota?
bhayden is offline
post #8 of 8 Old 01-17-2015, 07:50 PM Thread Starter
SandDawg's Avatar
I no longer get notifications in my Email for posts so this is a little late.
Really enjoy my TYM, a real back saver!
Only problems to date is a leaking oil seal on the front right wheel hub (4 wheel drive) and an oil leak at the PTO shaft. The PTO shaft is a small repair, not looking forward to fixing the oil seal on the front wheel. Had a wire to the fuel solenoid rub on the frame edge and short out causing the tractor to shut down and not restart, was a simple fix once found.
Still happy with my little tractor!
