Removing Bolens Steering Shaft - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 5 Old 09-24-2009, 08:14 AM Thread Starter
I have a Bolens ridiing 42" mower with the teeth striped at that bottom of the shaft. I have taken the deck off and the wheel off but can't remove the shaft. I see that there is a phillips head screw/bolt that attaches it underneath but is there a special way to get it off as it won't turn?
wrpratt is offline
post #2 of 5 Old 09-24-2009, 09:21 AM
JustinR's Avatar
Re: Removing Bolens Steering Shaft
The model number would help us help you. Also, are you just wanting to fix this or is this a restoration?
Original Bolens 1250 - Restored Bolens HT-18 - 1386 Water Cooled Yanmar Diesel Loader w/ Powersteering - Restored FMC Bean Cutler - Project 1477 - Troy Bilt GTX 20
http://huskylargeframes.blogspot.com/
http://www.youtube.com/user/jtube76?feature=guide
JustinR is offline
post #3 of 5 Old 09-24-2009, 09:39 AM Thread Starter
Not sure of the model number right now as I'm at work. I bought it in 2002 and am trying to fix it. Thanks.
wrpratt is offline
post #4 of 5 Old 09-25-2009, 01:48 AM
walter g's Avatar
wrpratt
Welcome to MTF. The newer Bolens are MTD made, so you would get more answers in that subforum.
But I can answer your question. The slightly older MTD's used a bolt instead of that screw. Put it back with the correct length bolt.
There are 2 bolts that hold the sector gear plate in. Remove them. Now you can move the gear out of your way. Hold the screw with a phillips head socket on a rachet.Do not try to turn it.
Now have someone else turn the steering wheel, and it should come loose.
The gear and shaft is sold as one piece. I believe they run around $45.
Check the plastic hex bushing the steering shaft goes into. They are almost always bad. Price $3.49.
There ia a bushing under the steering sector gear. Make sure it is good. It is only a couple bucks to replace.
But please post your model number info. Incase yours is slightly different.
Post the entire number so I can look it up. Sticker should be under your seat.
Pinion gear failures are caused by something. So check all bushings and joints in the steering and front-end.
If you have any questions please ask.
Walter
walter g is offline
post #5 of 5 Old 09-25-2009, 08:25 AM
You may try either a short phillips or a 90 degree phillips for cramped spaces works well. Ideal if someone was holding the steering wheel to remove these.
Troybilt Fanatic is offline
