EZ VAC Restore - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 48 Old 04-11-2012, 12:54 PM Thread Starter
Bolens 1886-01
ed-nh's Avatar
EZ VAC Restore
I started working on my ez vac model 70 restoration. This is the 8HP version, the big one! The engine purrs like a kitten so all I am doing is taking off the periferials, changing fuel lines, filters, oil, clean degrease, prime and paint. Her is what I have so far. Once the engine is complete I'll start on the trailer and sides. This should be a pretty straight forward restoration. I'll update as I move along.
ID:	207956   Click image for larger version
ID:	207957   Click image for larger version
ID:	207958   Click image for larger version
CLICK HERE
Restored:
853, 900, 1556, custom twin 1856, 1886, 1967 1250, 1955 Versamatic, 1957 Super Ride-a-matic, 2 DGT 1700's.
Restored:
Lots of attachments!
ed-nh is offline
post #2 of 48 Old 04-11-2012, 01:14 PM
BOSMECH's Avatar
Re: EZ VAC Restore
Sounds like the right time to do it because as you know fall will be here in New England soon enough and so will all the leaves on the grond. : (
BOSMECH is offline
post #3 of 48 Old 04-11-2012, 06:05 PM Thread Starter
Bolens 1886-01
ed-nh's Avatar
Re: EZ VAC Restore
Here are a few more pics. From all the paint I could find on the starter and starter guard it was gold so that is what I went with. Looks good even if not the right color.
ID:	207983   Click image for larger version
ID:	207984   Click image for larger version
ID:	207985   Click image for larger version
CLICK HERE
Restored:
Restored:
ed-nh is offline
post #4 of 48 Old 04-11-2012, 08:09 PM
Deerlope's Avatar
Re: EZ VAC Restore
It is looking mighty good Ed!!!!!!!!!!!!!
"1886 Upper Heat Shrouds Available"
Operational 2486, 1256 w/ sickle bar mower Kubota RTV900; Kubota M-5040; B-2650 Kubota, JD332 diesel
]Deerlope's Bolens on YouTube[
Till the soil til I am soil.
Deerlope is offline
post #5 of 48 Old 04-12-2012, 09:04 AM
BOSMECH's Avatar
Re: EZ VAC Restore
That looks great.
BOSMECH is offline
post #6 of 48 Old 04-12-2012, 12:40 PM Thread Starter
Bolens 1886-01
ed-nh's Avatar
Re: EZ VAC Restore
I'm not liking the red tank straps. They may come back off and go with white or black. I'll have more pics soon now that it is all back together. Next will be all the blower tins and mounting supports.
CLICK HERE
Restored:
Restored:
ed-nh is offline
post #7 of 48 Old 04-13-2012, 07:54 PM Thread Starter
Bolens 1886-01
ed-nh's Avatar
Re: EZ VAC Restore
All done with the blower and engine. Here's a few more pictures. Will start on the trailer and sides next
ID:	208347   Click image for larger version
ID:	208348   Click image for larger version
ID:	208349   Click image for larger version
CLICK HERE
Restored:
Restored:
ed-nh is offline
post #8 of 48 Old 04-13-2012, 09:26 PM
Deerlope's Avatar
Re: EZ VAC Restore
Ed, Does the blower and engine mount onto the rear of the tractor or tongue of the trailer?
Deerlope is offline
post #9 of 48 Old 04-16-2012, 07:58 PM Thread Starter
Bolens 1886-01
ed-nh's Avatar
Re: EZ VAC Restore
I made a special adapter that goes onto the tractor, mounts on the transaxle tabs. Then this engine and mount assy hang off of that and the trailer connects onto it. I'll post some pictures of the mount. It came from a Bolens 1600 so I needed to modify it to work on my tube frame. Stay tuned for some pictures.
CLICK HERE
Restored:
Restored:
ed-nh is offline
post #10 of 48 Old 04-16-2012, 08:56 PM
Re: EZ VAC Restore
looking real good so far!
G154
2 1256-01
1 1050
oldmossinger is offline
post #11 of 48 Old 04-16-2012, 09:55 PM
OldBuzzard's Avatar
Re: EZ VAC Restore
Ed, I have an EZ-Vac mounted on one of my 1256s.
Would you like for me to post pics of what that mount looks like?
Bolens TF: 800, G10-04, G11-01(3), 1256-02(2), H14-02
Bolens LF: 1886-01 w/FEL, 1886-01 w/Forklift, 1886-01, 1886-02, 1250-01 (2), HT20D, HDT1000.
Bolens Estate Keeper 7
Attachments: More than I can list.
OldBuzzard is offline
post #12 of 48 Old 04-17-2012, 07:03 AM
Deerlope's Avatar
Re: EZ VAC Restore
Well of course, we all like seeing pic's of any type.
Fred
Deerlope is offline
post #13 of 48 Old 04-17-2012, 07:50 AM Thread Starter
Bolens 1886-01
ed-nh's Avatar
Re: EZ VAC Restore
If you look at that black adapter it is the one that came with the 1600. The base was a home made piece that I salvaged from another tube frame that someone made. It hooks to the transaxle tabs using the 1/2" clevis pins. The uprights were some scrap that I cut and welded in place. The horizontal piece connecting the two uprights is the original Bolens ez vac mount. I cut it off of the old base and welded it in place on the uprights.
Now, the white engine base rests in the two uprights in those little slots. Then there is a 3/4" bolt that connects the white engine base to the black base. Then on the white base there is another tab with a 1/2" hole where the trailer receiver connects. If you look closely on the white base you will see the 3/4" bolt on one end and the 1/2" hole on the other end for the trailer. It took a bit of time to get all the measurements correct but all in all it is a pretty good setup.
ID:	208941   Click image for larger version
ID:	208942   Click image for larger version
ID:	208943   Click image for larger version
CLICK HERE
Restored:
Restored:
ed-nh is offline
post #14 of 48 Old 04-17-2012, 11:35 AM
OldBuzzard's Avatar
Re: EZ VAC Restore
Looks good Ed.
Here's what the original mount for a tube frame looks like when it's mounted on the tractor.
ID:	208967   Click image for larger version
ID:	208968   Click image for larger version
post #15 of 48 Old 04-17-2012, 12:54 PM Thread Starter
Bolens 1886-01
ed-nh's Avatar
Re: EZ VAC Restore
Originally Posted by OldBuzzard View Post
Looks good Ed.
Hi Old Buzzard, you were kind enough last year to send me a lot of pictures and even some literature on this. I thank you for the pictures. I did use your pictures as a guide when I built my base. The only original piece on my base is the thing with the slots in it. I'm anxious to have it done and see how it works. I wonder if I can get the decals that went on the blower. The previous owner painted over them and I could not restore them I tried.
CLICK HERE
Restored:
Restored:
ed-nh is offline
