Any ideas for easily mounting the mower deck? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Register Home FAQ Garage MTF Gallery Search Today's Posts Mark Forums Read Store Chat Room
Old 02-19-2012, 12:25 PM   post #1 of 14
C2H8O's Avatar
MTF Member # 24612
Images: 7
Default Any ideas for easily mounting the mower deck?
Anyone have ideas for installing and removing the mower deck? Ramps or something? A dolly to slide it into place?
I have an H14 tube frame. I find it very bothersome to drag the heavy mower deck sideways under the tractor. The lift link also sticks up, so I must disconnect and re connect it. I have tried jacking the front end, but the floor jack just barely fits between the PTO and cast axle - it has occasionally slipped off. And I still gott drag the deck sideways.
__________________
DougL
C2H8O is offline   Reply With Quote Quick reply to this message
Old 02-19-2012, 01:00 PM   post #2 of 14
MTF Member # 64330
Default Re: Any ideas for easily mounting the mower deck?
This don't help with the dragging, but you could drive onto wooden blocks to help with the clearance issues and it can't fall. I have seen vids of folks driving right over decks to install, I have not tried this myself though.
qub qadet is offline   Reply With Quote Quick reply to this message
Old 02-19-2012, 02:30 PM   post #3 of 14
Deerlope's Avatar
MTF Member # 20931
Find a place for an overhead lifting point and lift the front by means of a strap or rope then nothing will be in your way.
__________________
"1886 Upper Heat Shrouds Available"
Operational 2486,1886: 1455; 900;DGT1700, Kubota RTV900; Kubota M-5040; Kubota excavator KX 057; B-2650 Kubota, JD332 diesel
]Deerlope's Bolens on YouTube[
Till the soil til I am soil.
Deerlope is offline   Reply With Quote Quick reply to this message
Old 02-19-2012, 10:38 PM   post #4 of 14
tube frame hunter
MTF Member # 67800
I drive the fronts on 2 4x4's so the wheels are just at the edge then turn the front wheels all the way to the right and slide deck under from the right so the lift arm doesn't have to go under the tractor and get hooked,I do it on the asphalt so I don't tear up the grass "dragging" the wheels. Steve!!
stevie p is offline   Reply With Quote Quick reply to this message
Old 02-19-2012, 10:45 PM   post #5 of 14
MTF Member # 17818
I have at least 6 year of college (SQL Programmer) and every spring I used to drag the 54" deck under the HT. One spring I just got smart and I found out lifting the front of the HT from a overhead beam.. Right in and right out.
mike@trrap.com is offline   Reply With Quote Quick reply to this message
Old 02-20-2012, 09:03 AM   post #6 of 14
C2H8O's Avatar
MTF Member # 24612
Images: 7
Find a place for an overhead lifting point and lift the front..
Thanks! Note to self - get pulleys or hoist from local Harbor freight.
__________________
DougL
Old 02-21-2012, 06:34 AM   post #7 of 14
dt1050's Avatar
MTF Member # 61425
Images: 3
I have a 48" on my 1050 and I have my 16 year old son remove the mower deck....lol
__________________
Just cause it's orange don't make it a tractor, the one and only real orange tractor, Allis-Chalmers.
1980 Allis Chalmers 5020 4x4
430 Allis Loader
67 bolens 750
dt1050 is offline   Reply With Quote Quick reply to this message
Old 02-21-2012, 08:56 AM   post #8 of 14
MTF Member # 34589
ive prob been taking off the deck and putting it back on my dads 1050 since i was 10
its pretty easy
we have some 6x6s on the edge of the stone walk holding the stone in
i just drive up onto one of them with the front wheels
and slide the deck in from the side
and hook it up one corner at a time
simple
easy
*Ryan is offline   Reply With Quote Quick reply to this message
Old 04-11-2012, 07:32 PM   post #9 of 14
MTF Member # 64738
get a slip sheet a carpet man uses its plastic and a piece of cardboard two times as long as the deck they slide easy that way
yes i know its old
but this works
john
no2498 is offline   Reply With Quote Quick reply to this message
Old 04-11-2012, 11:16 PM   post #10 of 14
MTF Member # 177
Get another tractor. Install the deck once. One tractor with a snowblade, too. One for the snowcaster. One for the tiller....well, that's my dream, anyhow....
mrcaptainbob is offline   Reply With Quote Quick reply to this message
Old 04-12-2012, 06:14 AM   post #11 of 14
Deerlope's Avatar
MTF Member # 20931
Don't laugh and don't make it a dream because that is what has happened to me. 6 Bolens tractors all ready for work. I got to be nuts at least the wife thinks so.
__________________
Old 04-12-2012, 08:22 AM   post #12 of 14
BOLENSBOY60's Avatar
MTF Member # 37707
BEST DEAL i have found- is getting one of those game hiosts from cabelas- they can be had for a couple hundred with free shipping find a likely spot to mount it- get your self a 4 x 4 or chunk or channel iron or square tubing to run across your ceiling joists- these are a great value for the money- work dandy for hanging your deer too!
BOLENSBOY60 is offline   Reply With Quote Quick reply to this message
Old 04-12-2012, 12:17 PM   post #13 of 14
Deerlope's Avatar
MTF Member # 20931
When it comes right down to it the best way is to have someone else do it.
__________________
Old 04-12-2012, 12:37 PM   post #14 of 14
Bolens 1886-01
ed-nh's Avatar
MTF Member # 29037
I use floor jack on the front axle. I have also used the 2x4 trick too but find the floor jack easier.
__________________
CLICK HERE
Restored:
853, 1556, 1556 Loader, custom 1856, 1669, 1886, HT23
Restored:
tillers, 3pt, sleeve hitch, E-Z Vac, mowers, single & 2 stage blowers, moldboard, front and rear pto chippers/shredders, wheelbarrow attachment, aerator
ed-nh is offline   Reply With Quote Quick reply to this message
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.6.1
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Compact Tractor Reviews Tractor Reviews Snowblowers Lawn Mower Forum
My Tractor Forum Snow Thrower Power Equipment Forum
Combine Forum Snowblower Forum ATV and UTV Reviews
