Bolens 1256 hydrostatic questions - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 25 Old 06-19-2011, 08:53 AM Thread Starter
Tractor enthusiast
Looknlearn's Avatar
Images: 9
Brought home a 1256 -07 Bolens Husky yesterday and I adjusted the carb and the Wisconsin engine started right up. I had the option between a 6 speed and the hydrostatic but I chose the hydrostatic cause I would be mowing, snowblowing, and tilling with it. Was it a bad idea to go with the hydrostatic? Are they good and durable transmissions?
My other questions is, is that it doesn't have much power going slow. It will slowly move along then when it hits resistance it stops and makes noise like something is slipping. The belts and drive shaft are not slipping from what I can see. Is this normal? Are there seals that wear out and can be repaired? or do I have to fork over another pile of money for a replacement transmission?
Tucker
One '53 Economy King in a constant state of improvement(Avatar)
One 1256 Bolens Husky with a mower, and 3ft tiller and a 1253 with 2, 3ft snow blowers.
1995 F150 XL 4.9 liter 5 speed
Looknlearn is offline
post #2 of 25 Old 06-19-2011, 01:16 PM
JustinR's Avatar
Re: Bolens 1256 hydrostatic questions
You made a good choice. Have you checked the hydro fluid in the tank under the seat pan? There is a cap right in front of the seat. Make sure also that you have the throttle wide open. The hydro system has full charge at full throttle. Lastly, make sure and change the hydro filter.
Original Bolens 1250 - Restored Bolens HT-18 - 1386 Water Cooled Yanmar Diesel Loader w/ Powersteering - Restored FMC Bean Cutler - Project 1477 - Troy Bilt GTX 20
http://huskylargeframes.blogspot.com/
http://www.youtube.com/user/jtube76?feature=guide
JustinR is offline
post #3 of 25 Old 06-19-2011, 09:01 PM
Cam-Shaft's Avatar
Ditto
Romans 1:16 "For I am not ashamed of the Gospel of Christ..."
Bolens HT-23S power steering, Cruise control, Transmission cooler.
Bolens HT-20 w/ARK 500 FEL and 3pt hitch
Bolens 1050 pulling tractor (Wisconsin THD)
Bolens 800, rebuilt engine.
Cam-Shaft is offline
post #4 of 25 Old 06-19-2011, 09:02 PM
jason4567's Avatar
Those hydro's are bulletproof. The 1256 uses an eaton model 10. As long as the fluid level is maintained and you don't overheat it, it will last forever.
Be sure and clean the fins on the hydro unit (where the driveshaft goes). They get caked with dirt and oil and this can lead to overheating. Also make sure that you still have a driveshaft fan.
Jason
Bolens
Tube Frame: 600, 800 (2), 900 (2) 1000, 1050 (4), 1225, 1254 (2), 1256, G14, H14
Large Frame: 1250 (5), 2086
Others
Bolens RAM, Bolens FS-11, Copar Panzer, Sears SS12, Sears Custom 6, Gravely LI, L8, L, Comm.10a, Farmall Cub
jason4567 is offline
post #5 of 25 Old 06-19-2011, 10:32 PM Thread Starter
Tractor enthusiast
Looknlearn's Avatar
Images: 9
Thanks for the replies. Hydro fluid looked good. I didn't have the throttle all the way up cause it was late and that thing is LOUD. I can try to get pictures tomorrow but I am leaving for a few weeks starting tomorrow. My brother may be on my account here to ask a few questions cause he is gonna be working in it. I wish I am gonna be tinkering on it as well. The hydro still has the cooling fan and the fins don't look clogged up.
I managed to get the hydro filter off by jamming a screwdriver through it cause nothing else would work. I think I'll slowly turn the hydro to flush the old fluid out while the filter is off. The fluid didn't look bad but I'd thought I'd do it anyway. What filter do I use as a replacement? Will any filter work?
Is there are place to get replacement brake pads?
Can't wait to get this thing running. I sure like the thought of hydraulics. I am having second thoughts about leaving the tractor other behind.
Hopefully I'll get you guys some pictures before I leave.
Tucker
post #6 of 25 Old 06-20-2011, 10:23 AM
elsimon's Avatar
NAPA has a filter that will work.
Don't let your brother have all the fun. Great little machine that will give you lots of hard work.
GT_80 Fan Club Member #0003
Everything drives me crazy . . . it's a short drive.
Bolens 1256
Front plow, tiller w/ extn.
Sears '77 18/6 Twin "The Ghost" (she just appeared)
Sears '72 SS15 "Smurfette" (PO painted Smurf Blue) - Need: air cleaner cover
42" Deck(2), Front Plow(3), Seeder, Sickle Bar, 3pt Hitch(2), Moldboard(2), FEL, 220# Wgt Box, 175# 3pt Wgt Attach, 50# Wheel Weights(4), 2 Link Chains(2 sets), 3pt Tiller (converted from WB), Lawn Roller.
elsimon is offline
post #7 of 25 Old 06-20-2011, 11:34 AM Thread Starter
Tractor enthusiast
Looknlearn's Avatar
Images: 9
OK
It doesn't look like I'll have time to get you'all some pictures before I leave but I told my bother to make sure to get some for you guys. He will probably be on here for advice from time to time. Thank you for the advise so far.
EDIT. The departure was put off till tomorrow so I'll get you'all some pics.
Tucker
Tucker
post #8 of 25 Old 06-20-2011, 03:01 PM Thread Starter
Tractor enthusiast
Looknlearn's Avatar
Images: 9
Here are the pictures.
Tucker
post #9 of 25 Old 06-20-2011, 03:04 PM Thread Starter
Tractor enthusiast
Looknlearn's Avatar
Images: 9
Some more.
Tucker
post #10 of 25 Old 06-20-2011, 03:07 PM Thread Starter
Tractor enthusiast
Looknlearn's Avatar
Images: 9
And more.
Only rear problem the tractor seems to have other than very worn steering spindles.
Any tricks for the loose and worn steering spindles? The one wheel turns about 6 inches before the other one moves.
The snowblower chute I have. Just need it reattached.
Tucker
post #11 of 25 Old 06-20-2011, 03:11 PM Thread Starter
Tractor enthusiast
Looknlearn's Avatar
Images: 9
Last few.
I do have the attachment parts for the tiller but not the lift rod to the hydraulics.
Tucker
post #12 of 25 Old 06-22-2011, 02:01 PM
Bolens 1886-01
ed-nh's Avatar
Those pictures look great. The tractor overall looks to be in really nice condition. See just where the play is on the spindles. Sometimes it is just a worn spring pin. Mine was very sloppy and I replaced the pin that goes through and it tightened it up pretty good for only a buck. I am working on an eaton10 right now. I'll post some pictures of the internals for your viewing pleasure. They are certainly well built.
CLICK HERE
Restored:
853, 900, 1556, custom twin 1856, 1886, 1967 1250, 1955 Versamatic, 1957 Super Ride-a-matic, 2 DGT 1700's.
Restored:
Lots of attachments!
ed-nh is offline
post #13 of 25 Old 06-22-2011, 02:18 PM Thread Starter
Tractor enthusiast
Looknlearn's Avatar
Images: 9
It is definitely the steering spindle that is worn the hole through the spindle is rather oval shaped. I compared the diameter of the spindle bolt to the one in the parts diagram it appears that the PO already drilled it out bigger. It looks like i'll have to buy some replacements.
Tucker
post #14 of 25 Old 06-22-2011, 03:13 PM
ratboy's Avatar
Is that a crack in the pto just below the top bolt hole? or a shadow?
Steering spindle being worn out is a testiment to that particular tractor's reliability. The 1256 is considered by most to be the best tube frame Bolens built. That one has obviously had some hours put on it. Not to worry, it looks like it has plenty left to give. Keep your ear to the ground, someone in your neck of the woods will see you on it and start talking about others they have seen or own that are parts tractors. Keep an eye out for any H-14's or h-16's. They have techumseh engines on them and the engine usually wears out long before the tractor ( I'm going to catch some grief for that statement from the tech owners, sorry). They front ends on the tube frames were all the same. If you can't wait that long, put an inch of weld on the spindle where it meets up with steering arm. Make it easy to undo, should you ever need to take it apart.
ratboy is offline
post #15 of 25 Old 06-22-2011, 09:05 PM Thread Starter
Tractor enthusiast
Looknlearn's Avatar
Images: 9
[QUOTE=ratboy;1763922]Is that a crack in the pto just below the top bolt hole? or a shadow?
Yes that is a crack. I haven't had time to really think about it because my full attention has currently been on the hydro.
I drained the fluid in the hydro, which BTW takes forever, and changed the filter.
When I tried to refill it, it would only take 1 quart. I have heard that it should need about 4 quarts. I read in the manual that there could be an air pocket so I tried what they recommended: running the tractor on idle while pumping the travel pedal back and forth. Is the tractor supposed to move while doing this? Mine didn't. I only tried this for a short time for fear of ruining the transmission.
Do you have to do this for awhile before the fluid level will go down?
Is there a better methods for getting air pockets out?
Emailed sambolens asking about steering spindles. He responded today saying he has them for $65 each which seems like allot to me. Maybe i'm just to stingy. Not sure what I will do. Since someone already drilled the spindles bigger then if I replace them I will need to also replace the piece that the tie rod attaches to.
Tucker
