Bolens 1050 keyswitch ? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 11 Old 01-17-2011, 07:06 PM Thread Starter
farmerall's Avatar
Images: 11
The other day I was trying to start my 1050 and one of the poles broke broke off of the back of the switch. It is the switch that has three poles on it. One for ingnition, one for the starter and one for the battery. I tried to find one at the local Napa but the only three poled switchs they had were for magneto ignition. Does anyone know were I can get a new one or a part number so I can take it to Napa to have them look it up.
Thnaks Matt
farmerall is offline
post #2 of 11 Old 01-17-2011, 07:12 PM
New2Bolens's Avatar
Re: Bolens 1050 keyswitch ?
Try thhttp://www.psep.biz/store/troy_bilt_...ical_parts.htm
is site
New2Bolens is offline
post #3 of 11 Old 01-17-2011, 10:15 PM
BOLENSBOY60's Avatar
that sounds like the wrong ing switch for the 1050- does it have a push button starter switch on it? should be 5 spades on the back i `m pretty sure
BOLENSBOY60 is offline
post #4 of 11 Old 01-18-2011, 04:30 AM
teapot's Avatar
I have been layed up with a new hip and a bad knee, but I will see if I can get the part number for the switch. I also think it a 5 bladed switch. What does the wiring diagram show?
thanks teapot
teapot is offline
post #5 of 11 Old 01-18-2011, 05:32 AM
sam
67bolens"ek10"'s Avatar
my 1050 has a 3 terminals on the switch an its all original.
67bolens"ek10" is offline
post #6 of 11 Old 01-18-2011, 09:18 AM Thread Starter
farmerall's Avatar
Images: 11
I believe that it is the original switch since the tractors wiring seems to be untouched or modified. Also my 850 has the same switch in it and the wiring is original to it.
post #7 of 11 Old 01-18-2011, 10:39 AM
i think it depends if your engine is a tr-10d or a TRA-10D
post #8 of 11 Old 01-18-2011, 02:26 PM
I have a tr 10d .the switch has 5 poles but I only use three poles to make run.
gray wolf is offline
post #9 of 11 Old 01-18-2011, 02:38 PM
sam
i have a tra-10d in my 1050. my 850 is a s-8d and i think it has the same switch. pretty sure the 650 does also an that has a b&s.
post #10 of 11 Old 01-18-2011, 06:53 PM
29 Chev's Avatar
Attached are the wiring diagram for a 1050 Bolens ignition switch with battery ignition and the Napa cat page of two switches which will probably work but you would have to change the wire ends from eye to spade terminals and only use the B,I, and S terminals - 7-01854 and 7-01892 -(diffferent diameter mounting stem - 9/16" or 5/8"). At the bottom of the wiring diagram page it shows the connections of the orignal switch in each position ( I=ignition B=battery S=solenoid) off - no connection, on - connection from battery to ignition, and start - connection from battery to ignition and solenoid. Double check with an ohmmeter to verify the circuits work the same before buying or installing - hope this helps
29 Chev is offline
post #11 of 11 Old 01-18-2011, 10:45 PM Thread Starter
farmerall's Avatar
Images: 11
Thanks for all of the help. I got a switch with 5 posts and plan to only use the three I need.
