Bolens ridemaster ID - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 26 Old 05-02-2010, 10:31 PM Thread Starter
TroyM's Avatar
Hi, I have a Bolens ridemaster and I want to know what year it is. I looked over at sonys http://sonnys_bolens.tripod.com/identifythis.htm
but I am not matching up anything but a few numbers can anyone tell me the year from this image? http://www.tscyber.com/bolens/brm.jpg
Also anyone know what the original engine was? I know Wisconsin but was it a aks? I am finding a bunch on ebay but want to make sure its right.
TroyM is offline
post #2 of 26 Old 05-02-2010, 10:40 PM
Moved on....
wilberj's Avatar
Re: Bolens ridemaster ID
Hello to another ridmaster guy.
I cant help much on the year but there is some other guys that should see your post and help you.
My Bolens
Tube frame-600, 650, 850, G9, 1000, 1050, 1254, 1254, 1220, G14, 1556
Large frame-1250-0?, 1250-02, 1455-01, 1455-02, 1476-01, 1477-01, 1886-prototype, 1886-01, 1886-02, 1886-03 With FEL, 1886-04, 1886-04, 1886s-05 (HT18) Cat, 1886s-06 (HT18), 1886s-06 (HT18), HT-20, HT-20 With FEL and Backhoe,
5 Ridemasters, Bean Cutler, Ride a matic, 3 Power ho
26 Suburban, 510, 610, 775, Estate Keeper
wilberj is offline
post #3 of 26 Old 05-02-2010, 10:51 PM
oldron's Avatar
Try the Ridemasterclub on Yahoo,lot of knowledge there.
Ron
If its rusty and free its for me
oldron is offline
post #4 of 26 Old 05-02-2010, 11:17 PM
Eleven Year Site Sponsor
I cannot make out the full model number. Is it 35AB01? If so, it is from 1948-49. Mine is a 35AB01 and has the Wisconsin AKS engine. Bolens changed to the Wisconsin AKN at serial number R 4000 during the 35AB02 model run, most likely in September 1950, although documentation is sketchy and contradictory.
I have read that there is no significant difference between the AKS and AKN engines, but I don't know that from personal experience.
Sonny's listing of Ridemaster engines is almost completely incorrect. Don't know where they got their information, but it does not match the early factory literature. It may be that their listing came from a later replacement engine list from Bolens.
Doug
Bolens:1254, G14, H14, Whirly Rake, generator; 1250 (2), 1455, 1886, HT20, HT20D, HT23 (4), typical attachments, Bulldog trencher, Danuser post hole digger, Haban Sickle-Mo, Johnson FEL & forklift, Brantly backhoe; Cozy Cab; GK (2) 72" decks, dozer blades, snowblower; Ridemaster 35AB01, sickle mower, disc harrow, grader, hitch; Power Ho (3), sulky, snowcaster, air compressor
Bush Hogs: D4-7, D4-10 (parts), D4-12, plow blades & MMM (Want the 42" trail mower!)
Massey Ferguson: MF12 (1967), MMM
LPBOLENS is offline
post #5 of 26 Old 05-02-2010, 11:20 PM
Moved on....
wilberj's Avatar
Post Re: Bolens ridemaster ID
Originally Posted by LPBOLENS View Post
I cannot make out the full model number. Is it 35AB01? If so, it is from 1948-49. Mine is a 35AB01 and has the Wisconsin AKS engine. The engine was changed to the Wisconsin AKN at serial number R 4000 during the 35AB02 model run, most likely in September 1950, although documentation is sketchy and contradictory.
Its 35AB02.
My Bolens
wilberj is offline
post #6 of 26 Old 05-02-2010, 11:21 PM
As a 35AB02 before serial number R 4000, it should have the AKS engine.
Doug
LPBOLENS is offline
post #7 of 26 Old 05-02-2010, 11:34 PM
Good information on Wisconsin engines on this site:
http://my.att.net/p/s/community.dll?...pid=256080&ck=
Apparently the "S" suffix means higher speed and the "N" higher compression.
Mike
Tencubed is offline
post #8 of 26 Old 05-03-2010, 12:34 PM Thread Starter
TroyM's Avatar
Thanks, So its a 1950 with aks engine? I am not seeing aks on that list of engines did you mean akn
2-7/8 X 2-3/4
6.2 @ 3600
1949-1955
TroyM is offline
post #9 of 26 Old 05-03-2010, 01:27 PM
The original engine was an AKS if your serial number is less than 4000 (and it is). Some other references to the engines used show the Bolens-authorized replacement engine (should the original fail for some reason).
And I did mean AKS as noted in an earlier post. According to the Bolens engineering change listing that I have Bolens began using the AKN engine at Ridemaster serial number 4000. Either engine will work just fine.
Doug
LPBOLENS is offline
post #10 of 26 Old 05-03-2010, 01:34 PM Thread Starter
TroyM's Avatar
Ok thanks. aks must be hard to find but would like to have that then. I am finding akn. This looks like a good one if he will ship it. http://burlington.craigslist.org/grd/1715832377.html
TroyM is offline
post #11 of 26 Old 05-03-2010, 09:33 PM
Lindeman crawler fan
jdcrawler's Avatar
According to the information that I have, Type 35AB02 ser. #R 3025 would be a 1949 model and as LPBOLENS said, it should have a AKS engine.
The front tires are 5:50Ox16. New tires of the correct size and lug pattern are being re-manufactured by the Miller Tire Co. ( they list them on ebay also )
The rear axle bar is welded to the center tube frame on this model.
LPBOLENS mentioned that documentation is sketchy and contradictory and he is certainly right about that.
The information I have shows that the engine was changed to the Wisc. AKN engine (Ser. 1273901) starting with ser # R 4300 per engineering change revision dated 3-21-50.
( I believe his information shows R 4000 for the engine change. )
Ray
1949 Agricat crawler
( 3 ) 1948 Bolens Ridemasters type #35AA01
1939 Viking / Standard Twin
1962 Panzer model T70
"R/T" home made tractor
jdcrawler is offline
post #12 of 26 Old 05-03-2010, 11:05 PM
As Ray points out, whether the engine change occurred at R 4000, or at R 4300, your 35AB02 should have the AKS engine.
If you want to see a really beautiful Ridemaster, check out Ray's restoration threads here for his 35AB.
Doug
LPBOLENS is offline
post #13 of 26 Old 05-03-2010, 11:06 PM Thread Starter
TroyM's Avatar
Thanks, Yeah it has the 16 inch tires. If it was not for one finger sized hole in the tread I would keep the ones on it there not in bad shape at all for there age. Anyone have any leads on a aks engine? I want find something cheap to build myself.
I was also told that implements was tough to find is that true? I just want the grader blade and was thinking if I find a plow like one from these from a tractor I could make the bracket myself if I had to.
TroyM is offline
post #14 of 26 Old 05-04-2010, 09:04 AM
jdcrawler's Avatar
Troy
I think the grader blade is probably the most sought after implement for the Ridemaster.
I bought a 53 Ridemaster a couple of years ago that was missing engine, engine cradle, both drive pulleys, gas tank and had the wrong rear wheels.
It did have the grader blade, garden plow and (1) cultivator disc.
I was not able to find the missing parts to restore the tractor so I sold the implements on ebay last fall.
The grader blade alone sold for 3-times more than I paid for the whole tractor.
By the way .. how about some photos of your Ridemaster ??
Ray
post #15 of 26 Old 05-04-2010, 10:24 AM Thread Starter
TroyM's Avatar
Yeah the guy I got this off of bought it just for the blade. I'll have to take some measurements and see if I can make one. If I can find a blade close I should be able to replicate the rest.
Yeah I posted some on me and my wife's site last night I may get started working on it if I can stop playing on it lol..
http://www.tscyber.com/bolens/ride/ridemaster.html
TroyM is offline
