Bolens 1886 Custom Wheel Project- Done! - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 19 Old 03-20-2017, 12:09 AM Thread Starter
Senior MTF Pollster
Austen's Avatar
Images: 33
Talking Bolens 1886 Custom Wheel Project- Done!
Briefing:
If you by chance saw my teaser a few weeks back, you'll remember that I had been working on a custom wheel project and was nearing completion. Here's the link: Bolens Custom Wheel Project: Teaser
Mounting:
This project wouldn't have been possible without Lenny, the owner of Motorsport Tech, who I have build all my wheel adapters & spacers for my projects. The adapters are made in the USA, have a lifetime warranty, anodized, are hub centric with no cost spared in quality. These things aren't cheap.
The rears:
The rear wheels are where it gets fun and all the magic happens. While I've had a lot of spacers made in the past, I've never actually gone from one bolt pattern to another so I got to learn about a new type of adapter. In this case where going to call them spacer-adapters.
The spacer-adapters themselves are 2-piece- (apparently a design created by them as Lenny explained) because we're going from one bolt pattern to another- 6 lug to 8 lug so it would be impossible to have a one-piece design in order to access the lug nuts on the hub side- (it makes more sense if you see this in person).
(The slight discoloring you see is simply some smeared anti-seize)
I love this shot!
The way it works is you bolt one half to the hub the wheel hub, and then the second half of the adapter slides on via two dowel pins and then is bolted on via 8 included allen bolts. The total thickness of the rear spacer-adapters are 1.5" and are the thinnest possible Lenny could make them in this configuration. I could've purchased these same rims in a 6-lug design but they still would not have been the 6x6 lug pattern and rather 6 5.5" lug pattern requiring the same type of spacer-adapter. I chose the 8-lug pattern for extra uniqueness and also to coincide for fun with one of my other hobbies, diesel trucks.
The Fronts:
The fronts are pretty simple as the new rims share the same lug pattern and size as the originals. They however have less backspacing than the factory rims so due the bigger tires, they needed to be spaced out more to prevent rubbing. The front spacers are 3".
Impressions:
It certainly has different vibe to it for sure. The 29's which are closer to 30" than 29" are a big jump up from the 26s's that measured closer to 24.5" that were on before; they really filled up the large gap between the fender and tires. So far it seems to work fine and still be as functional for what I use it for which was the goal despite it being a little wider which has its advantages & disadvantages. I had the front spacers made to a spec to not allow rubbing on the front and little things like that I think made the difference in order for it to work. Will I keep this setup forever? Who knows, I might even switch it up something different in the future. At least there is the original wheel set to go back to that can be bolted back up easily.
Stock Dimensions:
(The dimensions were taken from the top of the hood in the front, below tail light in the rear and the outside wheel widths. This doesn't really matter though as it's the actual differences which do for a simple comparison sake here.)
Front Height: 41"
Rear Height: 22.6"
Front width: 43"
Rear: 46"
Current Dimensions:
Front Height: 42.5" (1.5" increase)
Rear height: 26.25" (3.65" increase)
Front Width: 47" (4" increase)
Rear Width: 49.5" (3.25" increase)
What is it like to drive?
Well, to be honest, not really much different. If I were blindfolded and asked which wheel setup it had, it wouldn't be as apparent as you might think. The thing I notice most is that it's a little speedier. In comparison before, it felt like it was always in "granny gear" while now it feels like it's in 1st. Basically it takes less pedal travel to go faster is the best way I'd describe it. The difference is subtle but I'd say you have to be a little more mindful with your foot when maneuvering around tight areas because less pedal travel does more work so to speak. You would assume the steering wheel would be night and day heavier with the spacers and bigger font tires, right, but it is not much different.
I guess the other thing I'd add is that it has a firmer ride. The 26" Tru Powers on it before were 4" ply and had a lot more give to them; in fact it was basically like riding on big cushy marshmallows as they were always squished down and would even develop flat spots after a while if you let the tractor sit for a while. The 29's are firmer and a lot more stout in that regard. I could see this potentially being a detriment, but time will only tell. The good news is that there is even more weight in the back (the rears took 20 gallons each of RimGuard compared to the 11 gallons in the 26s and should equal out to about what they did with the weights too given the significant increase in fluid) and the Tru Powers themselves are a soft compound. The tractor seems to have quite a bit less rolling resistance because of it. The parking brake has to be used more. You could not push the tractor in neutral simply because it was like pushing with flat tires in the rear; now you can. Just observations that you can take as you please.
Alright, enough about wheel spacers, let's back this little beast out of the trailer and have a photoshoot!
1971 Bolens 1886-01 Resto-Mod
Kohler CH22 V-Twin
Custom wheel set
Johnson Workhorse 14 loader
Gannon Earthcavator
Tiller
3pt hitch
1977 Economy Tractor
Hydraulic lift conversion
48" Belly mower
3pt hitch
"We donít look at the troubles we can see now; rather, we fix our gaze on things that cannot be seen. For the things we see now will soon be gone, but the things we cannot see will last forever." - 2 Corinthians 4:18
Austen is online now
post #2 of 19 Old 03-20-2017, 01:50 AM
Scott.O's Avatar
Re: Bolens 1886 Custom Wheel Project- Done!
that is a beautiful job. It would almost be sad to put it to work. nice going thanks for the pics...Scott
QT-17 48"deck, 6' utility dump trailer
Scott.O is offline
post #3 of 19 Old 03-20-2017, 02:48 AM
TractorNewb
Clevis's Avatar
Good stuff, Austen. One sweet 1886!
HT20, HT23, G11, G14
Clevis is offline
post #4 of 19 Old 03-20-2017, 06:32 AM
Booo
BOSOX's Avatar
Images: 14
The machine looks great with the new wheels and tires, Austen. The rears sure do fill the wheel wells. Quite a machine!
Mike
JD 214 w/ 39 Deck and Plow Blade (Long term project)
JD S82 RER w/ Bagger
BOSOX is offline
post #5 of 19 Old 03-20-2017, 06:33 AM
munderhill's Avatar
Images: 7
Very, very nice tractor. What are your plans for counter weight?
MU
munderhill is offline
post #6 of 19 Old 03-20-2017, 08:52 AM
Imagine it. Build it.
tiretrx's Avatar
Images: 8
Love the look, Austen. Some kind of beautiful machine. My compliments, sir!
.....just call me Ellis
I was abandoned as an infant and raised by a family of opposums........does that explain things?
tiretrx is online now
post #7 of 19 Old 03-20-2017, 09:15 AM
Ericjr16's Avatar
Sweet Austen! Tractor porn right there! Now ship it over to NY so us fellows can clean up, right Ellis?!
Challenge Met
John Deere 180 with two bin bagger
1997 John Deere 345
1971 Bolens 1256 snow caster
1996 Craftsman GT6000 snow blower
1980 Wheel Horse C-85
1967 Sears Suburban SS10
Many more!! changing by the day!!
John 3:16 Psalm 28:7
"Complain and remain, praise and be raised!
Ericjr16 is online now
post #8 of 19 Old 03-20-2017, 09:16 AM
spokes100's Avatar
Nice upgrade! Love the seat too, where did you get it?
spokes100 is offline
post #9 of 19 Old 03-20-2017, 11:39 AM
Preludeman101's Avatar
Beautiful machine!
Sent from my XT1585 using Tapatalk
2016 x590
Power integral Sleeve hitch
Brinly box Blade
Suitcase weights
LED headlights
John Deere 18 Utility Cart
Preludeman101 is offline
post #10 of 19 Old 03-20-2017, 05:02 PM
MikMan48's Avatar
Looks great Austen, I love the colour choice also! It sure is a beast!
Challenge Met
Have you met "The Fahn" yet?
http://www.mytractorforum.com/189-ot...meet-fahn.html
MikMan48 is online now
post #11 of 19 Old 03-20-2017, 06:38 PM
Austen, I have never seen any wheels that looked that good, that tractor looks to good to put to work, should be in show room.
rjmartinny is offline
post #12 of 19 Old 03-20-2017, 06:57 PM Thread Starter
Senior MTF Pollster
Austen's Avatar
Images: 33
Thanks, guys! It's been a fun project and I've enjoyed making it my own.
Thanks for the kind words, Scott!
Thanks, Clevis!!
Thanks, Mike!
MU
Thank you, MU. In terms of counter weight, 40 gallons combined of RimGuard and an Earthcavator.
Thanks Ellis, glad you like it!
Thanks, Eric! It's already on its way.
Thanks! The seat is actually factory Bolens seat, but did not come on the 1886 originally. It came on an earlier large frame model, the 1476. I have also seen this same style seat on some Wheel Horse model GTs of the era as well, so I'm not sure what company actually made and distributed these. A member here under the name of "29 Chev" (Stew) who's quickly built up a reputation for himself doing fine upholstery work in our club made the new covers for me. Here's more info on the seat restoration: Restored seat pics!
Beautiful machine!
Thanks!
Thanks, Mikey! Yeah, I debated on colors for a while and this seemed to be a good a medium.
Thanks for the compliments, Ray, glad you approve!
Kohler CH22 V-Twin
Custom wheel set
Gannon Earthcavator
Tiller
3pt hitch
48" Belly mower
3pt hitch
post #13 of 19 Old 03-25-2017, 10:13 AM
blackjackjakexxix
blackjackjakexxix's Avatar
Wow Austen,what a great job you did
RICKS BOLENS PARTS
www.ricksbolensparts.com
blackjackjakexxix is online now
post #14 of 19 Old 03-25-2017, 11:52 PM Thread Starter
Senior MTF Pollster
Austen's Avatar
Images: 33
Thanks Rick!
Kohler CH22 V-Twin
Custom wheel set
Gannon Earthcavator
Tiller
3pt hitch
48" Belly mower
3pt hitch
post #15 of 19 Old 03-26-2017, 10:24 AM
396 big block's Avatar
Beauty and a Beast right there, "Wow" awesome job!!!
Marty 2012 John Deere X500, 1970 John Deere 120
1972 John Deere 140 Acts 10:34 34 Then Peter opened his mouth, and said, Of a truth I perceive that God is no respecter of persons:
396 big block is offline
