power assisted, power, hydrostatic, and hydraulic steering?? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 5 Old 01-16-2010, 01:14 PM Thread Starter
nglauer's Avatar
Can someone tell me a little bit about the kits that bolens offered, and then provided in later years for the large frames. I'm curious what category they fall under, along with how it worked. My cub 2072 SGT had power steering.. but I don't remember seeing any type of "steering box/valve thing" in the steering column.. I would like to create a kit for mine eventually, but need to know the cheapest way to do it. I don't want to spend 300-800.00 on something on ebay that I might be able to piece together slowly over time. Does anyone know who made the kit for bolens originally? or was it a bolens exclusive item? did any other manufacture offer the same unit.. or similar that might pop up online for less?
I also found this kit for a yanmar.. it's more than I can spend.. but reasonable compared to some stuff i've seen.
http://www.best-used-tractors.com/po...d_steering.htm
Does anyone make a universal kit for GT's?
Thanks for the help.. I want to learn as much about hydraulics as I can between now and when I get my hands on a loader. I want to make sure that I have power steering before I add any more weight to the front as well. It amazes me how much difference the tractor has with the mower on vs. off.. so I can only imaging how hard it gets with a loader on.
Thanks,
Nick
Current Equipment..
Bolens HT23
Cub Cadet 154 loboy
Past Equipment..
Cub Cadet 2072 SGT
Cub Cadet 1811,128
Misc. Attachments:
Bolens Large Frame Tiller
Bolens Large Frame 54" hydraulic blade
Bolens Large Frame Snowblower
Bolens 54" Mower Deck
Tractors are a drug... and I am starting to become a user....
nglauer is offline
post #2 of 5 Old 01-16-2010, 03:37 PM
Re: power assisted, power, hydrostatic, and hydraulic steering??
if you go to the GT2000 (5120H) manuals - either the svc manual or the parts manual had a decent schematic of the optional power steering system offered for it
when checking the manual, first set of pages will be for the manual steering set up - then following pages will detail the power steering set up
and sorry, don't remember which manual had it, but i'd check the parts manual first
basically, at bottom end of steerig column, was a steering control valve (the nearly identical one is for sale on the surplus centers web for $199)
steering column had u-joints at both ends to pull the steering column closer to operator at the bottom end
hydraulics were plumbed "in series" (i'm borrowning electrical term there) off the hydrostat pump/motor
hope that helps
larryccf is offline
post #3 of 5 Old 01-16-2010, 06:05 PM
bhts's Avatar
I'm not sure who made the power steering for the bolens but brantly made one that looks very simular to the one i have.I will be removeing it from a 1886 that will be going on the tractor i am restoring and can post some pics of the setup if you want.
Bolens HT23
Bolens HT20
HT20D
1886-01(restoring)
Brantly Backhoe
Johnson Loader
54 Inch Deck
54 Inch blade
Tiller
Haban Sickle Mower
bhts is offline
post #4 of 5 Old 01-16-2010, 06:17 PM
Eleven Year Site Sponsor
The Large Frame Bolens power steering was a cylinder (with internal valving) that replaced the the drag link from the steering sector to the front tie rod. It was plumbed into the hydraulics off the hydro. It is actually a pretty clever set-up, but I am not aware of any other makes that used the same cylinder in the same way. You might ask someone like Samsbolens. I know he has routinely tried to track down original manufacturers for things so he could offer them for sale to the Bolens freaks.
Doug
Bolens:1254, G14, H14, Whirly Rake, generator; 1250 (2), 1455, 1886, HT20, HT20D, HT23 (4), typical attachments, Bulldog trencher, Danuser post hole digger, Haban Sickle-Mo, Johnson FEL & forklift, Brantly backhoe; Cozy Cab; GK (2) 72" decks, dozer blades, snowblower; Ridemaster 35AB01, sickle mower, disc harrow, grader, hitch; Power Ho (3), sulky, snowcaster, air compressor
Bush Hogs: D4-7, D4-10 (parts), D4-12, plow blades & MMM (Want the 42" trail mower!)
Massey Ferguson: MF12 (1967), MMM
LPBOLENS is offline
post #5 of 5 Old 01-16-2010, 09:35 PM Thread Starter
nglauer's Avatar
I haven't seen a cylinder with the valving built in available online. I thought my Cub 2072 was made like that.. but I must be wrong. From what I have seen online it has a valve inside the steering column. I just know that I miss it alot... especially mowing with the heavy deck under the HT23. I can only imagine how much worse it'd be with a loader.
Bob, will you post pictures of yours when you have a chance. Does it need rebuilt? if so you should take detailed pics so they can make a sticky on the rebuilding process.
Nick
Current Equipment..
Bolens HT23
Cub Cadet 154 loboy
Past Equipment..
Cub Cadet 2072 SGT
Cub Cadet 1811,128
Misc. Attachments:
nglauer is offline
