garden tractors with cat-0 3 point hitches - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 17 Old 01-02-2010, 08:37 PM Thread Starter
The Magnificent
D-Dogg's Avatar
This topic came up not too long ago, and I can't find the thread. No one could name a modern implementation of the category 0 3 point hitch.
It looks like the Kubota G series has one as an option, along with a rear PTO. Also a shaft drive 3PH mounted tiller.
Can any of you Kubota gurus tell me if the rear PTO on the G series is 540 RPM or 2,000 RPM? I could not find that level of detail on their website.
Thanks,
D-Dogg is offline
post #2 of 17 Old 01-02-2010, 08:47 PM
Re: garden tractors with cat-0 3 point hitches
INGERSOLL
david doyle is offline
post #3 of 17 Old 01-03-2010, 10:54 AM
We're all friends here
APinNY's Avatar
Images: 5
Thanks,
I'm no guru but perhaps I can help. I also went through their site and couldn't find any info about a rear PTO for that model. They do mention that the mid-PTO spins at 2576 RPM's, which is fine for mowers and blowers but the rear mounted implements have to spin much slower. The BX mid-PTO runs up to 2500 but the rear only goes to 540. I would imagine the G series is similar.
Al
Kubota BX1860, 48" fine cut mulching MMM, FEL, snow thrower, cab, Heavy Hitch
TroyBilt LTX 13, (given away)
DR Lawn Vacuum. Review here
APinNY is offline
post #4 of 17 Old 01-03-2010, 11:32 PM
Tech Exchange Moderator
Sergeant's Avatar
You can still get Cat o implements thru Tractor dealer's Brinly is still manufactring them to be sold thru dealers only right now.
Manufacturers that still have Cat 0 3point hitch
Cub Cadet 3000 series has a Cat 0
Ingersoll as mentioned above
Kubota
John Deere a Cat 0 3point is still avaliable for the X465 thru X749 Though most people do buy it with the Limited Cat 1 3point hitch. The Kubota G series has a 540rpm Rear PTO for the tiller.
I'm guessing you looking for a 2000RPM tiller for your 318. If that the case the Best tiller to look for for your 318 is a Used Hydraulic tiller for it Because it could use either the Front or Rear PTO. That would be a 30inch Hydraulic tiller. I know from time to time guy advertise them for sale over hear http://www.weekendfreedommachines.co...cus/discus.cgi
John Deere Models:X748,GX335,140H3,112,Sabre 1542,TX Gator
Ingersoll Model:3016PS
Simplicity Models:Wonder Boy
White Model: GT2055
Sergeant is offline
post #5 of 17 Old 01-05-2010, 06:51 PM
BP Fick's Avatar
Kubota no longer makes the G model. Since it was so close in price to the small BX, the 1860, its demise is understandable.
No ground engaging capability on the GR models. It isn't strong enough in key ways for that, although it remains a flagship lawnmower.
BP Fick is offline
post #6 of 17 Old 01-05-2010, 06:55 PM
Just passing through
Upper5Percent's Avatar
http://www.tuff-bilt.com/tractor.html
Hitches: Two three-point Category "0" with individual
Hydraulic lifts- 700 lbs lift capacity
DWIGHT D. EISENHOWER
Upper5Percent is offline
post #7 of 17 Old 01-05-2010, 09:43 PM Thread Starter
The Magnificent
D-Dogg's Avatar
Kubota
Thanks,
I picked up a 2000 RPM Befco tiller for the 318. Had no idea Befco made one.
The question actually arose from a couple of conversations. Someone was asking the practicality of dropping the money on a cat 0, then another question regarding the 2000 RPM PTO.
It seems to me that the limited cat 1 and cat 1 have more or less taken the place of the cat 0. Ingersoll's attachments are all pretty much Ingy specific being hydraulic, but I would suspect Kubota will continue to carry their cat 0 implements for at least a couple of years.
I know plenty of folks make non-driven cat 0 attachments yet. I wonder if Frontier offers anything for the cat-0 still?
That Tuff-bilt is an interesting rig, but at the price, I think the JD x700 and Ingersoll are not exactly worried.
D-Dogg is offline
post #8 of 17 Old 02-21-2012, 08:44 PM
Doing a bit of research it looks like the g series tractors have a 2000 rpm rear pto, it looks like they use the front shaft to run a pulley system to run the rear pto
redneckdzl is offline
post #9 of 17 Old 02-21-2012, 08:49 PM Thread Starter
The Magnificent
D-Dogg's Avatar
Wow, Thanks for that answer. I'd written it off as a no on the PTO.
D-Dogg is offline
post #10 of 17 Old 02-21-2012, 09:02 PM
It was a add on option, and judging by how hard it is to find a tiller which was the only option that kubota offered I figure its even rarer to find a tractor that actually has the rear pto setup
I'm torn between trying to find a 3 pt hitch and making a sleeve hitch for my tractor
Just realized this thread was over 2 years old, glad you got an answer
post #11 of 17 Old 02-21-2012, 09:41 PM
Still lovin' the 322!
PA318Guy's Avatar
Thanks,
Yes and the guy who sold you the Befco is still waiting to hear that it's working !!!!!!!!!!!!!!!!!!!!!
Current Machine JD 322
PA318Guy is offline
post #12 of 17 Old 02-22-2012, 08:00 AM
Its working used it last year on an Ariens GT to cultivate between rows."How tiller will Travel".And I'm running it on a 3250 PTO but throttle back and only running it about 2" deep to cultivate and its offset so it gets right up against the rows once I make a pass with the disc hiller.
gburnett is offline
post #13 of 17 Old 02-22-2012, 08:03 AM
The Tuff-Bilt tractor is built to cultivate one row at a time and really has no equal now as its built for excellent vision and clearance of the crop being cultivated which no garden tractor can come to matching.I have a Hines thats very similar and they're pretty decent mowing tractors also.
gburnett is offline
post #14 of 17 Old 03-03-2012, 06:27 PM
what might some good brands be that make a decent budget box scraper for a cat 0 3pt on a cub cadet?
I think the brinly/crafstman (sleeve hitch) box blade I was looking at might be a bit “lightweight“ for the use I was hoping to put one through...
Cub Cadet HDS 3185 - For Sale (pm me if interested)
ShredSled is offline
post #15 of 17 Old 03-10-2012, 01:44 PM
I'm also looking for a decent cat. 0 boxblade for my 318
318- 46" deck,54 blade, 3pt hitch, 3pt carry-all/sprayer, 3pt cultivator, 12" brinly plow, 4ft 3pt brinly disc, Al Z's 3pt forks
345- 54" deck-sold
Hustler fastrak superduty 25/54
gtstang88 is offline
