Simplicity coronet pto clutch - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 10 Old 05-28-2013, 04:11 PM Thread Starter
Hello,
Currently I am working on a Simplicity Coronet 12 Hydro that I got for free as it was not working. The pto switch was busted so I replaced it with the PTO Kit due to update. I got the machine running and was very happy but when I engage the pto for blade operation nothing happens. All the wires looked fine so I crawled underneath and removed the electric pto. I have no experience with electric pto's so I am not quite sure what I am looking for except I thought someone said there should be some sort of liner on the disc but I see nothing. Is this correct? Here is a picture of it.
Any info will be much appreciated.
Thanks
Name:	2013-05-28 15.04.14.jpg
WooodyII2 is offline
post #2 of 10 Old 05-29-2013, 08:05 AM
Re: Simplicity coronet pto clutch
I would put the clutch back together and back on the rider. do not connect the wires to the clutch. Next take 2 pices of wire and put one on each post of the battery and then touch one to each of the terminals on the clutch. If the clutch is good you should hear it snap in. If it does snap in when you touch and release the wires then the clutch should be ok and that would mean there is a problem with the wiring.
mowman1 is offline
post #3 of 10 Old 05-29-2013, 08:12 AM Thread Starter
Thanks, I will try that today
post #4 of 10 Old 05-29-2013, 08:41 AM Thread Starter
Well......
I did as you said and no click, no nothin. The battery is good so I know thats good. So these clutches look a bit pricey. Anyone no of a good place to get one? New or used?
Thanks guys
post #5 of 10 Old 05-29-2013, 11:39 AM
4K Poster!!!
Fcubman's Avatar
Images: 5
You could use a multimeter and check for continuity through the clutch windings. The PTOs are pretty pricey, so I'd make really sure this one was bad before buying another. Since you can get at the windings, you may be able to find a break in the wiring - probably near the terminals. What do you have to lose at this point?
(Red Green)
Fcubman is offline
post #6 of 10 Old 05-31-2013, 02:17 PM
Not familiar with that particular clutch but can you verify if the armature (moveable disc) is free on whatever it slides on? In other words, if there was a magnetic force, is it physicall possible for the two discs to meet? Assuming it can freely move (big assumption = see my post on Conquest Clutch) it is still dependant on a magnetic force (windings, lead, etc. good) and the distance between the moveable and stationaly (vertically) disc. On the conquest, the coil needed to ohm out between 2.5 and 3.0 ohms if I recall (reference my other post). Mine actually ohm'd out at 3.4 but works just fine. You are really looking to make sure it is no 0 or .something ohms(short) or open lead or exponentially higher resistance (open). Check by putting leads in clutch end plug and verfy at coil connection point if possible (vett out wiring connections). Check to make sure there is a 0.012-0.015" spacing between discs at rest.
On my, all of this checked out but it was the visual/physical observation of a stuck armature that solved the issue.
showags is offline
post #7 of 10 Old 06-19-2013, 07:58 AM Thread Starter
I will give it another look today. Thanks for the info. Been on vaction so back to the grind
post #8 of 10 Old 06-19-2013, 09:03 AM
Deceased March 2015
check on Ebay for a used clutch
shamrockjack is offline
post #9 of 10 Old 06-19-2013, 09:43 PM
sammiefish's Avatar
I know you said your battery is good ... but ...
on my coronet (9 manual)... if the voltage is low (good enough to start but maybe not good full charge) the pto wont engage..
maybe even just a connection problem not providing enough juice
AC 3/400's
sammiefish is offline
post #10 of 10 Old 07-13-2013, 12:20 PM Thread Starter
Finally fixed. I got a clutch from a junker coronet 13 and installed it. And now all is right the world. Thanks everyone for the help
