Snow plow wear bar - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 7 Old 02-19-2011, 01:42 PM Thread Starter
Help Snow plow wear bar
What are you using to replace wear bar on your snow plow? Thank You Stan
bgosh is offline
post #2 of 7 Old 02-19-2011, 06:46 PM
Re: Snow plow wear bar
Most allow you to turn it over to put the unworn edge back down on the pavement.
AC716H is offline
post #3 of 7 Old 02-19-2011, 08:49 PM Thread Starter
Actually I never even thought about that. Thank You Stan
bgosh is offline
post #4 of 7 Old 02-20-2011, 12:04 AM
Tractor Nerd
Justy37's Avatar
There is a local metal dealer here, he sells stuff like iron bars, plates, square tubing. Does little iron projects for people, welding and such. I just get a flat piece from him thats about 1/4 inch thick and take it home and place it on top of my old blade and mark holes, drill them out. Then I take my little 4 inch hand grinder and put a edge on it. I don't make it perfect because I know the cement will do most of that as I'm moving snow.
Justy37 is offline
post #5 of 7 Old 02-20-2011, 11:41 PM
I just cut a 4" x 48" for my 46" plow about a month ago. I just let it run 1" past each side. No need to wory about the finish edge, Plowing will clean/angle it up very fast. I just drilled the holes about .040"+- under the diagonal meas. of the stove bolts' square. It doesn't have to be a square hole. It'll pull right through. I drilled at the center of the 4", so I can flip when the 1st side wears down.
Joe
RailmanJD318 is offline
post #6 of 7 Old 02-21-2011, 09:44 PM
ACmowerguy's Avatar
I just bought new ones at the dealer for $40 each. Got one for each of my two 42" blades. The originals couldn't be flipped but the news ones can. I didn't have the time to make my own. I believe the factory ones are a hardened steel and last longer than regular mild steel bar.
SIMPLICITY- 700, 3410S, 3410H, 17GTH-L, 727, 738, 7116H, 75th anny Sovereign, '99 Landlord DLX
Allis-(2) B-10's, B12, (2) B110's, B-207, (2) B210's, B212, HB212, Homesteader 8, 416H, 710, 912H, 914S , 916H, 917H
Deutz-Allis 917H with PS
Massey-MF8 Executive, MF12, MF16,
Sears- 1971 HT14 hydro
JD - 110, 214
ACmowerguy is offline
post #7 of 7 Old 02-22-2011, 08:21 AM
Burntime's Avatar
Acmowerguy, I think you are right. But for 6 bucks instead of 42 I made my own in 5 minutes. I only use mine in dirt and rarely on the driveway so it lasts and lasts. No idea how it would do on concrete. My buddy is a county worker and he has offered some of the stuff they take off when it wears too far. Its just so friggin heavy that I have not taken him up on it. Its something like 1/2 or 3/4 of an inch thick! I don't want to lug that much around the garage until I need it!
Burntime is offline
