Allis Chalmers B-210 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 26 Old 09-18-2010, 02:38 PM Thread Starter
Justin M.'s Avatar
I brought home my Allis Chalmers B-210 today. I picked it up for $450 with a 42" mower, 36" snowblower, wheel weights, and tire chains. I'm not planning on a restoration, but I do want to fix it up a bit. I'm going to start with figuring out why the lights don't work, then try to adjust to Vari-shift, and inspect/clean/change fluids on the rest of the tractor. I bought it to haul a cart for firewood, and the snowblower is a big bonus, because I won't have to use my walk behind blower to clear a path for the tractor. It may replace my walk behind snowblower for driveway use also depending on how well it works. I will also be pulling an aerator and dethatcher. This is my first old garden tractor, so it will be a learning experience. I'm sure I will be posting up with questions soon.
Justin M. is offline
post #2 of 26 Old 09-18-2010, 03:28 PM Thread Starter
Justin M.'s Avatar
Re: Allis Chalmers B-210
Okay, I have my first question. While check on the headlights not working, I have found that the voltage on the A and F terminals of the starter/generator to be 4V. Using the troubleshooting guide that I found here I grounded out the F terminal, and the voltage on the A terminal went up to 17V. It states that this indicates "the regulator cut-out section is probably not connecting the A terminal to the battery". Can someone please explain this further?
post #3 of 26 Old 09-18-2010, 04:47 PM
skunkhome's Avatar
Images: 9
it is likely the points in the regulator on the generator coil that control the flow of current thourgh the system are burnt or a wire is broken. What does your ammeter say? You could ground out the F terminal and it would charge but it would shortly boil the battery and/or burn up the generator.
skunkhome is offline
post #4 of 26 Old 09-18-2010, 05:46 PM Thread Starter
Justin M.'s Avatar
The ammeter is at 0 when it is running. When I grounded out the F terminal the A terminal voltage went up to around 17V., and the regulator started smoking a little.
post #5 of 26 Old 09-18-2010, 10:08 PM
4K Poster!!!
Fcubman's Avatar
Images: 5
Congrats on your find!
Letting the smoke out of the wires is never a good thing….can you take the regulator apart and inspect the insides?
You have proven the generator is good. The problem lies in the regulator itself, or the wiring. I'd first check to make sure all of the grounds are good, especially the regulator's ground.
(Red Green)
Fcubman is online now
post #6 of 26 Old 09-18-2010, 10:13 PM
Still lovin' the 322!
PA318Guy's Avatar
Real nice find there and I'm betting that after you blow snow with that you won't want to go back to a stand behind!
Current Machine JD 322
PA318Guy is offline
post #7 of 26 Old 09-19-2010, 06:47 AM
USMC
slkpk's Avatar
Images: 21
Great find and enjoy it. My 64 JD 110 unintended restoration started out as a variator adjustment. In the end I was glad I did it. slkpk
1964 JD RF110 Restored
2007 JD 2305
slkpk is offline
post #8 of 26 Old 09-20-2010, 10:57 AM
RUMBLEFISH's Avatar
Images: 3
I picked up a B212 last spring and cant wait to tear into it over the winter. You got a nice tractor for sure and at a decent price.
Good Luck
RUMBLEFISH is offline
post #9 of 26 Old 09-20-2010, 11:15 AM
Jim_WV's Avatar
Images: 13
Looks like you got a great old workhorse there, little fixing and should be good to go for years to come .
Jim_WV is offline
post #10 of 26 Old 09-20-2010, 08:51 PM Thread Starter
Justin M.'s Avatar
So the previous owner called me and said he also had a Simplicity Landlord, with the same 10HP Briggs(running) that he would sell to me for $100 if I wanted it for parts for mine. It's just missing the hood. I really don't need another tractor sitting in the yard, but this sounds like it might be too good of a deal to pass up. What do you think?
post #11 of 26 Old 09-20-2010, 08:55 PM
I'd have handed him the cash thru the phone.
Mike
A gun and a parachute are much the same. When you need one nothing else will really suffice.
Tencubed is offline
post #12 of 26 Old 09-20-2010, 09:06 PM
THEPATRIOT's Avatar
Images: 6
You should be on the way!
Cub Cadet original,70
THEPATRIOT is offline
post #13 of 26 Old 09-21-2010, 03:48 PM Thread Starter
Justin M.'s Avatar
I brought the Landlord home for $100. It runs good, just needs a hood and some belts. It will really be a shame to part this out, but that's what I bought it for.
post #14 of 26 Old 09-25-2010, 04:02 PM
skunkhome's Avatar
Images: 9
Man, you have an ancient bolt together mower deck on that thing. Heavy, heavy mower.
post #15 of 26 Old 09-26-2010, 09:19 PM
jim390fe's Avatar
That tractor is a '64 landlord if it has the original engine it would be Briggs model 23, 9hp engine... I myself would not part it out, looks to be a good solid unit with the original bolt together deck as Phil pointed out.
Tractors I currently own: 1954 Gravely model L, 1962 WH 702, 1966 A-C B-10, 1969 Simplicity 3112H, 2014 Kubota B-3300
jim390fe is offline
