A Conquest, a Prestige and a Dealer - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 29 Old 05-17-2017, 05:02 PM Thread Starter
Willscary's Avatar
Any of you who have read my last couple of threads know that I have been agonizing over the trade of my flawless 2013 Conquest for a new 2017 Prestige EFI. About an hour ago, I drove the new Prestige off my trailer. We are having thunderstorms all around the area, so I figured that I would wait until I used the machine to give a "first impressions" review. Unfortunately, when I turned the key (yes, a key...no push button start) and backed it down the ramp, I realized that the dark clouds coming at me were to be the first to arrive. My fuel gauge was blinking the cautionary "empty" signal, so I thought..."I'll just try it out quick!"In about 25 minutes, I had been able to mow the larger side of my yard. This normally takes about 40 minutes. Better yet, I can normally mow my lawn just over twice with a full tank of gas...perhaps 2-1/3 times. I mowed half of the lawn with the gas gauge blinking near empty.My 2013 Conquest had a 27HP (old rating system) 724cc Briggs Professional Series motor with EFM and push button start. To start it, I would push the start button once to turn on the digital dash and then wait until the tachometer had settled back to zero. With the throttle at full, I would then push and hold the button for a two or three engine cranks and it started, every time. It worked perfectly.My 2017 Prestige has a 27HP (new rating) 810cc Vanguard Commercial series Cyclonic intake motor with a key start. It starts just like a car. Turn the key and hold it for about one revolution and it fires. It also works flawlessly, but quicker than the older motor. This new motor has a deeper growl than the Conquest's motor did.At low throttle, the Conquest idled at 2,000 RPM and at full throttle it sat at 3,600 RPM. The Prestige idles at 1,800 RPM, but only sat at about 3,300 RPM at full throttle when I started. After roughly 1/2 hour of running, this rose to about 3,400 RPM. The motor smells a bit. I am guessing that it is tight and breaking in. I am hoping to see RPMs rise after a few more hours of use. The Prestige is quieter at idle, but noisier at WOT...at least it is right now. After break-in, hopefully this improves also. It runs very smoothly. Oil and filter will get changed at about 5 hours of use. Mobil1 10W-30 will be the fluid of choice.The Conquest had the K66 (non-high speed...top speed was like 5.3 MPH) and it was very quiet. The Prestige has the K72 High Speed, and right now is sort of noisy...it whines when starting out. This is new to me. I have read that synthetic 5W-50 helps this a lot. We shall see in about 30-50 hours, when I change it out. The Prestige is MUCH faster than the Conquest. I did not think I would use the speed...more on that in a bit!The Conquest had the 50" deep profile stamped deck. It cut better than anything I had ever seen before. I was quite nervous about changing decks. The 52" Ferris fabbed deck seems to cut exactly the same as the 50" did, even on my very rough lawn. So far, the clippings look to be smaller and blown farther and the deck is nearly perfectly clean on top. Right now, with a half-hour of cutting under my belt, I would say that the 52" cuts just as well, but cuts faster, finer and disperses better. One thing...the electric height adjustment on the 52" deck seems to be slower than the one on the 50". The Ferris deck is MUCH beefier than the Simplicity stamped deck...not just the metal size, but ALL of the components. The rollers are bigger. the lift mechanisms and hangers are much heavier. the spindles are much heavier duty. It is just plain very well built. If cut quality changes in the future, I will let both you and the dealer know!My Conquest was a rigid frame. the Prestige has the 4 corner suspension. there is a strange feel to the machine when starting or stopping. The ride on the Prestige is not perfectly smooth, but when compared to the rigid ride of the Conquest, it is a huge improvement. I probably mowed 50% faster than I ever did with the Conquest, and the ride was nicer, even at the higher speed. I will be mowing faster from now on! The suspension works well. Not perfectly smooth, but much better!The Prestige has hydraulic lift. I like not having the big lever on the left side anymore. It also has a tilt steering wheel. It's a nice feature that I don't think I will need to mess with.The Prestige has power steering. It definitely works and is easier to steer than the Conquest. Not a deal breaker if I did not have it...but perhaps, just maybe...the power steering may have also aided in the very quick mow time on this first half of the yard.I looked at these machines at several "local" dealers. The price for the EFI Prestige was high and the trade value of my Conquest was low. I can not say enough about Nathan from Persha Equipment in Mayville, WI. Two of you on the forum recommended them. He gave me an excellent price on the Prestige, a very fair price for a trade of the Conquest, was knowledgeable and a pleasure to deal with. All in all, he made this upgrade better than I could have ever hoped!Feel free to ask questions. It is raining here right now, so I will most likely settle in to reading the manuals.
I own a 2017 Simplicity Prestige 27/52 EFI.
From 2015 to 2017 I owned a used 2013 Simplicity Conquest 27/50.
From 1996 until 2015 I owned a White LT-16 Vanguard V-twin and 2 stage blower.
In 1991 I purchased a used 1984 Gilson 16 HP opposed twin. It was a horse!
Willscary is online now
post #2 of 29 Old 05-17-2017, 05:05 PM Thread Starter
Willscary's Avatar
Re: A Conquest, a Prestige and a Dealer
OK, so the above was all written in paragraph form. What the heck happened???
post #3 of 29 Old 05-18-2017, 08:30 AM
Questions? We want pictures!!
PappaNille is offline
post #4 of 29 Old 05-18-2017, 09:38 AM
'Simple' MTF Member
Talntedmrgreen's Avatar
Images: 59
Very glad to hear the first impression is a great one! I would LOVE to run one of those babies on my lawn. I have had a couple Prestige tractors, and they are fantastic (20/50 and 25/54). I would really like to try the new fab deck and suspension setups. I have always heard great things about Persha, in fact, they are the only dealer name I know beside the local guys here. Great to hear there's a good one out there!
Let's SEE it!!
Talntedmrgreen is offline
post #5 of 29 Old 05-18-2017, 11:58 AM
Glad to help, I knew you would like Nathan and the deal he gave you. Great people.
Legacy XL 4x4: Hardside Cab, 47" Two Stage Snowblower, 60" Deck, Front End Loader. Prestige 27HP/54" Deck, Simplicity Chipper/Shredder. Fimco 25 gallon tow behind sprayer
Andy is offline
post #6 of 29 Old 05-18-2017, 12:25 PM Thread Starter
Willscary's Avatar
I was very happy with the knowledge they had and Nathan gave me an amazing price, plus a very solid trade amount. I did not even want to haggle. It was a great trade experience without having to ask for anything to change!
Thanks Andy!
post #7 of 29 Old 05-18-2017, 03:10 PM Thread Starter
Willscary's Avatar
I mowed until it rained yesterday. About 1/2 acre was cut and then the tractor was put away. It quit raining a few hours ago, so I brought it out to take pictures.
Hopefully you can see how well the lawn was cut. I cut at about 3-1/2". It was probably 4-1/2" long. Notice how clean the deck top is and how fine the cuttings that are on the deck are. Perhaps this is just a first small cut thing, but it is unreal how clean the deck is and how fine the clippings are.
ID:	1978642   Click image for larger version
ID:	1978650   Click image for larger version
post #8 of 29 Old 05-18-2017, 03:22 PM Thread Starter
Willscary's Avatar
They have swapped the headlight control and the PTO control from one side to the other. They have also swapped the RMO switch and the height of cut switch. What I mean is they are on opposite sides of the dash from where they were on my 2013 Conquest.
ID:	1978666   Click image for larger version
post #9 of 29 Old 05-18-2017, 03:35 PM Thread Starter
Willscary's Avatar
The 810cc 27 HP Briggs Vanguard Commercial Cyclonic EFI...
ID:	1978682   Click image for larger version
ID:	1978690   Click image for larger version
post #10 of 29 Old 05-18-2017, 04:10 PM
Wow looks great!
post #11 of 29 Old 05-18-2017, 04:36 PM
Great job. I'm jealous.
What about a video? I would love to see it start up and cut.
Sent from my SM-J320V using Tapatalk
Ilovetomow is offline
post #12 of 29 Old 05-18-2017, 05:12 PM Thread Starter
Willscary's Avatar
I filled the tank with gasoline (Top Tier, ethanol free 87 octane) and drove it around for a few minutes. The motor is now buttery smooth and is beginning to get quieter.
For others with a K72...does your transaxle whine when starting out or changing direction? My K66 was, for the most part, quiet. It only began to whine when towing the loaded trailer up the hill, and then, not that loud. This thing whines any time I start out. Is this normal?
post #13 of 29 Old 05-18-2017, 09:14 PM
I can tell you that I had a 2006 (I think) Prestige about 1.5 years ago with only 250ish hours that I flipped pretty quickly. It certainly was not well maintained before I got it, however, one of the things I did was of course change the transmission oil. Out of all the things that was wrong with this tractor, that oil was like honey.....perfect, and the transmission still whined.
Also, I have a fairly new Broadmoor with a K57. When I bought it the tranny whined like any other tractor I had. Today, after I put on the 72nd hour of use, that whine is pretty much gone. It's still there, but I hardly notice it at all. Maybe I'm used to it and just don't pay attention any longer, but I do believe it is quieter.
Hope this helps a bit.
post #14 of 29 Old 05-18-2017, 09:46 PM
That sure is one sweet looking machine, how do you like the new mesh seat? I sure like my old Prestige I just turned 365 hours on it since new.
Andy is offline
post #15 of 29 Old 05-18-2017, 11:08 PM Thread Starter
Willscary's Avatar
Ilovetomow...thanks! Maybe the transaxle just needs to break in also, but my Conquest was dead quiet. This whines...only when starting or changing directions. It does make me feel a bit better though.
Andy, My Conquest had the mesh seat. It is the best mower/ tractor seat I have ever sat in. Others may be as comfortable, but the way it breathes...it is awesome that seat sweats are gone...even on hot days!
I went out and finished the lawn in about 20 minutes tonight. The thing is fast and the mower deck at those speeds is just as good as the 50" on my slower Conquest (so far). The power steering was not needed, but it sure does make mowing faster!
