What is the best way to clean paint off tires? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 17 Old 02-22-2008, 09:32 AM Thread Starter
Btackett's Avatar
Previous owner decided to spray paint the wheels and got overspray on the inside of the rear tires. I removed the tires, sandblasted and re-painted the wheels and getting ready to put the tires back on painted rims.
What is the best way/cleaner to use to remove it before I put the tires back on?
I have heard that DOT3 brake fluid works good and then clean it off with a 409 or equivalent cleaner?? Anyone else ever heard this? What about WD40?
Would laquer thinner damage the rubber?
thanks,
Bill
Btackett is offline
post #2 of 17 Old 02-22-2008, 09:56 AM
Rest in Peace Mr Jimi
Mr Jimi's Avatar
Re: What is the best way to clean paint off tires?
Sandblasting is the very best way.
Mr Jimi is offline
post #3 of 17 Old 02-22-2008, 10:04 AM
jazzyjeff's Avatar
Images: 19
Any petroleum product is not good for the rubber technically .Id use steel wool and soapy water or a scotch brite pad.The friction will take it right off pretty quick.If you use a petroleum product just don't go to crazy with it.But id try steelwool first.
Jeff
http://www.zaleskiequipment.com
Bobcat CT440 Cab, Ingersoll 4120
jazzyjeff is offline
post #4 of 17 Old 02-22-2008, 11:25 AM
Jersey Mechanic
I use Carb. Cleaner on a rag. If the tires aren't dry and cracked it will take it right off and make the tires look new. However if the tires are dry and cracked you have to use a scrub brush and a heavy cleaner, I use the solvent from my parts washer.
eddyyy302 is offline
post #5 of 17 Old 02-24-2008, 04:18 PM
munderhill's Avatar
Images: 7
I second this recommendation.
MU
munderhill is offline
post #6 of 17 Old 02-24-2008, 08:17 PM
Retired MTF Admin
mark777's Avatar
Easy Off oven cleaner works well. If you shoot the foam in a disposible container (coffee can) brush it on the areas and let it sit in a cool, dry place it will lift the over-spray in 15 minutes.
mark777 is offline
post #7 of 17 Old 02-25-2008, 09:14 PM
7000 posts and climbing!!
Dad0850's Avatar
Images: 7
If I get paint on the tires I use thinner (or reducer) to remove it.
I've always been crazy, but it kept me from going insane.
Waylon Jennings
Dad0850 is online now
post #8 of 17 Old 06-10-2008, 12:24 AM
fez
gasket remover works nicely on removing paint from any surface
fez is offline
post #9 of 17 Old 06-10-2008, 12:27 AM
Just passing through
Upper5Percent's Avatar
PLOWING relatively soft ground works...it just takes a couple of seasons...
DWIGHT D. EISENHOWER
Upper5Percent is offline
post #10 of 17 Old 06-10-2008, 01:30 AM
MEMBER
TOMMY's Avatar
Wd-40
2010 JD X320
48 FARMALL SUPER A
74 Sears ST-12(Disassembled)
74 Sears ST-12
73 Sears ST-12
TOMMY is offline
post #11 of 17 Old 06-10-2008, 06:47 AM
ex spelling bee champ
Ingersoll444's Avatar
Images: 14
Next time you go to paint the wheels, spred some Vasaline on the tire. Paint the wheel, and wipe the overspry off!!
Paul B
SUPER Of The Month 10/2011
Ingersoll444 is online now
post #12 of 17 Old 06-10-2008, 07:16 AM
Once was a Super Member
Wingnut's Avatar
Black tire paint, but then you have a whole can of worms painting the whole tire.
Celebrating 39 years of a Drug-Free Elvis! Adventures with Harry Ferguson!
How far you go in life depends on your being tender with the young, compassionate with the aged, sympathetic with the striving, and tolerant of the weak and the strong, because someday in life you will have been all of these.
Lose money while restoring a Farmall F-12 let me show you how!
CLICK HERE
Wingnut is offline
post #13 of 17 Old 06-10-2008, 08:44 AM
earth's Avatar
Can ya rotate the tires? Mounting Left to Right or vice versa. Put the painted side on the inside where ya can't see it? If you have Ag tires, make sure the tread is going in the right direction.
MAN'S PRAYER --
I'm a man...But I can change...If I have to...I guess.
If all else fails, use duct tape.
earth is offline
post #14 of 17 Old 06-10-2008, 10:21 AM
10,000 +posts!
glenn27's Avatar
I use the vasoline or grease trick a lot, if I'm in a hurry and don't want to tape off everything--but Acetone on a rag works well.to remove overspray when you miss....
Jimmy Buffett
glenn27 is offline
post #15 of 17 Old 06-10-2008, 12:28 PM
I've used carb or brake cleaner,paint thinner or laquer thinner, to get overspray off tires--but they will dry out the rubber some and possibly cause the tires to crack sooner that they normally would...I'd say brake fluid would be OK,it's made to be compatible with rubber seals in brake calipers,etc,and EATS paint real good!..
I've used E-Z Off or other cheap dollar store oven cleaners to clean tires and gunky parts before painting with excellent results,you just have to be careful what you use it on--it'll eat into aluminum if left on for long,and lifts paint off engine blocks made of aluminum too--Castrol Super Clean does the same thing,so if you have mag wheels ,be careful not to get the cleaner on them!..
Robert
Tractor-Holic is offline
