LawnBoy Governor Adjustment? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 9 Old 07-15-2008, 04:16 PM Thread Starter
I got my 10515 running today.Apparently the only problem was the governor spring which I replaced.
It's not exactly right. The sping seems to be about 1/4 inch or more too long. It extends through the linkage slot.
But, it may be that I don't have it set in the right place.
It works. RPM sounds about right WOT and it idles down fine. But, at about the last 1/8 inch from being all the way to idle the governor lets it go back to WOT.
Do I need to rotate the adjustment one way or the other, or what? Thanks
ZeroJunk is offline
post #2 of 9 Old 07-15-2008, 04:44 PM
5K Poster!!!
Indy452's Avatar
Images: 9
Re: LawnBoy Governor Adjustment?
Does your 10515 have a metal or plastic carb?
Indy452 is offline
post #3 of 9 Old 07-15-2008, 05:55 PM
mhdi22's Avatar
I'll be watching for the answer too.........metal and plastic carbs...........just can't seem to get it right (finding the high revs)
8480......6257......10650
mhdi22 is offline
post #4 of 9 Old 07-15-2008, 06:03 PM Thread Starter
It's plastic.
ZeroJunk is offline
post #5 of 9 Old 07-15-2008, 06:47 PM
My kid @ W.H. gift shop:
Edward's Avatar
Images: 9
http://mytractorforum.com/showthread...ighlight=10323
and theres a few more pics I know of that I took on other threads I started, and I know others have posted pics too. If you search, do a user search of threads started by me using 10323 as the keyword
Edward is offline
post #6 of 9 Old 07-15-2008, 07:43 PM Thread Starter
Edward, you mentioned the service manual suggested starting at 1/3 on the governor adjustment. Do you remember whether that is CW or CCW looking down the barrel?
ZeroJunk is offline
post #7 of 9 Old 07-15-2008, 09:38 PM
Edward's Avatar
Images: 9
Clockwise
Edward is offline
post #8 of 9 Old 07-15-2008, 09:57 PM
Senior MTF Poster
"he spring seems to be about 1/4 inch or more too long. It extends through the linkage slot."
Don't think that is unusual.
Walt Conner
Walt 2002 is online now
post #9 of 9 Old 07-16-2008, 12:56 PM Thread Starter
Mystery Solved
The cable was coming in at such an angle that it cocked up the throttle linkage enough that it was contacting the adjustment nut and pulling the butterfly open. Tied the cable at a couple of placed to secure it in correct postion, idles fine now. Thanks for the input.
ZeroJunk is offline
