Correct Engine RPM, set? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
post #1 of 6 Old 07-19-2006, 09:31 AM Thread Starter
jerry_nj's Avatar
I have a Sears 6.5 B&S 22" push mower that I run in the mulch mode most of the time.
It came with an OEM mulch blade, single blade with extra cutting surface and curves. It works ok, but I think it may work better if the engine were at a higher RPM, engine sound is the usual loud, but not very high RPM. These come factory set and I don't think one can change the RPM without making up some kind of a kludge. As noted on another thread, I replaced the OEM blade with a Viper blade and the mulching is improved. I still wonder about the RPM, is there an inexpensive ignition pick-up tachometer good for lawn equipment anyone can recommend? Then if one has a tach, what is the correct RPM, I suppose it depends on the size of the blade, higher for a 20" than for a 22".http://www.mytractorforum.com/newthr...wthread&f=155#
Biglaugh
jerry_nj is offline
post #2 of 6 Old 07-19-2006, 10:11 AM
slipshod's Avatar
Re: Correct Engine RPM, set?
If it is mulching OK why do you want to run at higher RPM's?
slipshod is offline
post #3 of 6 Old 07-19-2006, 10:45 AM Thread Starter
jerry_nj's Avatar
Good point, low RPM, better gas mileage I suppose. Still, I'd like the mower to run at the "design" RPM. My ear says it isn't, so a tach and spec would answer the question unambiguously. I suppose larger engines may run at lower RPM. 6.5 HP is the largest walkbehind (not power driven) engine I've ever had. Then too, I wear ear protection, to protect my already damaged hearing (horse it out of the barn) and that says I hear only part of the sound the engine makes. But, I think I do hear the "tempo" of the RPM.
jerry_nj is offline
post #4 of 6 Old 07-19-2006, 01:09 PM
Jerry,
All push mowers have the engine speed set by the blade tip speed, not the top goverend speed . Somewhere, I have a chart that shows the maximum tip speed for all blades up to 30" . I got it from a Briggs field tech about 10 years ago. You can get a small tach called a Vibra Tach at most small engine shops.
Dave
DLF_IN is offline
post #5 of 6 Old 07-19-2006, 07:14 PM
Lawn Mower Fan
Jason's Avatar
Blade tip speeds are federally-regulated to 19,000 feet per minute.
Cheers,
Jason
'87 Lawn-Boy Supreme 8157 (L-B F)
'94 Craftsman 3-n-1 (Honda GCV160)
'95 Lawn-Boy Silver 10301 (engineless)
'99 Lawn-Boy Silver 10330 (Tec LEV100)
'01 Honda Masters HR215SXA (GXV140)
Jason is offline
post #6 of 6 Old 07-19-2006, 09:53 PM Thread Starter
jerry_nj's Avatar
Yes, I have understood that manufacturers have to limit blade tip speed, and it is lower for residential than for commercial machines. As residential lawn mowers are all direct drive, that is the blade is directly attached to the crankshaft there is a simple relationship between the RPM and tip speed. Let's see I if I can do the math:
2"pi"R (R = Radius, is 11" for a 22" mower) is the Circumference, is 69 Inches. and if limited to 19K feet per minute, or 209K inches per minute, I get RPM(max)=209,000/69 = about 3,000 RPM, hum if I didn't make a mistake, this sound a bit high. Well, as I compute it I'd not want the engine to run higher than 3K RPM, still need a tach to find the RPM.
jerry_nj is offline
